Question about Euro-Pro Shark EP366 Handheld Vacuum
Where do you get filters for a EP366 - Euro-Pro Shark EP366 Handheld Vacuum
  • Euro-Pro Master
  • 18,389 Answers
TO ORDER REPLACEMENT DUST CUP FILTERS
To order, send check, money order or credit card authorization to:
EURO-PRO Operating LLC
94 Main Mill Street, Door 16
Plattsburgh, NY 12901
or call
EURO-PROCustomer Service at: 1 (800) 798-7398
Monday to Friday 8:30 A.M. -5:00 P.M. Eastern Standard Tim
Please Note:
The Shark Dust Cup Filters are washable.
Importan
Make sure that Dust Cup Filter is completely dry before inserting back in the hand vacuum
http://www.sharkclean.com/manual/EP366_(700_WATTS)_REV_0603A.pdf
Posted on Jul 27, 2013
My dyson v6 pulses when I put the filter back in
if fitting/ removing the filter makes a change ( filters no nothing but filter air), then the problem is the filter
if a new filter makes no difference to the problem , take it in to a sevice agent for repair
Jan 08, 2017 | Dyson Vacuums
How I clean exhaust filter
Here is what the owners manual of your unit lists to clean the exhaust filter.
Cleaning the exhaust filter
Open and remove the filter grill. (Fig. 4)
Remove the filter and shake out debris. (Fig. 5)
Rinse the filter in water if necessary. Let it dry before placing it
back into cleaner. (Fig. 6)
Replace filter grill.
Apr 03, 2016 | Eureka Rally 2 Canister Vacuum with...
How do I open Dyson DC7 to clean filter
The only filter you can clean is in the compartment beside the dust bin, push in on the release catch to pull out the filter holder. This filter should be replaced occasionally. There is an exhaust filter under the cover the dust bin sits on. This filter should also be replaced occasionally.
Jun 13, 2014 | Dyson Filter DC7
If the filter is clogged would it quit working
Hi there! If the filter is clogged this will cause the vacuum to lose suction and possibly shut-off. Below are instructions to checking and cleaning your filters.
1. Remove the dirt cup. Twist off the dirt cup lid.
2. Remove the filter cartridge from dirt cup.
3. Separate the foam and cartridge filters. Wash foam filter under running. Allow 24 hours to air dry outside the vacuum.
4. Tap the excess dirt out of Hepa filter. Hepa filter may also be washed. Allow 24 hours to air dry.
5. Check the secondary filter by removing the filter cover from base. Rinse the foam filter under running water until it runs clear. Allow 24 hours to air dry.
6. The red baffle tube inside of the dirt cup is apart of the filtration of the vacuum and needs to be cleaned as well. Twist out the baffle tube by turning 1/4 turn clockwise. Remove any hair or debris wrapped around baffle tube. Baffle tube can be rinsed if needed. Allow to dry thoroughly.
If the filters are too dirty they may need to be replaced. With regular maintenance the filters should be replaced about once a year. Follow the links below to order replacement filters for your UH20020.
Primary Filter
Exhaust Foam Filter
Hope this helps!
Jun 12, 2014 | Hoover Nano Cyclonic Compact Bagless...
How many filters does a dyson dc07 have
Hi there, the DC07 has 2 filters. A pre motor washable filter and a post motor filter which will be either a simple pad (like thick cloth) or a Hepa filter (about and inch thick with a plastic housing). The post motor filter should not be washed but the pre motor filter can. As a technician I would recommend replacing every couple of years for best running of your vacuum. The post motor filter is under the clear bin, you can lever the cover off with a small flat blade screwdriver. The washable filter is to the right of the post motor filter inside a removable housing.
Feb 08, 2011 | Dyson DC07 Bagless Upright Cyclonic Vacuum
Can not get filters
While you are looking for a new filter, you could do this(as written in the instruction manual):
1. Hold the HEPA filter
by the edges and vigorously
"TapClean" the HEPA Filter
dirty side down on a hard,
flat surface until no more
dust is observed falling out
from between the pleats of
the filter.
2.
We recommend washing the HEPA filter
once a month or when suction
appears to be reduced. Let the HEPA
filter air dry completely for 24 hours.
3. Rinse the non-woven pre-filter and let
it air dry completely for 24 hours.
4. Insert the non-woven pre-filter.
5. Reinstall the HEPA filter in the
vacuum.
Have a good day.
GB
Nov 06, 2010 | Euro-Pro EP602 Bagless Stick Cyclonic...
How do I remove the filter to wash it?
Hi There,
Here's a step by step guide on how to clean the filter on your Dyson DC07.
Turn power off and unplug the machine.
unplug_us.gif Step 1
  • Press the release button and remove the filter housing from the machine.*
remove_filter_house.gif *The post-motor filter located under the clear bin should last the lifetime of the machine and does not need to be washed.
Step 2
  • Remove the filter from the housing. (Only the blue foam, yellow cage and white cloth should be washed.)
Step 3
  • Wash in cold water only. Please do not use detergent on the filter, or wash the filter in a dishwasher or in a washing machine.
  • Repeat the steps shown below until the water runs clear.
wash_filter.gif The filter should be washed at least once every 6 months.
  • Leave to dry in a warm place for 12 hours. DO NOT dry the filter inside a clothing dryer, hair dryer, microwave the filter, place the filter in an oven, or near a naked flame .
  • Ensure the filter is completely dry before replacing in the machine.
It is VERY important to make sure your filter is 100% completely dry before reinstalling it into the vacuum cleaner. Running the machine with a damp filter can cause permanent damage to your motor, or cyclone assembly.
What some people do is purchase an extra washable filter, this way they can easily swap filters when they need to be washed, preventing any wait time while the filter drys. Also after a few washing you'll notice the filter starting to deteriorate, sooner or later you'll want to replace the filter. Here's a link to the filter on our site if you'd like to get an extra one.
Dyson DC07 Replacement Filter Part No. 904979
I hope this helped you and answered your question. If this was able to answer you question, please be so kind and rate my repair helpful, or leave feedback for me. If you still have some questions, please feel free to use the comment field on the repair page, and I'll be more then happy to answer any follow up questions that you may have.
Thanks very much,
Chris Jones
GoVacuum.com
May 06, 2010 | Dyson DC07 Bagless Upright Cyclonic Vacuum
Cleaning the filters
There are 3 different filters on this particular model. Two of them are foam, and as washable, the 3rd is a HEPA filter that's located on the back and is not washable, but needs to be replaced once a year.
The most important filter, and the one that most people are not even aware of, is located directly underneath of the dirt cup. Directly under the dirt cup you'll see a black tray that says "pull". Pull this tray out, and you'll find a square shaped washable filter. Simply remove this filter and rinse it under water until it's clean. Make sure to let the filter completely air dry before reinstalling it in the vacuum and using the vacuum again.
The second foam filter is located directly above the dirt cup. Remove the dirt cup, and in the clear plastic housing that's directly above the dirt cup you'll find a circular colored plastic piece. Reach your hand up there, and unscrew this plastic part while pulling downward. You'll find a circular shaped filter that wraps around this plastic piece. This filter may also be washed the same way as the square shaped one, again just make sure that the filter is completely dry before using the vacuum again.
The HEPA filter is actually on the back of the vacuum in a grate that pull down to open it and remove it. This filter needs to be replaced only, and can not get wet.
The foam filters can be washed several times, but will sooner or later need to be replaced, as they will start to deteriorate after a few washings.
If you need to purchase these filters, here are direct links to all of the filters on your vacuum cleaner.
Square Shaped Pre-Motor Filter Bissell Part 203-1073
Circular Shaped Bissell Upper Tank Filter 2031085 Pre-filter Lift Off Series
Bissell Style 8 & 14 HEPA Media Post Motor Filter Part 3091
Here's a link to the parts diagram for your model also, this will help you locate the 3 filters.
http://lib.store.yahoo.net/lib/vacuumcleanerbacgs/bissell-lift-off-revolution-parts-schematic.pdf
Also, here's the link to the owners manual for your model as well:
http://lib.store.yahoo.net/lib/vacuumcleanerbacgs/bissell-lift-off-revolution-owners-manual.pdf
I hope this helps you,
Chris J.
GoVacuum
Apr 09, 2010 | Bissell 37604 Lift-Off Pet Bagless Upright...
It just quit
I took it apart and cleaned it a little and put it back together and it works.
Jul 21, 2008 | Euro-Pro Shark EP366 Handheld Vacuum
HEPA Filter
http://geeksquad.fixya.com/ThreadView.aspx?prdid=618630&thid=730623
HEPA Filter
Posted by jenski66 on Jul 02, 2008
My vacuum came with a sponge over the filter and the directions said I could wash the filter. Do the directions mean to wash the black sponge or the actual filter? Is the sponge part of the filter or is it trash?
Filter F27
Dirt Devil Purpose Cleaner for Pets
Upright Bagless Vacuum
Model #1LY2108-000
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. Typically the top filter of which is the sponge is washable but the HEPA filter is not, it can be brushed off and vacuum off with another vacuum, but the best filtration is to replace the HEPA filter and to wash the sponge filter, if the sponge filter get to bad then replace the sponge filter as well. Or, you can check with your local vacuum cleaner dealer in your area or to contact the manufacturer’s website and or phone #. So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
http://royalvacuums.com/ Customer Service 1-800-321-1134
Hours are: 8:00 AM to 7:00 PM (EST)
Thanks, Don the Vac Man
Go Ahead. Use Us.
Jul 02, 2008 | Dirt Devil 12 Amp HEPA Filter Vacuum...
Euro-Pro Shark EP366 Handheld Vacuum Logo
61 people viewed this question
Top Euro-Pro Vacuums Experts
Dennis Key
Dennis Key
Chris Hall
Chris Hall
Are you an Euro-Pro Vacuum Expert? Answer questions, earn points and help others
