Rca rs2640 How do you find and change the Q401 transistor?!
  • Audio Player... Master
  • 5,449 Answers
It should be marked Q401 on the printed board. It will have 3 legs you need to desolder these and then you can read the number to order a replacement. Make a note of how the transistor is fitted before you remove it. For example if it is flat on one side and that faces another part then when you put the new one back it should go in the same way, with the legs matching the holes in the pc board.
Posted on Jul 29, 2013
2 Suggested Answers
  • 319 Answers
SOURCE: RCA RS2640 Quit
Unit probably has defective component in standby circuit. Have serviced
Posted on May 08, 2008
What is the Q401
Q401 is the part designation of a transistor on one of the boards in the unit.
Jan 15, 2015 | Televison & Video
Rca big screen
Most times when this unit chirps the horiz output transistor has shorted. If I remember correctly the transistor is Q401. Some times the flyback transformer can be bad as well T401.
Jan 28, 2008 | RCA P46921 46" Rear Projection Television
RCA RS2640 Quit
Jan 15, 2008 | RCA RS2640 CD Shelf System
Buzzing noise
I had the same problem with mine and the fix for it was to replace the Q401 transistor on the main board. I used a NTE382
replacement and has worked fine ever since.
Hope this helps
Aug 26, 2007 | RCA RS2640 CD Shelf System
Expert advice
I had the same problem with mine and the fix for it was to replace the Q401 transistor on the main board. Used a NTE382
replacement and it has worked fine.
Jun 20, 2007 | RCA RS2640 CD Shelf System
Buzzing noise
Of course it will stop buzzing when you mute the speakers. From the limited description, it could be anything from a power supply to loose wires in the system between the speaker leads and the motherboard. Best bet is to take it in to a technician and get a pro's answer. If he wants to charge more than what it's worth to you, get a new one.
Jun 19, 2007 | RCA RS2640 CD Shelf System
RCA TV PROBLEM
check the horizontal o/p transistor I suspect it's shorted, find location Q14401, on the board it's marked as q401. it's located near the flyback on a heatsink. if it's bad the rca part number is 242224. good luck
Dec 13, 2006 | RCA F27442 27" TV
Rca rs 2620 power but no audio
I had the sane problem: No audio out from any source. Although I was unable to find a schematic or service manual, I did find the defective part was labeled on the circuit board as Q401 and replaced it with RadioShack part number 276-2009 (MPS2222A NPN Transistor TO-92 case NPN silicon). This is not an exact match, but is available at most RadioShack locations for under $1 and has fixed the problem.
Dec 12, 2005 | RCA RS2620 Single Cassette Deck
42 people viewed this question
 Grubhead
Grubhead
