Question about John Deere Garden
Safety reset Hit a piece of wood while mowing that lodged between the deck and blades killing the mower. Removed the wood, but mower will not start. Is there a safety switch that needs to be reset? If so how is that done? John Deere 445 with 60" deck
    New Friend:
  • 12 Answers
None that I am aware of
Posted on Jul 28, 2013
SOURCE: replace blades on a john deere L120 mower deck
First make sure you have the tools, metric that is. The deck must be removed and turned over. To do this you must put the deck in the lowest position. Using a 15mm socket pull the belt tension spring pulley forward to detach from clutch. Next remove retaining pins located at the five deck brackets. This will allow the arms to slide off and the deck can be dragged out from under the mower. Turn deck over. Use a 18 inch 2x4 to block blades while removing the two 15mm bolts. The bolt heads will need to be cleaned so the socket can seat on bolt head. I use my torque wrench to get more leverage and i can use it to reset blade bolts to 64 ft lbs. While blades are of it is a god time to thoroughly clean underside of deck.
Posted on May 25, 2009
SOURCE: john deere 111 mower deck. Lift is in stuck in highest position
Looked up detailed isometric diagram w/ parts denoted on John Deere website. FixYa website was a litele misleading. I did not realize that accessing a question posted "for free" would cost me something to get the answer. It's kind of like askin a neighbor as a neighbor to give you a hand and then he sends a bill.
Thanks but no thanks
Posted on Jun 26, 2009
  • 5 Answers
SOURCE: John Deere LA110 mower blades got disengaged
does it engage manually with a lever, or is it electronic with a push pull switch? if electronic, check the wire that goes to the electric clutch, it might have come off when unplugging it. do all this with the engine off
Posted on Jun 27, 2009
mickey813
  • 472 Answers
SOURCE: John Deere L120. Engine dies when PTO switch is pulled.
sounds like the seat switch is bad
Posted on Mar 02, 2010
  • 18 Answers
SOURCE: PTO loads engine down and almost quits running!
pto is going bad
Posted on Jun 06, 2010
Craftsman Model Number: 917.377151 motor shuts down when blades engaged
The engaging of the mowdeck is cause an excessive demand of your engine. From that, we can assume your problem is in the deck. Since the power drive is all about belts and it threw the belts, from your information I can only deduce that either an object (stick-wood-rock) has wedge into a position that has stopped rotation of the blades. Also, each blade has a pulley/spindle. These have bearings which must be free to rotate.
A bearing failure or seizing can also cause the problem you report.
Follow safety rules in your manual to insure the engine cannot start. Attempt to rotate each blade to check for free rotation. If the do not you most likely will need to remove the mower deck and check further. An obstruction or seized spindle should be easy to determine and sit repair is easily possible.
Sep 03, 2016 | Craftsman Garden
Why does it bog down in grass maybe 6 " high?
The likely cause of this is that the grass is too high for your mowers deck. You should try just mowing about 1/3 of the blade at a time (if you can) until you reach your desired length, so if you grass is 6" high, only take off about 2" at first to reduce the stress on your mower. Set your mower deck to it's highest setting and give it a shot.
Also, be sure that the blades are sharp, and if you don't have mulching blades, you should get some! Grass this high will leave long clippings on the lawn which can suffocate the grass, mulching blades will chop up the clippings into smaller pieces, which is beneficial for your lawn!
Finally, make sure you aren't mowing wet grass. If you mow when the grass is wet the clippings can stick together and clump up under the mowing deck which will cause excess strain to the mower and maybe even cause it to shut off.
If none of this works, you may want to use a string trimmer to remove the first two inches of your grass and then continue mowing as normal!
Hope this helps! Happy Mowing!
Aug 03, 2015 | Garden
Is there a safety mechanism / cable on Husqvarna LGT2554 that will not allow blades to engage if it runs out of gas while mowing
None. The only safety switch that prevent blades from engaging is the reverse switch but that will just kill the engine.
It is more likely that the deck drive belt has came off only of the pulleys.
Oct 19, 2014 | Garden
I ran over a steel stake that locked up my blades and killed the engine. Freed jam, engine will still not start. Is there a safety reset?
hello,check the key way on the flywheel,when engine is stoped suddenely this will happen,shears the keyway and throws out of time,want start,hope this helps,
Feb 18, 2012 | Husqvarna Lawn Tractor 48" Deck, 23 Hp,...
Ran over a steel stake that locked up the blades and killed the engine.
hello ben, Again,i said that the key way on the fly wheel may be out of time so engine will not start, you could check the deck safety switch may have knocked out or adjustment,hope this helps.
Feb 18, 2012 | Husqvarna Garden
My mower will start but when I pull the handle back to mow it shuts off. What can be the problem?
Flip it over and make sure that the blade is clear. I've had pieces of wood jammed. The engine starts but I couldn't engage the blade.
Jul 01, 2011 | Garden
John Deer 100 series Having problems with the mower deck. Started hearing a ticking sound while mowing. stopped to clear a possible obstruction. pulled PTO knob and it is down right jammed up! wants to...
Check that the blades spin freely by hand. That may be in contact with the deck somewhere or one of the deck bearings may be seized. Regards Phil.
Apr 12, 2011 | John Deere Garden
Troy Bilt model 60TG I hit a small piece of wood and the tractor
If you haven't already, check to see if there is a hunk of wood wedged between the blade(s) and mower deck. I've seen that happen. I pried the hunk of wood out with a crowbar and life was good again. The second time, someone ran over a campfire log they didn't see under leaves last fall and bent the blade spindle. It basically froze the spindle in place even though there wasn't anything wedged in there. I removed the belt from the top of the mower deck and then it started just fine..... although the blades and shaft were toast and had to be replaced. If you can disengage the mower deck without removing the belt(s), try it if you haven't already. See if it starts that way. If not, the issue may be more serious such as a broken connecting rod in the engine. Try the simple stuff above first to troubleshoot the cause.
Apr 30, 2010 | Garden
VIBRATION-THRU SEAT & FOOT RESTS AFTER ENGAGING BLADE
get down and gun your fingers in the slot that the belt rides in, soulds like you may have a small rock or piece of wood lodged in the v part of one of the pulleys. I bet thats it Jim
Dec 18, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Garden Logo
154 people viewed this question
Top John Deere Garden Experts
Phil Walker
Phil Walker
Tim Whalen
Wayne Fellows
Wayne Fellows
Are you a John Deere Garden Expert? Answer questions, earn points and help others
