Question about Dometic Refrigerators
Norcold 811 code
Wil not switch to ac in auto mode
    Top Expert:
  • Dometic Master
  • 4,262 Answers
Bad display board
Posted on May 30, 2016
3 Suggested Answers
  • 68 Answers
SOURCE: Norcold Fridge will not work on LP gas while traveling.
One of two problems. The auto switch is bad or the lower circuit board is not doing its job. You can call norcold technical or take the board to a service center and have it checked with the tester they should have. The lower board retails for 176.00. I looked at my tech file and it is a little vague on your particular situation. If I were repairing your fridge I would take the smart route and call technical. Hope you get your problem solved. If you need more help please feel free.
Regards
Posted on Mar 24, 2009
SOURCE: Norcold model 1200LRIM. Unable to
Try to unplug it from the battery a few hours and then plug it back in and see if you are now able to select the AC or LP mode. There has been a recall on the 1200LRIM, The defect is a potential cooling unit leak caused during AC electric mode operation. Click on the link below to read more:
http://www.texastriallawyer.com/norcold/index.html
Posted on Nov 21, 2010
Norcold fridge in my motorhome
Norcold fridges are now part ofThetford one of the largest suppliers of mobile and marine products. You do not quote the model so not sure if a 3 way (gas/mains/12v) or AC/DC. The most common problem with all mobile fridges is the heater unit is faulty. Thetford have discontinued spares for a large range of norcold models. Information can be obtained on the Thetfold.com website.
Good Luck
Jul 09, 2014 | Refrigerators
Fridge will not work on AC mode. AC is present into fridge.
There should be a code appearing on the display. If you are not getting any 12V to the Fridge your fridge will not function. You may also want to check for any blown fuses inside the electronic board assembly. ">
Aug 30, 2013 | Norcold Inc Norcold 1200LRIM Refrigerator
My Norcold N611 frig code flashes 3 time every few second and doesn't go into A/C mode and will only go into gas mode when the switch is in auto mode and the interior light stays on even when the
The N611 will flash 3 times as an AC heater fault. If your AC heaters are ohming out properly (48 ohms of resistance), then you have a bad power board. If the AC heaters are not showing around 48 ohms of resistance, replace the AC heater. It's going to be one of the two. Here is an article on it:
Norcold Fault Codes AC HE or On light flashing 3 times What to do
Aug 16, 2012 | Refrigerators
Model 12110 IM Norcold-not cooling on AC or Gas..no fault codes coming up
Hi, if the burner lights in the 'gas' mode, the control board is OK. You most likely have a leak in the sealed refrigerant system, and you need to have the leak located and repaired. This is a job for a RV refrigeration technician. If you need to find the nearest Norcold authorized service dealer, go to www.thetford.com, and use their dealer locator menu.
Apr 13, 2011 | Thetford RV Refrigerator - N300 Model -...
Norcold model 1200LRIM. Unable to select AC or LP mode. Auto is only option. Fridge frequently quits in Auto mode. No error codes. Display just goes blank. Battery connections are good; voltage is good....
Nov 21, 2010 | Thetford Norcold RV Cooler/Freezer
Refrigerator doen't work on electric
check the fuse on the back of the board on the fridge itself
Sep 01, 2009 | Thetford Norcold RV Cooler/Freezer
My Norcold Fridge will not operate on AC
Check you 110 volt breaker in the converter panel to see if it is tripped
Apr 03, 2009 | Thetford Norcold RV Cooler/Freezer
Regards
Mar 24, 2009 | Dometic NDR 1292 Refrigerator
Toshiba estudio 161 copier
1. Entering the simulation mode
Perform the following procedure to enter the simulation mode.
"C" key AUTO/TEXT/PHOTO key
Main code Start key Sub code Start key
(Note:Perform the first four key strokes quickly allowing no more than one
second between key strokes.)
if the machine dies enter the code 14, then press start, the machine wil reboot and the problem wil be solved, if not , contact your nearest service centre
May 05, 2008 | Toshiba e-Studio 161 Copier Copier
Refrigerators Logo
24 people viewed this question
Top Dometic Refrigerators Experts
John Tripp
John Tripp
4stevetaylor
Level 1 Expert
RV REFER LLC
Level 1 Expert
Are you a Dometic Refrigerator Expert? Answer questions, earn points and help others
