Question about Yamaha RX-V596 Receiver
Yamaha RX-V596 Receive turns off after pressing Power
Hello. I have a Yamaha RX-V596 Receive which has been a pretty great machine. Everytime I try to power it up it stays on for a few seconds then turns off. Any tips how to solve this problem? Thanks Stephen Thompson [email protected]
  • Anonymous Mar 14, 2014
    my Yamaha home cinema rx-1067 is only showing stnby when I press power bttom
  • 4 Answers
Sometimes the receivers turn off if the speakers are shorted in order to protect the AMP circuit. So try this - 1. Disconnect all cables (speakers), inputs from Tape Deck, VCR and other input devices), sub-woofers, rear speakers all. Except the AC power cord. Then turn it ON and see if it stays on. If it still has the same problem, then most probably your power circuit inside the receiver has a problem - like a shorted Capacitor or diode etc. Based on how technical you can be and what resources and time you want to spend, this is repairable. But based on the price of a receivers these days, it is not worth. Good Luck!
Posted on Sep 01, 2007
SOURCE:
I have had my Rx-V596 receiver for years and just last week I started hearing a constant humming thru the speakers regardless of what input source is selected. I have checked all the cables and can not...
Most likely suspect is a breakdown of a capacitor, probably in the power supply -- one of the few modern electronic components that go bad over time. You'll probably need a Yamaha service center to get it fixed -- they'll give you an estimate before starting, but it may be a better investment to upgrade to a new receiver. It takes a skilled tech to fix this at the component level -- doubtful that replacement boards are available.
Feb 02, 2018 | Yamaha RX-V596 Receiver
How do I hook up my Panasonic sc-bt230 Blue ray to my Yamaha receiver rx-v596
What exactly are you trying to accomplish?
Register and download the manual for free at retrevo.com
http://www.retrevo.com/support/Yamaha-RX-V596-Receivers-manual/id/320ag000/t/2/
Register and download the setting guide for free at hifiengine.com
http://service.us.panasonic.com/OPERMANPDF/SCBT230%20EZ%20SET%20UP.PDF
Feb 14, 2011 | Audio Players & Recorders
My yamaha rx-v596 makes a clicking sound but does not turn on
If it clicks twice almost instantly (on then off within 1/2second) then its got a serious power supply imbalance.
If it clicks on then 5secs later clicks off then one of the amplifier channels has probably failed and the protection circuit is tripping it off to protect itself.
either way its a repair shop job I'm afraid
Jul 16, 2010 | Yamaha RX-V596 Receiver
Can an ipod or mp3 player be hooked to a Yamaha RX-V596, using an auxliary cord
Typically you can find an adapter / cord that contains a 3.5mm headphone plug on one end and a pair of RCA plugs on the other. These RCA plugs should be able to be plugged into any available input on a receiver that isn't a PHONO input. These cables can typically be found online at various different places. Not to promote one site over another, but I have had good luck finding random cables like these at Cableswholesale.com and allelectronics.com. Hope this solves your problem.
Thanks,
Ben
Mar 29, 2010 | Yamaha RX-V596 Receiver
Is the Yamaha RX-V596 capable of using HDMI in
Nope. Use S-Video or composite video In and digital audio in from the Cable Box, S- or composite-video out to the TV/Monitor.
OR (what I do) skip the receiver as a video middleman and take the HDMI video right to the TV; and run the Cable Box digital audio to the Receiver.
Feb 18, 2010 | Yamaha RX-V596 Receiver
Memory guard on
Hi Rocco
I too have searched the user manual on this unit, and have not found any reference to "memory guard". Can you give me more information about the feature you are trying to operate and I will try to assist you further
Here is a link to a PDF version of the manual for free. Just enter an email address and there you go.
regards
Graeme
Feb 16, 2008 | Yamaha RX-V596 Receiver
Hooking up this receiver
I don't see why not. I have a 46" Sony Bravia HDTV that I have hooked up to my RX-V596.
Just use either the RCA out on your TV to the "TV " RCA audio in on the receiver, or if your TV has Optical or Coaxial Audio Out use those...
Dec 27, 2007 | Yamaha RX-V596 Receiver
RX-V596 center and rear channels do not have any sound
Nevermind... My center channel output was set to "NONE" I've had this receiver for a few years now, probably set it that way back when I got it. Oh well, Helps to re-read the user manual...
The info is in the "SET MENU" section of the manual, Pages 35-38. Should solve the issue for "almccrum" above as well.
If you don't have your manual it can be downloaded here:
www2.yamaha.co.jp/manual/pdf/av/english/re/RX-V596.pdf
Oct 06, 2007 | Yamaha RX-V596 Receiver
Input selector on my Yamaha RX-V596 stuck
Hi Dush
Sounds like the processor has locked up in the unit. Try powering it right down from the wall socket for a day to reset, and then retry operation. If that does not work, leave it disconnected for about 10 days to erase backup memory completely and then try again. Good luck. Don't forget to give me a "FixYa" rating if this works. If it doesn't, get back to me in here and we can talk more about it.
regards
Graeme
Sep 16, 2007 | Yamaha RX-V596 Receiver
Yamaha RX-V596 Receiver Logo
500 people viewed this question
Top Yamaha Audio Players & Recorders Experts
 Grubhead
Grubhead
Colin Stickland
Colin Stickland
Are you a Yamaha Audio Player and Recorder Expert? Answer questions, earn points and help others
