Question about Haier Refrigerators
Trf295 refrigerator 2 drawer fronts are broken ice compacting and door not closing properly
  • 2920 Answers
SOURCE: leveling refrigerator
you might lower the front ones to get it level thats the only sloution i can come up with
Posted on Aug 27, 2008
joboo1
  • 257 Answers
SOURCE: Refrigerator Door not closing properly
Hi, No the door is not adjustable like you might think Since it is smaller than the other door any alignment problem is really visible. First do check the bracket to make sure you didn't lose a screw and that the brackets are solid and don't move. The problem is the level of either the refrigerator or the floor. If you have a 3 ft bubble level put in on the top of the refrigerator along the front, NOT on the door. There are feet on the bottom front corners of the refrigerator, you may have to remove the plastic grill to access them but depending on the model and age of your refrigerator it should be attached with clips. The feet screw in and out but with weight they won't move easily so you may have to jack the front a little, remove some stuff or try a crescent wrench. Once the front is level check the front to back, the refrigerator needs to tilt slightly to the rear so the door when partially open will close by itself. Again you didn't give a model so on some the rear feet are not adjustable and some are. I suspect you may have adjustable and the box is not squared up. If after adjusting the front and the entire refrigerator tilts like an uneven table leg then you have to adjust the feet likewise. Use your level diagonally across the top both directions, it should be exactly the same. If you have non adjustable and they are uneven it is the floor and you have to use shims under the low foot. Good Luck!
Posted on Jan 30, 2009
SOURCE: Bottom freezer door/drawer won't close all the way on one side.
Remove all the food from the freezer and then the drawer from the cabinet. Now using a silicone based lubricant, lube the tracks up real well. Be sure to clean the tracks first if gunked up. Make sure nothing small fell out of the basket over time and is laying on the floor in the rear of the freezer section. Once done, you should be fine.
Eric Campion
Posted on Feb 21, 2009
  • 142 Answers
SOURCE: water dispenser on front of refrigerator door does not dispense water. Ice Cube maker continues to make ice cubes. Defrosting doesn't fix problem.
Water dispensing solenoid is bad. You need to replace the solenoid valve. This typically is independent of the ice maker.
Posted on Jun 02, 2009
  • 4793 Answers
SOURCE: KitchenAid Superba refrigerator door not closing
have you adjusted the levelers underneath to make sure f/f is square.use a level on top.
Posted on Mar 06, 2010
Testimonial: "Got it done finally. It was an easy fix and I was planning to hire someone to do it. Thanks."
The freezer has a white plastic back panel with vents to blow the cold air into drawers. That thing pulled away (ice formed behind it) - how to put it back?
there is some ice that has frozen the door in a fixed potion, if you have hair dry put on warm point toward where it hinges other than that call some service person to help you.
you mite call the manufacture customer service dept. ask for service
technician, explain whats wrong and see what they say. it never a bad question, or to ask for help!!
www.ask.com/mfg.name/make/model/customer/service/telephone#/
Oct 06, 2015 | Refrigerators
Why on a whirlpool gold double door refrigerator
That's an easy one, the draw is not in correctly, preventing the door to close properly. Clean up the mess then work with the draw until it seats properly, then double check that the door seals closes right.
Jul 23, 2014 | Whirlpool 25.6 cu. ft. Side-by-Side...
Water is sitting on top of freezer compartment and leaking out on floor
Make sure that your drawer is aligned properly and that there is no ice build up anywhere. Mine built up some ice in the very back and side somehow, and caused the door not to close tightly which lead to a similar problem. Removing the ice build up cured it.
Jun 13, 2014 | LG LFX25960ST Stainless Steel French Door...
My bottom freezer not closing properly
Pull both drawers completely out of their locations, clean off the slides that they each normally rest on. Clean off the surfaces beneath where they sit. Now, if they are both the same width and height, switch them and see if the problem is solved. If not, check the actual drawers to see if their sliding surfaces are cracked or covered with any kind of junk. You should be able to get everything to fit with these procedures.
Jan 12, 2013 | Maytag MFD2560HES Bottom Freezer French...
I have an LG refrig french door model LFX 31925ST/00. Purchased less than 2 months ago. The top plastic freezer door continues to get an ice build up on the front of the drawer only. Is this normal? ...
It sounds like a loose or bad seal on the top area of the freezer door. Use the old dollar bill test to see how good the seal is. Hold a dollar bill up to the seal and close the door. there should be some resistance. compare the resistance between the top and bottom of the door.
Nov 06, 2017 | LG Refrigerators
I have the freezer set at 3. There is ice forming all around the door and snow like frost on the food.
Frost buildup on food and ice around the door is due to warm air infiltration. This sounds like a door closure problem. Be sure that nothing is interfering with the drawer as it closes. Be sure to open the upper door and look down at the drawer top to see that the gasket is hitting the steel frame of the cabinet. Look all the way around the entire drawer front checking the seal.
Also open the drawer and hold it as it closes, so that if there is any food product binding it you will see it get hung open.
Good luck.
Jun 13, 2010 | Jenn-Air JFC2089H Bottom Freezer French...
Ice Maker
sounds like door is misaligned while both doors are closed is the gap even from top to bottom if not than make adjustments top and bottom serews, try to find out whats draging drawers not shutting all the way ect,ect
Apr 22, 2010 | Whirlpool 25.6 cu. ft. Side-by-Side...
Hotpoint FFA70 - Freezer door will not close properly.
The rear panel can be removed,i have done it.I removed the 4 hex head screws from the top & bottom of the panel,and firmly pulled it forward.The reason i say pulled firmly is that when panel came out the back of the freezer was solid with ice.I have defrosted the freezer,dried any water from the unit and replaced the panel.Fingers crossed,so far,so good.In my case this build up of ice was definately the reason the drawers were not sitting in the correct position,as it caused the rear panel to 'bulge' out.Hope this helps.....
Dec 11, 2008 | Hotpoint FFA70 Bottom Freezer Refrigerator
Bottom drawer does not properly close
Okay, I fixed it for now. The design for this bottom freezer drawer is not good. What happened was most likely that my son slammed the door, and it bounced and was slightly open. Overnight, ice started to form all over the compartment, including inside the drawer guides. Some ice was probably obstructing the drawer glide from sliding shut.
What I did, not thinking this was the solution, was to prop chairs against the drawer to close it while I searched for answers on the Internet. In the meantime, some of this ice must have refrozen in the closed position (due to the weight of the chairs). When I went to check it later, I had a little trouble opening the drawer. I gave it a hard yank and some small frost flew off, as I opened the drawer.
It was not easy sliding it due to the frost. I then moved it out and in until it felt smooth, and finally closed the drawer and it stayed in the shut position.
Kids are instructed to close the drawer gently and visually check that it is sealed. There is also an air passage between the refrigerator unit and the freezer so that when you close the double french doors, some air pushed to the freezer section and momentarily pops the drawer open. You should make sure that the drawer closes before leaving the kitchen. If you are on vacation, prop chairs to make sure both the freezer drawer and the french doors stay closed. This is important if you're in an earthquake area as a small tremor could open the doors and you'll get a fire when the lights stay on and burn through the wiring (as others have noted).
Dec 03, 2008 | Kenmore 73502 / 73504 / 73509 Bottom...
Ice building up on top of drawer
Try to defrost the unit until all the ice disappear in the evaporator coil.
Feb 05, 2008 | Jenn-Air JFC2089H Bottom Freezer French...
Refrigerators Logo
16 people viewed this question
Top Haier Refrigerators Experts
John Tripp
John Tripp
doggzzz
Level 1 Expert
Are you a Haier Refrigerator Expert? Answer questions, earn points and help others
