Question about Minka Aire F803-TL Artemis? Fan
Connect blue wire light ground
I have a Minka Aire F803 ceiling fan. I don't understand the wiring for the wall transmitter. My wall outlet has 3 wires black,white and ground. The manuals states do not connect either of the black wires to the white. The green/yellow wire is the ground and I connected that to the ground. The 2 blacks I connected to the 1 black outlet wire but what do I do with the outlet white? The fan or lights do not work with my current wiring, what am I doing wrong?
    Genius:
  • Minka Master
  • 1,617 Answers
I think you have to connect the black to the white if you don't have any other wires.
Posted on Jul 28, 2013
2 Suggested Answers
  • 16 Answers
SOURCE: Ceiling fan switch
you connect white to blue
Posted on Aug 09, 2012
How to bypass a Concept II fan receiver?
SURE you want to do this? A REPLACEMENT Receiver is just $36 bux...
Minka Aire P001021500S Receiver 6 5Uf Dl
[Brand & Part #: Minka Aire P001021500S SKU #: minp001021500s UPC #: 706411042003]
This APPEARS to be your manual:
https://www.1800lighting.com/documentation/Installation/Minka-Aire-Ceiling-Fans/F518.pdf
>>> See Figure 4 <<<
The big question IS ~ how will you switch the fan and lights after your mod?
*** DO THIS AT YOUR OWN RISK! POWER OFF FIRST ~ have a DEPENDABLE/BRIGHT flashlight ready!! ***
MARK BOTH ORANGE WIRES at "both ends" with small strips of masking tape: "1" and "2"... )so you should end up with 4 strips). #1 at the Receiver and then #1 at the fan. #2 at the Receiver and #2 at the fan.
Looking at figure 4 ~ "I" would connect WHITE to WHITE.
Then connect (two) ORANGE + BLUE + BLACK wires together... TWIST them tightly-TIGHTLY together. Now TRY a YELLOW wire nut to bond them all together... if that is not large enough use a RED wire nut.
CAREFULLY strip more insulation jacket ~ if needed... then trim to required EQUAL length.
YOU DO understand this will put your LIGHTS AND FAN into a constant ON condition? And I suspect your FAN will be at high-speed?
Anthony
Dec 20, 2017 | Dryers
My fan works but the lights do not on my bolo f620 fan
I would make sure the wire connections from the receiver to the fan light wire are secure. Otherwise call 1-800-307-3267 ( Minka aire )
May 04, 2014 | Minka Lavery Minka Aire F620-DBB Bolo 5...
Light ON Fan ON. Cannot operately sperately by remote.
Do you have a Fanaway or Minka Aire Concept fan? Anyway it's usually wired this way; Black to black, white to white & red to blue.
Apr 14, 2014 | Minka Concept II Flush 44 Ceiling Fan by...
How do you connect the wiring of the Minka Aire Concept I and II to existing multi-switch that has a separate function for the light and fan? The unit has just 2 wires (black and white) and the ground,...
I will like to have more details about your multi-switch (circuit diagram/ no. of conneting wires left out with its color/ and its fuction ie function of the multi-switch). The same will be required for you bot types of fans --- old and new one.
Please send it.
Oct 20, 2013 | Minka Aire Ceiling Fan
I have two minka aire ceiling fans in the m bed rm, controlled by two separate wall remotes which are hard wired and have dip stwitches on there back sides, one fan/light works and the other will n
I think you have a mixed or a connected wire problem. It looks like your breaker has tripped, doesn't need to spark... :) to trip. Is everything the same voltage ? Are you sure there's power at the switch mentioned..
Don't take anything for granted, respect electricity..
Jan 27, 2013 | Minka Aire Ceiling Fan
I need a replacement bulb for my Minka Aire Artemis ceiling fan. Can I buy this locally (I live in Minneapolis) or will I need to order it online?
remove old bulb & take it to a home improvement store,hardware or electrical supply, to find a matching replacement.
Oct 15, 2009 | Minka Aire F803-TL Artemis? Fan
I currently have 2 switches on the wall for a ceiling fan(this was pre-installed when I bought my new home, but my Minka
The red and white should be hot all the time for the fan to run even when the light is not in use. The black and white wires are used for the switch on the wall to turn the light on. Hope this helps.
Apr 25, 2009 | Minka -Aire Brushed Nickel Remote Control...
Traditional Gyro by Minka Aire - Just installed and does not work
I would triple check that the wiring is correct, then I would check the dip switches on the receiver and the wall switch to make sure they are set the same.
Apr 28, 2008 | Minka Aire F602-BNCH Gyro? Fan
Minka Aire F803-TL Artemis? Fan Logo
80 people viewed this question
Top Minka Dryers Experts
Joseph Coppeto
Joseph Coppeto
Are you a Minka Dryer Expert? Answer questions, earn points and help others
