Question about Bunn VPS Coffee Maker
Weak Coffee Why does my coffee taste like water no matter how much coffee I use??
  • 691 Answers
First think to check is the spray head which pours the water onto the powder. remove the spray head, clean it and soak it in descaler.
reassemble and do a brew. When finished check the surface of the coffee has 6 dimples where the water has poured onto it and that the coffee is uniformly wet. If no dimples or dry spots, get replacement spray heads.
Posted on Nov 01, 2013
SOURCE: my bunn is too slow
Use the de-liming spring to clean the copper tube behind the spray head. Pour several pots of clear white vinegar through the unit to further remove lime and scale from the interior of your coffee maker. My Bunn is 24 years old, and the only replacement parts I've ever required are new carafes and the 4041 silicone washer repair kit.
Posted on Sep 19, 2007
  • 60 Answers
SOURCE: weak coffee
It sounds like you may have lost the sprayhead. It is under the brew basket (above the place where you put the basket with the filter and the coffee). Sometimes they get loose and you don't realize it and it can fall in the grounds and get tossed out after brewing.
Posted on Jul 18, 2008
ginko
  • 19396 Answers
SOURCE: WEAK COFFEE & NOT HOT ENOUGH
Basing on personal experience (you can find more on Google probably), solutions are:
On percolated (filter) coffee machines:
Check water temp, if water temp is insufficient , most common is scale heating element , faulty element, faulty thermostat.
Check if water is dripping right at the center of the filter, if it is dripping on one side because the orifice is clogged, that can result in weak coffee.
Coffee blend not well distributed on filter basket.
On Espresso machines:
Check water temp, same as filter coffee machines (thermostat element, scale on heating chamber).
Ensure that coffee is filled correctly in the filter cup (fill at level), and well pressed.
Ensure that the coffee mixture that you are using is not too coarse, buy the apposite one for espresso.
Ensure that you are not leaving the machine brewing for a time that is too long, and Italian coffee cup is very small, approximately one regular shot.
On the hob moka pots (espresso, Moka and Bialetti type):
This are the trickiest ones, you need art and practice to get a good espresso with a Moka, but when you learn, the result is better than what you may get with an home electrical espresso maker.
The frame on the hob must be not too strong, and the mixture coarse but well pressed, with water at level tag, or you will get a weak coffee.
On Mokas a good strategy is keeping hob at minimum, and turning up the flame at top when coffee starts coming out.
French and turkish cafetieres:
Ensure that you put enough coffee, water hot enough, and that you left the infusion enough time to get a strong coffee.
Note: insufficient pressure and clogged lines on electric machines never give you a weak coffee, exactly the opposite.
Not pressed mixture always gives weak coffee, but too much pressed mixture may give you coffee with bad taste.
Posted on Apr 01, 2009
  • 125 Answers
SOURCE: Bad tasting coffee
Hello. Usually bad taste is one of 3 things, water quality, coffee quality is changed, or brew temp is different. Try removing all the water, by tilting the unit over the sink, unplug please, so the end where the funnel would go is draining the water into the sink, go slowly. Once all the water is removed, refill it with fresh water until it comes out the spray head/funnel area again, plug back in, heat and test. Now there could still be residue in the tank, and it may require doing this a couple of times to clear fully. Try another coffee, may have just had a bad can/bag/etc..
Last, take the temp of the water coming out of the funnel, should be about 180 deg. F, if not it could be too cool, and needs a thermostat or element. If you need a service provider, go to www.bunnomatic.com and locate a service near you.
Hope that helps, and thank you.
Posted on Apr 11, 2009
  • 131 Answers
SOURCE: when we make a pot of coffee, the water goes
This is usually caused by a missing sprayhead above your filter basket. take out the filter basket, and see if there is a sprayhead up there, or if there is just a little round pipe that the prayhead screws on to. If it is missing, you can contact your local Bunn dealer, or phone bunn directly, and they will take care of you. You can get a list of repair centers in your area at www.bunn.com
Posted on Nov 26, 2009
My tassimo coffee maker is ruining the coffee it taste like water
i too had this problem BUT it was AFTER i descaled it and did the cleaning, now coffee tastes weak, and ive tried different discs (other coffees) and all come up weak.
Nov 13, 2011 | Bosch Tassimo TAS 4012 Coffee Maker
Coffee comes out as weak as coloured water! far too weak.
you probably are not putting enough coffee in to strengthen the coffee
Apr 25, 2009 | Philips Senseo HD-7810 Coffee Maker
Weak coffee is the result of brew
Since it is "brand new out of the box" check for plastic burs (pieces of plastic improperly hanging around
openings along flow of water) throughout unit, and use more coffee than recommended for your taste of
what a good cup of coffee should taste like, since that varies from individual to individual. If you are using
packets, try using TWO. Experiment, Experiment...........
Apr 17, 2009 | Regal Ware 15-0264 Polished Aluminum...
Coffee out of the machine seems too watery
Feb 22, 2009 | Gaggia Syncrony Compact Coffee...
Bad tasting coffee
tell what does it taste like is it to hot burn let me now but i would descale it first not with venagar but with coffee maker descaler start with that and let me now what the taste
Jan 10, 2009 | Sunbeam COFFEEMAKER 10C BLACK DR13
Krups 453 - coffee is weak
Dec 09, 2008 | Krups ProAroma 453-42 Coffee Maker
Coffee weak
IT MIGHT NEED DESCALING RUN SOME WATER AND WHITE VINEGAR THEN RUN CLEAN WATER A COUPLE OF TIMES AND MAKE COFFEE SEE IF ANY BETTER PS WHITE & ONE SUGAR FOR ME THANKS HOPE THIS IS HELPFUL GLENN.............
Nov 15, 2008 | Mr. Coffee 072179228578 12 Cup Coffee...
Weak coffee
Jun 24, 2008 | Cuisinart DCC-1200 Coffee Maker
Coffee is weak and watery
After reviewing troubleshooting diagrams, I really couldn't find a solution to your problem.
The only thing I can suggest is to use 2 oz per pot of coffee grounds. Your 5 or 6 scoops assuming they are one ounce each is way more than enough.
Look under where your basket goes. Most bunn coffee maker has a flavor guard on the downspout. this down spout actually helps distributes the water over the whole basket of coffee grounds. Most of the time I see these missing, and when they are gone, they are gone.
Use less water for the amount of coffee you are using first. Sadly when there is not enough water, the coffee tastes bitter. Too much water tastes weak. Hot water extracts certain elements out of the beans even after grinding.
Always use a fresh paperfilter designed for your coffee maker.
If this pot is not work correctly still, I will suggest seeing your appliance repair technician.
May 26, 2008 | Bunn BT10B Coffee Maker
My coffee tastes weak
Not pressed mixture always gives weak coffee, but too much pressed mixture may give you coffee with a bad burnt taste.
Dec 28, 2007 | Starbucks Barista Utopia
Bunn VPS Coffee Maker Logo
57 people viewed this question
Top Bunn Coffee Makers & Espresso Machines Experts
Kelley Hopper
Jim Y
Jim Y
pawnpower
Are you a Bunn Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
