Question about Crosley 40-pint Dehumidifier
Crosley dehumdifier high-pitched whinig
I just purchased a Crosley 70 Pint dehumidifier, model cdf700w1. I got it home, let it acclimate to room temperature for about 4 hours....turned it on and was pleased that the fan was not loud. However, when the compressor kicked on it makes a high-pitched whining sound. It's really bothering my ears and I called and left a message at the appliance center where I purchased it. It is collecting water, but I am very concerned because my other (GE) dehumidifier did not make any high-pitched sounds. Is this a bum unit?
I HAVE A WHIRLPOOL 25 Pint Dehumidifier model AD25BBL2 serial starts with QM. Anyway it Seems to work ok as water does collect in water tray. About every 30 minutes it makes a single KNOCK NOISE. Unsu
Hello, Consumer. We're sorry to hear about the difficulty with your dehumidifier. Below are links to our Use & Care guides, Parts Diagrams, Troubleshooting information and the Service are of our website. We hope this helps!
May 21, 2014 | Whirlpool 25-Pint Dehumidifier
There is a part inside the water bucket with a wheel. Where does this attach to the unit?
I have a sg-deh-30-2 model and the unit seems to be doing everything right,the filter is clean the motor is running and room temp is 75 but the machine is not dehumidifying the bucket is dry
Jun 17, 2012 | Soleus DP2-70-03 70 Pint Flat Panel...
Need float switch that cuts off dehumidifer when bucket gets full
Without a Model Number or Part Number it's hard to help you. But here are three links, where you can find the float switch, if it's still available. You'll definitely need the Model Number to find anything.
Hope this helepd you. Please let me know. Thanks.
May 11, 2011 | Crosley 40-pint Dehumidifier
Dehumidifier freezes up
Dehumidifiers2_bing.gif freezing up can be causes by a few different problems.
Here is a tip that I wrote to help people with the freezing dehumidifier2_bing.gif problem....
Dehumidifier is Freezing up and not working
Jul 01, 2010 | Whirlpool Gold AD70USS 70 Pint Per Day...
Crosley dehumidifier does not collect water.
There are many reasons for a dehumidifier2_bing.gif to not work or collect water.
Here is a tip that I wrote to help people to figure out what is going wrong with their dehumidifier2_bing.gif.
Dehumidifier is running but no water is in bucket
May 13, 2010 | Crosley 40-pint Dehumidifier
Humidifier Fan Doesn't Stop
RH at 70 % seems to me a little excessive you really should be working somewhere around 50 to 56% the fan has to move Air through the system.
I would like to know your room Air temp what is the Air temp comming off the system. what are your parameters.
Jun 08, 2009 | GE AHG40LA Dehumidifier
Dehumidifier automatic on and off function not working
Unless you live in a dry environment or place the unit in a hermetically sealed room, it probably will not turn off. As the air dries within the room, more moisture comes in with the air. As long as the air outside of the room is more humid than the room this will be true.
Mar 10, 2017 | Whirlpool Gold AD70USS 70 Pint Per Day...
Goldstar Dehumdifier - draining through hose not working
Check the connection where you attached the hose. It may be plugged or covered by a plastic film from when it was molded.
Jun 09, 2008 | Goldstar DH304 Dehumidifier
Crosley 40-pint Dehumidifier Logo
Top Crosley Dehumidifiers Experts
Bill Long
Gil Shultz
Are you a Crosley Dehumidifier Expert? Answer questions, earn points and help others
