Question about RCA Audio Players & Recorders
Can't get the speakers off my casset player #RP7950B
How can I get sound from my radio
If a cable speaker is shorted to ground or (in your case) the short was on the casing the radio mutes the output to save the amp. So
remove all cables and put them back to the radio & connect the speakers one by one to see if it works or mutes again
Sep 30, 2016 | Jensen Jta-475 Cd Player /turntable...
My HD350 Technics audio set consistent of four Parts:ST tuner, SE amplifier, SL CD plager, RS cassetteplayer wicht are connected via a flat broad cable. It goes from tuner to cd to cassette. Now my cassete...
Please don't cut a cable, You won't be able to repair it. There must be a way to lose the cable without cutting. I forgot, but I will search around. When I find something I'll come back on this.
Jan 18, 2015 | Technics Audio Players & Recorders
1991 toyota carolla seca cs limited head unit wiring colour codes
Radio Constant 12V+ Wire: Blue/Yellow
Radio Switched 12V+ Wire: Gray
Radio Ground Wire: Brown
Radio Illumination Wire: Green
Left Front Speaker Wire (+): Pink
Left Front Speaker Wire (-): Purple
Right Front Speaker Wire (+): Purple
Right Front Speaker Wire (-): Light Green
Left Rear Speaker Wire (+): Black
Left Rear Speaker Wire (-): Yellow
Right Rear Speaker Wire (+): Red
Right Rear Speaker Wire (-): White
May 25, 2012 | 1991 Toyota Corolla
Can the casset deck be changed to a CD player
Yes, you have to change the whole din unit, most units support ISO (standard wiring) an autostore will explain this more clear.
Dec 01, 2010 | Car Audio & Video
Car speaker wont work
kindly check teh wiring and get the player serviced it might help u
Sep 10, 2009 | Car Audio & Video
Cd's stuck in cd player
take the disc cassete out and make sure all cds are strait,if cassete not coming out disconnect the unit take off couple scres on top,the lid will come of and then take out the cd cassete and chech if everthing strait and if theres no cd stuck half way in the player it self,if my info was at any help please comment ,thankyou
Aug 27, 2009 | 2004 Mazda 6
Top RCA Audio Players & Recorders Experts
Gyula Lacz
Are you a RCA Audio Player and Recorder Expert? Answer questions, earn points and help others
