Air gun clicks, will not drive nail, makes a poof. I relieve pressure, put in a drop of oil or two and it will go back to nailing for awhile. what gives?
SOURCE: cambell-hausfeld framer
its double firing, after firing gun pull back, what is happening is when you fire a nail your pushing the gun back onto the wood and its putting another nail in
SOURCE: 16g wont shoot nails. bottom flat piece comes out
You broke the "hammer" you can open the housing and replace it, fairly simply. You can buy replacement parts at most large scale hardware or tool stores. The task takes about 10 min, and some simple hand tools.
SOURCE: Gun fires, leaves good indentation, no nail. WCE
Remove nails and use thin tool to push driver all the way up to top of cylinder. If the gun fires one nail then skips, the driver is not returning to top of cylinder. If no nails fire, then nails are not feeding into proper position. Driver must return to top to allow nails to feed into position. Most common problems are bent driver, worn piston oring and bad batch of nails(head too large). Good luck
SOURCE: i have three nailers from CH and all of them sound
Check and adjust the air pressure at the compressor. All air tools have a recommended range of pressure, and you may not have enough air for the tool to work. Also, place two drops of pneumatic oil or light machine oil into the air inlet at the nailer, and then connect the hose. Fire the gun several times into scrap wood. Oil with 2 drops daily.
Best regards, --W/D--
SOURCE: air leaks when triggered and no nail
Make sure no nails in gun. With air connected listen for leaking thru nose of the gun also. If leaking thru nose slightly, air is getting past the cylinder seal oring and/or top of cyl is not seating against headvalve. Repair leak to nose of gun before trying to fix head leak. With no air leaking thru nose of gun, add plenty of white grease to orings in the head (one oring at a time) to see if leak is less and/or grease will streak behind the leaking oring. Then repair as needed. May need slightly thicker oring or sand surface where oring makes contact to remove scratches that are allowing air to pass. Also air can enter the head thru the small port in the gasket leading to the head (make sure that the gasket is sealing).
