Question about GE Profile 30" Self-Cleaning Freestanding Double Oven Gas Range - Stainless-Steel
GE gas range JGBP80MEV4BC control panel not working
The control panel doesn't work. Is there a lock out feature for this model? The panel doesn't have a number keypad.
SOURCE: Buttons on Control Panel not working for my GE Profile Gas Range
Anyone has any information as to how to fix my describe problem with GE Profile Gas Range I have.
Thanks
Posted on Mar 17, 2008
  • 3 Answers
SOURCE: Oven wont light
Mine did that and I found the ignitor for the oven was bad. It was the "glow" type for pilotless ignition and it was burned out. It is supposed to glow bright red and the gas comes on and the oven will light. It was easy to tell that it was bad. But to check it I swapped the broiler ignitor with the oven ignitor and the oven worked.
Posted on Dec 20, 2008
jumptrout51
  • 3361 Answers
SOURCE: ge gas range - the keypad is blank and does not beep.
You will have to replace the electronic control.
Posted on Feb 21, 2009
SOURCE: GE Spectra XL44 Gas Kitchen Range - suddenly only top works
where do I find the pilot light?
Posted on Jul 04, 2009
jumptrout51
  • 3361 Answers
SOURCE: GE gas oven not working
You have a stuck or shorted keypad. Replace the clock control.
Posted on Jul 22, 2009
Gas range digital display reading too hot
If you haven't tried to reset (unplugged the electricity) try that, if it doesn't work, check GE's site. have your model number ready
Aug 11, 2012 | GE Kitchen Ranges
My GE xl44 gas range broiler won't work,
The ignitor is not working right and is going bad....
have the repair man replace the ignitor, or DIY....
Check out this tip about your problem...
Oven not Working or Oven not Heating
Oven Problems Replacing the Igniter
heatman101
Jun 02, 2011 | GE Profile JGB900 Gas Kitchen Range
Our GE profile oven model JGsp31wet1ww oven will not heat up. When i set the oven to say 400 degrees, it just stays at 100 and never heats up. The broiler seems to work fine and the stove top gas burners...
pull out the racks and remove the bottom floor of the oven,turn it on bake,if the ignitor doesn't glow most likely it's bad,if it does glow and it doesn't ignite within 40 to 60 seconds the ignitor is bad.even though it glows doesn't mean it's good,it works by amps.it takes 3.2 amps.for a flat ignitor to open the gas valve and 2.5 amps for a round ignitor to open the gas valve.
May 15, 2011 | GE Profile Spectra JGBP90 Gas Kitchen...
Purchased GE Profile dual fuel range 6 months ago. Clock has always run fast and today the entire touchpad control went dead. The oven light works as does the gas burners. I am not sure if I inadvertly...
Unplug the unit and wait 2 FULL MINUTES before plugging it back in. That will reset the circuit board and you should be good to go. If it doesn't work, my bad!!!!!!
-AGK
Apr 17, 2011 | GE Profile JGSP44 Dual Fuel (Electric and...
Ge gas stove display reads loc ref and no buttons work just replaced controll board
The keypad is "locked", hold down the button to remove this (usually "clear") for 5 seconds. Look closely at the buttons, one of them will have a picture of a padlock near it. That's the button that clears the "lock" condition. It's a safety feature to keep the kids from turning on the oven.
Aug 05, 2010 | GE Profile JGS968SHSS Gas Kitchen Range
My GE Spectra gas oven worked fine last night. Today, the oven will not heat. The broiler and the burners work fine, as does the clean feature. But nothing when the oven is turned on.
Are you sure the cleaning process works, because usually when the oven wont work, the clean process wont work. If you are correct, then the problem is most likely the control panel not responding to the bake setting. This will require either a new touch panel or a new control circuit board.
Oct 11, 2009 | GE Spectra JGBP35 Gas Kitchen Range
I have a spectra gas range and the broiler works but the oven doesn't. When I turn the oven on the middle light blinks but oven won't light, what's wrong? Model#348A8035P017
Mar 30, 2009 | GE Kitchen Ranges
Thanks
Mar 14, 2008 | GE Profile Spectra JGBP79 Gas Kitchen...
Lighting the oven
Control Lockout (on some models)
Your control will allow you to lock out the
touch pads so they cannot be activated when
touched or cleaning the glass panel.
To lock the controls:
Touch the 9 and 0 touch pads at the
same time for 3 seconds until the
control beeps twice. The display will
show LOC continuously and the time
of day if not blacked out.
NOTE: All cooking and timing functions will be
cancelled when locking out the control.
To unlock the control, touch the
9 and 0 touch pads at the same time
for 3 seconds until the control beeps
twice, and LOC will be removed from
the display.
NOTE: Some models have a Control Lockout
pad. Touch and hold it for 3 seconds to
lock/unlock.
Gas/Control Lockout (on some models)
surface burners, oven burners and control
panel so they cannot be activated.
To lock/unlock the controls:
Turn all surface burners off.
Touch and hold the Gas/Control
Lockout pad for 3 seconds until the
display shows LOC ON.
To unlock the control, touch and hold the
Gas/Control Lockout pad for 3 seconds
until the display shows LOC OFF.
When this feature is on and the touch pads
are touched, the control will beep and the
display will show LOC ON.
 The control lockout mode affects all
controls. No controls will work when this
feature is activated.
 The adjustment will be retained in memory
after a power failure.
Nov 30, 2007 | GE Profile Spectra JGBP90 Gas Kitchen...
GE Profile 30" Self-Cleaning Freestanding Double Oven Gas Range - Stainless-Steel Logo
74 people viewed this question
Top Kitchen Ranges Experts
Ismael Rodriguez...
Craig Butler
Craig Butler
Sal De
Are you a Kitchen Range Expert? Answer questions, earn points and help others
