Question about Mitsubishi HS-U446 VCR
Mitsubishi hs-u446 e4
What does E4 on the display mean and can it be fixed
SOURCE:
nfandres
  • 168 Answers
SOURCE: How do you connect the VCR Mitsubishi HS-U446 to record a TV show?
Usually the standard color coding for those connections are yellow, red and white. Yellow for video, red and white for audio left and right if it is stereo. Also pay attention on the the label of your vcr if it is input or output. You need need to connect it from output of your vcr to the input of your tv set. TV have also the same color coding. By the way the cable you use for this purpose is what we called RCA, which is also color coded. good luck!
Posted on Feb 26, 2007
jackboy
  • 2985 Answers
SOURCE: Error message E4 and stuck tape
Yes with care. Simply remove the cover and with care unwrap the tape. If you must break the tape - but make sure all residual tape is cleanly removed. Re assemble and put a tape head cleaner through- following the instructions.
Posted on Jun 22, 2007
  • 158 Answers
SOURCE: is it digital? will I need a converter box?
The conversion to digital affects off air reception. Since you have Comcast analog cable, you will not be affected until Comcast decides to discontinue analog cable, which is not likely any time soon.
When that day comes, your old VCR will probably grace a landfill anyhow, and you will need a converter box from Comcast.
Posted on May 13, 2009
  • 296 Answers
SOURCE: Error code E4
Hi, The error E4 means Reel Lock Detection.
Thanks! mannu_rakesh
Posted on Sep 02, 2009
SOURCE: mitsubishi black diamond E4 fault
your VCR has a problem with the drive belt CAPSTAN, maybe is broken or fallen, you have to take it apart and check that the band is in order
Posted on Mar 11, 2011
E4 error means
What manufacturer and model number is it?
When do you see E4 displayed? Where?
Can you tell us what you have done prior to seeing E4 that might relate to the cause?
https://translate.google.com will help you translate into English if needed.
Mar 08, 2018 | Heating & Cooling
My Teka DW7 57 FI VRO2 dishwasher shows the error code E4.
E4 means it is overfilled because of too much inlet water. Turn off the main supply. Remove excess water from the base pan and restart the dishwasher. DW7 57 FI Teka official website Bathroom Kitchen Professional Kitchen and...
Apart from using the manual instructions, you can get technical help from the company directly too.
Hope this helps!
May 15, 2016 | Dishwashers
I have an AUX air conditioner showing an E4 error on the LCD display. The model is ASW-H18B4/HS. Do you know what this error means and can it be fixed?
E4 aux invertor model ASW22DI-LH problem solution that indoor motor connection problems and indoor motor falty.
Mar 12, 2015 | Heating & Cooling
Error code E4 is on our display of our KDW243A dishwasher - what does this mean please?
Error code E4 means there is an overflow. Water is probably trapped. If you get error code E4, just tilt the machine back about 45 degrees and let the water drain out. It should come out on both sides. Then, you should be good to go.
Dec 14, 2010 | Kenwood Dishwashers
Disherwash is showing e4 what does it mean
The E4 error is not usually associated with newer dishwashers. Older Kenmore dishwashers with digital displays would show an E4 error when the selector switch pads/buttons were stuck. You need someone In to look at it im afraid
Sep 25, 2010 | Kenmore 15762 Dishwasher
I have waves split air condition its cooling is good but some time in the display e4 is coming and that time my ac is not giving cold air what is this.tell me some one.
The e4 that displays on your air condition come up simply because there is an error during the operation of the system. E4 means Error 4 which is a code that is interpreted as low pressure switch.
E4 simply means there is low pressure switch, the pressure switch turns on automatically inside the air condition, so when you turn it on sometimes the switch jams and does not open so the air condition will be on but would not get cold because the switch jammed and it displays an error signal to let you know there is a problem in the system.
Take care
Jul 09, 2010 | Heating & Cooling
My Wolfgang Puck pressure cooker shows 'E4' in the display.
There doesn't seem to be any legit way of fixing this. I tinkered with the pressure sensors and valves, kicked the pressure cooker a few times, still the E4 error presented itself.
I was able to bypass the E4 error by completely bypassing the electronics and wiring the heater coil to get power whenever the pressure cooker is plugged in. It was a very simple job, anyone with any electrical experience can do this.
The only problem is that it is a safety concern as there is no way for the heater to turn off even if pressure is getting to be way too high. There may be a pressure relief valve in the lid but the heater coil won't shut off, so don't leave it unattended! But at least this way to you can still pressure cook.
Pics of process:
http://s909.photobucket.com/albums/ac295/danwat1234/fixing%20the%20pressure%20cooker/
May 10, 2009 | Wolfgang Puck 5-Quart Electronic Pressure...
Base unit displaying E4 after we experienced a power black out
e4 error code that means it ihas defective base unit. it happened due to a spike in the power lines that may cause this error
Feb 09, 2009 | Uniden 5.8GHz Cordless Phone
Unit shuts down
The E4 error in display its mean the wire sensor connector to thermostat is loose pls fix , or have a problem in PCB Board on thermostat, pls go to the nearest repairman to repair that.
Thank you,have a nice day
Edgz
Jan 22, 2008 | ACE -Air 18,000BTU Heat Pump A/C Free DVD...
Mitsubishi HS-U446 VCR Logo
48 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
