Question about GE Refrigerators
Ge refrigarator gss221bta
Freezer coil ice up, defrosted now frig too cold
mikedurland
  • 481 Answers
SOURCE: Kenmore refrigerator 5260 not cold
  • the defrost timer on your machine is actually integrated within a control board/air diffuser. hopefully that is not the problem (expensive).
  • i would start by testing the heater and bimetal thermostat in the freezer. (note: the bimetal thermostat will only have continuity when below 40 degrees.)
  • the heat you feel between the doors is normal (if it is not too hot).
  • some of the heat that is released by the machine is intentionally released between the doors to prevent condensation.
  •  if it seems warmer than usual then you might need to clean the coils under the machine and make sure the airflow under the machine is not obstructed at all.
  • if the coils are dirty then they will not be able to release the heat properly and the heat will be released in other areas like between the doors.
Posted on Jul 18, 2008
freetek
  • 5568 Answers
SOURCE: freezer cold refrigerator not cold
It almost sounds as if your fridge is stuck in a defrost cycle.
The timer for this is often located behind the grill at the bottom and sometimes is constructed with a visible shaft that you can mark to see if it is running at all. Some units are constructed so that the defrost heater and compressor can't be on together, others are made so thoughtful. If you don't see a shaft, you might try an old mechanic's trick of using a screwdriver with the tip pressed against the timer housing and the handle pressed firmly behind your ear for bone conduction. If you hear anything like motor noise during the time the compressor is not on, then the timer is probably OK. If you hear nothing, then it might have failed.
Posted on Oct 20, 2008
aasc
  • 1606 Answers
SOURCE: GE Frig model TFX20JRBK ww with icing on freezer
I would suggest fixing it . You only have 2 parts in the defrost system . A timer , and the defrost heater which comes with the bimetal , pt . # WR51X10031 .Most probable , is the defrost heater . You will need to remove the rear inside freezer panel , and defrost the coils with a hair dryer . After defrosting , 2 screws hold each ( 2 ) heater on , ant the defrost thermostat , just clips onto the top of the coils .
Posted on Nov 18, 2009
  • 15 Answers
SOURCE: Freezer works, frig does not. Also ice build up in freezer coil
I just worked on a FF801W which is supposed to be very similar. The defrost heater in mine was of the glass tube type and located under the evaporator. There was a bimetal thermostat clipped to the top of the evaporator and a thermal fuse (sealed in a clear plastic tube) nearby. The connections were behind a little plastic cover (2 screws) in the back wall just above the evaporator.
Mine was iced up like yours and I had to defrost it with a hair dryer. All the defrosting parts in the freezer compartment turned out to work so I now suspect the defrost timer (down by the compressor). I've marked it and I'm waiting to see if it's turning.
Posted on Dec 15, 2009
Sea Breeze
  • 4654 Answers
SOURCE: my frig is running but not cooling - frig is 50
I can help you diagnose the problems with your GE. Several things can cause these symptoms. All you need is a voltage meter patience and a want to, to repair and do it better than a paid technician. In most cases with the PSS26MSRSS the defrost heater is the cause for this. Look into rear of your freezer and back wall. Is Ice or frost building on rear wall? If yes unplug and prepair to remove contents in freezer compartment. Remove rear panel in freezer and use hair dryer to defrost ice until the defrost heater is visible. BRB , Sea Breeze
Posted on Jan 23, 2010
Testimonial: "Thanks for the quick help - yes frost on back wall. Once I unload and defrost should I then take out defrost thermostat? "
My frig is running but not cooling - frig is 50 degrees,freezer 40 degrees, cleaned the coils,etc GE side by side coils in bottom if frig side feel cool, "box" between freezer and frig side is not blowing...
Jan 23, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
I have a Jenn-Air side by side frig. The freezer side cools too cold, the frig side not enough. 2 weeks ago I took all the food out of freezer and noticed ice build up on back. I unplugged unit, let it...
If the freezer is staying cold it sounds like a defrost system problem. A bad timer, heater or thermostat can cause frost to build up on the coils and block air flow to the refrig side. Check out ACMEHowTo.com for troubleshooting the defroster problem.
There is a small duct between the freezer and refrigerator side if this is blocked the frig side won't cool.
Jan 09, 2010 | Jenn-Air JCD2389G Side by Side...
Nov 18, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Our GE profile freezer/frig - frig side has ice on coils
Sounds like the automatic defrost system is not working. The usual problem is the defrost heater, the defrost thermostat, or the defrost timer. If any of these parts are bad, it will not defrost.
Aug 21, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
GSS220 side by side refrig does not defrost and no longer cold
the frig is cold by the air for the freezer so if it all ice insinde no air can pass to the frig 1 turn off you frig ,, yes it not fun but you will reset the frig ( more that 3 hour )
meanwile , take out the ice of you freezer ,lower you temperature in the freezer and restart
if it do that a other time , it easy it you temperature detecter it is broken .. some you need to change it
Jun 07, 2009 | GE Refrigerators
Mar 23, 2009 | Avanti FF1101W Top Freezer Refrigerator
Refrigerators Logo
26 people viewed this question
Top Refrigerators Experts
Sal DeAngelo
dweatherby
