Question about Echo Garden
Excessive Vibration in Echo PAS-230 edger accessory
When I use the edger accessory it began recently having a lot of vibration. It will loosen the nut in which the wheel is loosened and you can feel the extra vibration in the hands as well. I am uncertain why this is occuring as there is no issue with the weed eater attachment (no excessive vibration with that component). Any assistance would be great and extremely appreciated.
  • Echo Master
  • 1,807 Answers
Sounds like the Edger blade is unbalanced/off centre/unevenly worn or loose.
Posted on Jul 27, 2013
5 Suggested Answers
slohry
  • 87 Answers
SOURCE: how to change an old edger blade
Take a pair of vise grips and clamp the blade to a 2X4 for more leverage. Some old edgers had a left hand thread.
Posted on Apr 09, 2009
moretons
  • 155 Answers
SOURCE: do I turn the nut to loosen the blade on a sears
most times it is the opposite way to which it turns.
Posted on Jul 25, 2009
  • 183 Answers
SOURCE: I have a new echo trimmer with attachment series
There isnt anyway to turn the head the other way round as its ment to run that way just go round the edges the other way
Posted on Jul 31, 2010
dave_gold
  • 38 Answers
SOURCE: Describe your Poulan/Weed Eater No.
I found the manual for this model weed eater, according to the manual the mixture...
and I quote "This engine is certified to operate on unleaded gasoline. Before operation, gasoline
must be mixed with a good quality synthetic 2-cycle air cooled engine oil designed to be
mixed at a Ratio of 40:1 ...."
and I quote once more from the manual "Helpful Tip. To obtain
correct oil mix ration, pour 3.2 ounces of 2 cycle synthetic oil into one gallon of fresh gas."
Hope that helps,
If you like I can send the manual via email if you need it.
:) happy weed thrashing
Posted on Aug 12, 2011
How to release harley handle vibration?
All v twins have an inherent low vibration. It's what makes them great. If you're asking how to minimize the vibration, aftermarket poly dampers are available to replace the mounts where the handlebar mounts to the tree. There's heavier, softer handlbar grips that make a huge difference, wearing gloves help. If excessive vibration is something that recently appeared you should check your front wheel balance, engine mounts, etc. A good front wheel inspection and balancing should help.
Oct 28, 2014 | Motorcycles
There's excessive vibration on my TB70SS trimmer. What can I do to correct this?
common with these units is the spindle drive gets damaged causing it's rotation to be off set and causing vibration, look for marks on outer casing around central spindle joint . also check the line holder has not been damaged causing to be offset .worn shaft bearings can also cause this problem.
Jun 26, 2014 | Troy Bilt Tb70ss Gas Trimmer
Vibration on 02 dyna wide glide
check your motor mount bolts. my top motor mount bolts had loosened and caused a lot of vibration until re torqued.
Mar 15, 2013 | 2002 Harley Davidson FXD Dyna Super Glide
My MYD edger breaks off the adjustment rod any fixes
I've broken two of them. I had a lot of vibration, and the blade was bent. I'm replacing the rod and the blade to hopefully fix the problem. If it breaks again, and I still have the vibration, I'll look at replacing the belt and possibly the pulleys.
Feb 10, 2013 | Mtd Garden
LG WM0642H washer "excessive" vibration
sounds like damper rods are getting worn. they support bowl underneath.i think if u change them it should fix problem. is it noisy during spin?if u need more help please reply. please turn power off b4 working on it do not want any accidents.
Apr 08, 2010 | LG WM0642H Front Load
I have a CRF100 and it has excessive vibration
Make sure all of the engine mounting bolts are tightened properly. One loose engine mount bolt can cause exactly what you are describing. While you're doing that, perform a visual inspection of the attachment points on the frame, making sure there are no visible cracks.
Aside from that, just stick a wrench on every bolt and nut on the bike that you can see - and make sure everything is tight.
The only other possible thing I can think of would be a loose flywheel on the crankshaft. Unlikely, but check just to be sure.
Nov 30, 2009 | 2005 Honda CRF 100 F
Excessive vibration
check for bearings fault,ie open door and lift inner chrome drum up and down if you feel a knocking feeling or you ear this then its the bearings
Jul 06, 2009 | Bosch Nexxt 100 Series WFMC1001UC Front...
Vibration that I hear and feel in shaft after trimmer warms up
Sounds like the drive shaft may be broken or weak in one spot. When it heats up, the metal becomes softer, causing the vibration. Have you had the drive shaft off recently?
Jim
Jun 14, 2009 | Husqvarna Garden
Excessive vibration of the steering column
Sound more like out of balance tires, or bent wheel. Unless this vibration is even in park. Then I would say something is up against a part of the steering that shouldn't be.. Or your exhaust system is bent or touching part of the undercarriage that it shouldn't be. Was the car ever wrecked?
Mar 28, 2009 | 1990 Toyota Camry
80 Series top loader excessive vibration and noise on spin
check the screw feet, on the front corners, one may be not screwed down far enough to be 'tight' to the floor allowing a small movement that makes a lot of noise, halting under pressure suggests this is the case
May 26, 2008 | Kenmore 24032\24036 Top Load Washer
Open Questions:
Garden Logo
194 people viewed this question
Top Echo Garden Experts
Jim Parker
Jim Parker
Jim London
Jim London
colesmowers
Are you an Echo Garden Expert? Answer questions, earn points and help others
