Curtis 3227a lcd
How do i turn the external speakers option
No sound coming from internal speakers Toshiba Projection television Model 50h82.
Some TVs have a set up option to disconnect internal speakers when an external audio amplifier will be used.
Dec 29, 2016 | Samsung Audio Players & Recorders
I plugged in external speakers but get no sound. Is there somewhere in a menu to turn the speaker ports "on"?
In almost all the led tvs there is an option in the menu to select whether you wish to use internal speaker or the external speaker. You have to make the after putting an external speaker.
http://electro-medical.blogspot.com/
Jan 02, 2016 | Televison & Video
How do I get external speakers to come on?
You can select the option at its sound menu. Get it, and select 'External speakers' which in turn switch off the internal speaker, and bypass the signal to the external speaker. But; the you can't bypass the audio output, but the audio signal output from the back of the TV to any external amplifier or so. If you've any doubt, contact any technician. Gopakumar Gopalan Google
Sep 16, 2014 | Samsung LN46A650 46 in. LCD HDTV
HOW DO I CONNECT A GATEWAY LP2207 TO GET THE AUDIO TO WORK?
Some monitors do not have speakers (my HP monitor does not). The sound has come out of some external speakers attached to the tower. Or maybe you need to access the monitors on-screen menu to turn the speakers on (if they have speakers). Or maybe you can access the monitor speaker control through the PCs Device Manager option (this is where all external components attache to the PC can be viewed, and sometimes changed).
Aug 13, 2014 | Gateway LP2207 LCD Monitor
No sound, when I click on the little speaker on the right hand lower coner the sound level bar is moving but no sound
Check the sound ICON at the lower right of the screen. Make certain the options are Internal Speakers and not EXTERNAL Speakers. Test by using a head phone in the external port to see if the sound is diverted properly. If you have sound OUT at the external Ports, then Reverse the option to Laptop Speakers.
May 09, 2014 | Sony VAIO VPCEB12FX PC Notebook
Internal speakers
If you go into the menu their should be an option for audio/sound once you enter that sub-menu there should be an option for the speaker internal/external or speaker on/off.
Nov 10, 2013 | Pioneer Elite PRO-940HD Television
Why doesnt the volume come on whe i turn my televsion on?
first thing is,check its not muted or output is selected for added surround sound,second may need to open back of tv see all wires are connected to the speakers and board.first explore all your menu options for muted sound or output
Mar 19, 2013 | Curtis CMMT32 32 in. LCD TV
No sound on curtis lcd3227a
check:
Speakers in set not switched to OFF or external.
Set has sound when playing a DVD etc connected to a rear audio/ video input.
If set has a earphone jack see if it has sound.
Dec 23, 2012 | Curtis Televison & Video
No sound on my sharp aquos lc-45gd4u 45 in
Assuming you are using the internal speakers, check and make sure you have the audio enabled. Some TV sets have a option to turn off the internal speakers. Also make sure mute isn't turned on. If you are using external audio setup, double check your connections.
Nov 24, 2012 | Sharp Aquos LC-45GD4U 45 in. LCD HDTV
Televison & Video Logo
Top Televison & Video Experts
Electro Med Services...
