Question about DeLonghi Heating & Cooling
Ct110 water leaking and it is showing an error code. will not re-start
My 110cc vuka scooter it is starting but the moment i press the gear lever it dies
Hi, Godfrey if it's not a safety switch issue then it's a carb issue and the usual suspects are:
1. Idle circuit and transfer ports clogged.
2. Air fuel mixture adjustment too lean.
3. Pilot jet clogged.
4. Faulty accelerator pump.
5. Float level too low.
6. Float bowl contaminated old fuel, water, dirt, rust, etc.
7. Float bowl vent or overflow tube clogged.
8. Fuel flow to carburetor restricted.
9. Intake manifold leak.
10. The gas cap is not venting properly or fuel tank venting system blocked.
11. Vacuum line from intake manifold to petcock broken, cracked, or not attached, carburetor vent line plugged.
12. Needle and seat stuck closed in the float bowl.
13. Multi carburetors not in sync.
For more information about your issue and valuable "FREE" downloads that you will need please click on the blue links below. Good luck and have a wonderful day.
Basic chinese bike troubleshooting guide
Bike idles perfect but dies when given the slightest amount of throttle 93...
http://www.agri-moto.com/images/Parts/Vuka/vuka_xl110_xl125_parts.pdf
vuka xl 110 service manual
HONDA CT110 Owner Manual
http://ct90-ct110.com/PDFs/CT90_%2077-79_CT110_80-82_PDF.pdf
May 14, 2017 | Vuka Motorcycles
I have IFB washing machine it shows E7 error
1:IFB Washing Machine Not Turning ON OR Turns ON But Does not Starts. 2:IFB Washing Machine Door Does Not Opening. DE Error 3: Water is not coming inside the IFB Washing Machine Inlet problem 4:Water is Leaking from the washing machine, drum or hose pipe damaged 5:Wash is not happening / Spin not Happening in the IFB Washing Machine 6:Drum NOt rotating or Drum Making Huge Sound while spin cycle, 7:Water not Draining From the washing Machine 8:Burning smell, Tripping Problem, etc https://electronicshelponline.blogspot.com/
Read more: http://ifbservices-com.webnode.in/error-code-fault-codes/
Aug 05, 2016 | IFB Washing Machines
Dishwasher is showing an 'LE' error code? What does this mean?
LE on a sumsung dishwasher is a "LEak" warning. There is water in the base of the machine. If you tip the machine sideways 45% the water will run out and the machine will start again. This will not however fix the leak! But it will confirm that you have one
Sep 22, 2015 | Samsung Dishwashers
My Beko DW686 Dishwasher displays ER1 Error Code, there are no error codes in the manual, can you help?
reset error code 01. pulled dishwasher out removed kick plate tipped at 45 deg angle and found no leaks or water. turn6ff59c77-7c20-45c4-ac2a-e3c9e6fd4c14.gif breaker off and back on after 20 minutes still doesn't clear.
see tje diagram attached. God bless you
May 25, 2013 | Dishwashers
High Water Level ErrorSamsung DMT300
The parts mentioned, 8058475/SWITCH, PRESSURE and 8058500/HOSE are Asko parts. Samsung should have their own equivalent parts, but the Asko parts should work as well... I think the Samsung parts would be less expensive?
May 13, 2012 | Samsung Dishwashers
I am geting a P1 error code
P1 error code is not enough water flow to operate the unit: increase water flow to unit.
http://waterheatertimer.org/pdf/Rheem-Error-code-P1.pdf
http://waterheatertimer.org/Troubleshoot-Rheem-Tankless-water-heater.html
Error codes are considered start-point for troubleshooting.
Page 18 of maintenance manual shows how to clean water filter monthly.
http://waterheatertimer.org/pdf/Tankless-maintenance.pdf
Other causes can include faulty sensor, clogged in-line filter, clogged water softener, sediment in pipe, sediment at elbow, bad check valve, water leak, etc.
Take a moment and rate answer:
And take advantage of fixya expert assistance live.
For a price, expert works with you while you work on water heater or any do-it-yourself project.
Fixya is always less expensive than a service call.
Sep 11, 2011 | Rheem Tankless Hot Water Heater...
LG 3 in 1 Dishwasher model LD2131SH showing E1, leaks water
e1 is a leakage error. you will have to find where it is leaking from...crack hose .crack motor assy.. water must be leaking
The excessive RPM of Washing Motor happened during Wash cycle due to water leakage.
Water leakage in Hose connections. Water is leaked by damages. The Motor Water Seal leakage of Sump assembly. The height of Drain Hose connection (sink-Drain Hose) is not over 20 . Impeller of the Washing Pump is worn away.
Sep 11, 2009 | LG 24 in. LDS 5811 Built-in Dishwasher
My air conditioner is leaking water and i have lost the ma- CT110
Where is your AC leaking at, can you tell? This is common, but the leak of water should not end up in your house--but outside; this occurs as a result of the failure of your AC tubing or pump. The accumulation of water is a part of the normal process of condensation. Here's a really good diagnostic article that talks about water accumulation and leaking AC systems:
http://yourhandymanzone.com/Your_Handyman_Zone_How_To_Pages_Home_Improvement_Zone_Cooling_Ventilation_Systems_Central_Air_Conditioning_Creates_Water_Puddle.htm
Read the article, and, actually, your best bet may be to take advantage--towards the end of the above-linked article--of the text-link for Free four (4) quotes from local AC contractors in your area (click the link that sasy"Find A/C Contracts. Get Up to 4 Quotes"), and "pick the brain"--seek the advice--of these local technicians who offer you a free quote to discern whether your AC tubing or pump is the problem for your water accumulation.
Aug 07, 2009 | Heating & Cooling
I have a 1981 Honda CT110 Trail 2 wheel motorcycle. I have been working on it and everything seems to be working normal except the idle. It will idle normal for a time and the suddenly rev real high. I...
The problem is an air leak leaning the fuel mix. The idle speed starts going up a ramp until it is wide open. The valves no longer seating well is a possible cause as is carb manifold gaskets, rings and a cylinder head not torqued down tight.
Apr 23, 2009 | 1982 Honda VT 250 F
AEG 50760 Dishwasher shows Error Code 30
there is water in the base of the macine. lean it over to the side to get all of the water out then try again.
Feb 14, 2008 | Dishwashers
Heating & Cooling Logo
18 people viewed this question
Top DeLonghi Heating & Cooling Experts
paulcarew
Donni Steen
Are you a DeLonghi Heating and Cooling Expert? Answer questions, earn points and help others
