Question about Lowrance LCX-15MT GPS Receiver
Tried to upgrade the mmc card for puget sound and somehow everything got erased so i need to find a way to reload it back onto the chip
Photos are accessible on the camera but not on the chip to download. how can i get them onto the little chip?And how did this happen? I've taken 100's of photo's and just pulled out the chip, plugged it...
If , when you pull out the memory card, you don't use the "safely remove hardware" function, you run the risk of corrupting the card. If you use the computer to erase the card, you run the risk of corrupting the card and causing it to not work properly in the camera. If your pics are safely downloaded into your computer, try formatting the card in the camera to get it to work again.
Mar 07, 2010 | Nikon COOLPIX P90 Digital Camera
The buit in sd/mmc card is not able to read on dell inspiron 1525
Try to do system restore,
If that doesn't work download the latest driver for that built in card reader then install it,. if it still doesn't work run the hardware diagnostics of the computer then if it passes without any error you'll need to do operating system reinstallation so that means erasing everything in the computer,.. If that doesn't solve your problem get that card reader replaced.
Hope this helps!
Feb 08, 2010 | Dell Inspiron 1525 Notebook
I have a R4 upgrade revolution for ds card which was working fine.all of a sudden it is getting stuck on the loading screen.i tried formatting the card a putting the files back on which i had saved to my...
First wipe the micro card clean ... get rid of everything... then go to the r4 website and download the latest kernel/firmware for the device. Reload everything back onto your card ... this should fix the problem ... My nephew dorked his card up and I couldn't even delete any of the files from the card. I had to format the card to fat 32 wipe it clean and then reload all the software onto it .. fixed it right up ... hope this helps ...
Jan 12, 2010 | Nintendo DS Console
We insert a memory chip into our Kodak EasyShare C190 camera. The read-out informs us that the memory card requires formatting. We click on "OK." The camera goes into a "formatting" mode, then informs us...
Your camera is only supporting SD/MMC Cards (up to 2 GB) and KODAK SDHC Cards (up to 8 GB).
The card that you currently have might be faulty. Please try another card.
You might also need to switch the camera over to saving pictures directly onto the SD card.1: Menu, Cam settings, Chose AUTO or SD card option Press OK
Note: If the SD card isn't in the camera or is unreadable the camera will automatically go back to saving you taken pictures on the internal memory.
Jan 04, 2010 | Kodak Easyshare C190 12MP Digital Camera...
XP not able to download songs onto MP3
When using XP and media player 10, your mp3 player has to be in MTP mode to transfer music, you can't do it in USB mode. If you have already tried in USB mode you'll be beter off clearing the memory and starting over (you'll have to reload your music after you are done).
  1. Plug the player up to the computer using the USB cable.
  2. Close out any pop ups that open. If they won't close ignore them until you are finished.
  3. Double click the My Computer icon on your desktop.
  4. When that opens find your player under Removable Devices or Audio Devices. Some computers will show your player twice but will have the SD MMC card showing behind the player name. That is only for formatting the SD card.
  5. Right click once on the player to open the Options menu and then click on Format
  6. Click OK to any warnings that come up. There may be one or two depending on your operating system.
  7. Any memory will now be erased from your player and you can disconnect from the computer.
  8. Reboot your computer and plug your player back in.
  9. When you see USB appear on your players screen, press and hold the M button until MTP appears on your screen.
  10. Reload your music
Sep 05, 2009 | GPX MW3836 MP3 Player
There is virose in my phon
jst format ur memory card thts all
Jun 13, 2009 | Nokia N95 Cellular Phone
Reset
Try Removing SD Memory Chip From Unit, Remember What Side
of SD-Chip Faces Forward, Slide The SD-Chip, White Tab To
Unlock.
If This Fails
www.dvssale.com
Call Dan Kim 408-970-3387, DVS-Tech Santa Clara, CA
Email dankim@dvs.co.kr
Email kimus@dvs.co.kr
I Own One Myself, Just Upgraded to 2GB SD Chip, Reloaded Software w/Map Ugrade
Still Working Fine
jeffreydrescher@Bellsouth.net
Oct 03, 2008 | Digital Video Systems Plenio VXA-3000 GPS...
How i do format my nokia n70
Warning this will erase everything on your phone. Make sure that you back up everything to an mmc card if possible
Switch of your phone
*#7370# also works for formating, so no need to perform difficult key combinations
Jul 06, 2008 | Cell Phones
Forgot password blackberry curve 8310
I think all you can do it reset the device to disable the password completely. If you enter the password ten times incorrectly it will ask if you want to do a complete reset.
THIS WILL DELETE ALL YOUR PERSONAL DATA.
If you can, back up your device using the Blackberry Desktop Manager application before doing a reset. Then you can re-load all your personal data after the reset, instead of having to type it all in again.
May 24, 2008 | AT&T Blackberry Curve 8300 Smartphone
Lowrance LCX-15MT GPS Receiver Logo
Top Lowrance GPS Experts
Andrew Taylor
Andrew Taylor
Are you a Lowrance GPS Expert? Answer questions, earn points and help others
