Compaq presario power button not working
I have the Presario CQ57 (Compaq Laptop). The power button on the laptop is non-responsive when pushed. This is both with the battery and AC adapter attached and also tested seperately. I tried the trick of taking out the battery and unplugging the unit and waiting 90 seconds while holding down the power button but the laptop will still not come on when the power button is pushed. However, I can randomly click keys on the left side of the keyboard and it will magically turn on. However, the power button and the light are not on or working. Any suggestions? WOuld much rather use the power button than randomly bang on the computer keyboard to get the computer turned on.
tom19511
  • 1601 Answers
SOURCE: Compaq Presario 2100, remove keyboard
Here you go
All you need is here.
http://h10032.www1.hp.com/ctg/Manual/c00246219.pdf
Posted on Oct 23, 2007
  • 188 Answers
SOURCE: Compaq Presario 700 won't power on
These are prone to broken power jacks that short out components on the mainboard. My shop saaw a lot of these come in dead like this and sometimes we could get them going again with a lot of mainboard work, but it seems they keep breaking.
I would save your money for another laptop considering the lousy reliability record these models have.
Posted on Dec 26, 2007
mailtoravi
  • 186 Answers
SOURCE: compaq presario v6000 laptop keyboard malfunction
Try reseting the BIOS to its defaults by following the instructions below :
Start or restart the Notebook and start tapping the F10 key immideatly you see the HP logo.
Now, in this press the F9 key to load the BIOS Default settings.
Press the F10 key to save the settings and exit the BIOS setup window.
Additionally, check by connecting any USB Keyboard to the Notebook if available.
Additionally, find the Product Number of the Notebook which is indicated with P/N printed on a white sticker pasted at the bottom of the notebook.
Open HP.com and enter this in the search field at the top right column.
Click on Software & Driver downloads and select the Operating System in the Notebook which should be Vista.
Scroll down to find BIOS under which you will find the BIOS Updates available for your Notebook.
Download and save the latest BIOS Update available.
Close all the windows and applications and double click on the file to update the BIOS.
Donot attempt to access any application or turn it off or restart when the BIOS is being updated as this will damage the BIOS Chip and make the Notebook useless.
The Notebook will restart automatically after the BIOS is Updated.
Hope this helps...
Posted on Aug 14, 2008
leecom72
  • 4806 Answers
SOURCE: How do I replace a Compaq Presario V5000 laptop keyboard?
You need a flat bladded thin screw driver to prise off the long cover the runs along the top of the keyboard and just below the screen. Make sure you remove any screws at the back of the screen hinges, and along the top above the battery housing (you need a small posidrive screwdriver for this). You will find there is a screw on the underside of the laptop that holds the keyboard in place from underneath, plus two or three very small screws on the top at the screen end. When all the screws are removed you can lift the keyboard up from the screen end and pull (gently) away from the touch-pad end. Tilt it up and you will see the keyboard data ribbon, don't twist it or pull it as you will damage it.
hope this helps
Posted on Nov 13, 2008
  • 77 Answers
SOURCE: Laptop turns on and then off in a matter of seconds.
hiya
as you say you extended the warrenty then this shud still be covered regardless if they still make it....
Rik
Posted on Feb 26, 2009
Presario CQ57 model compaq laptop Widows could not update the computer's boot configuretion. Installation can not proceed. solve this problem tips
Sounds like you will have to re-attempt a clean install from a Windows installation disk. Unfortunately, the disk will need formatted. You can use a recovery or boot disk to do so.
Apr 07, 2014 | HP Compaq Presario CQ57-229WM Notebook PC
Compaq Presario Cq56
If you are looking for the device drivers for this laptop then -
You can download the device drivers from the Compaq/HP WEB support/download page. Make sure you select your model laptop and the Windows drivers you require and install them. Click on this link to download the drivers: -
www.compaq.com/country/cpq_support.html
Mar 23, 2013 | Compaq Presario Cq57 Notebook Pc
Compaq presario CQ57 windows failed to start
Double check that there is power (no joke). Press power button and if you get a response tap F8 many times. If you get a screen then select "Last known good configuration". If you get nothing then it may be time for a shop visit.
Jan 12, 2013 | Compaq Computers & Internet
Compaq presario cq57 keyboard wont work
Hi ,
Yes it can , If you know what your doing , open the laptop up to expose the keyboard , then clean and dry the keys very well and put it back together , let me know what happens ,,,,,,Goodluck Roy
Oct 30, 2012 | HP Compaq Presario CQ57 Laptop AMD DC...
How do i toggle the mouse pointer on my compaq presario cq57?
Usually on the Presario models there is a very small button just about the mouse trackpad that will disable and enable the use of it. It's usually between the trackpad and the keyboard
Aug 02, 2012 | HP Compaq Presario CQ57-229WM Notebook PC
How to replace cq57-229wm screen
HI,
On amazon you can purchase display for affordable price
Amazon com cq57 229wm screen. Take a look, but be awero... read reviews first.
regards
Mark
Jan 31, 2012 | Compaq Presario, Compaq EVO, Compaq...
Computers & Internet Logo
David Payne
David Payne
