Question about NewAir Af-351 Portable Evaporative Cooler With Built-in Air Purifier -
Portable evaporative cooler motor wont start - NewAir Af-351 Portable Evaporative Cooler With Built-in Air Purifier -
Can my 3 in 1 air cooler also be used as a dehumidifier
an air cooler is a dehumidifier by definition
It cools the air around the evaporator giving you cool air and at the same time any humidity in the air is condensed into water and drained off
to understand air conditioner principles it goes something like this
we sweat and the more we sweat is because of the humidity in the air
if the air temp is 30 degrees c with a humidity of 75% then we feel that it is a very hot muggy day simply because the humidity stops the sweat from evaporating and allowing the skin to cool
Now it you take the humidity out of the air and at the same day temperature , you will actually feel cool because the sweat can evaporate and cool the skin
now you can understand that the best setting for air conditioning is 25 degrees c because if the setting is lower then the skin gets too cool because there is no humidity to restrict the evaporation of the sweat
modern spilt systems have a mode called comfort where the fan and the compressor work to maintain a constant level of humidity when sleeping and you don't get cold especially towards the morning
Jul 29, 2015 | Dehumidifiers
Why is my dri-eaz drizair 1200 dehumidifier freezing over?
There are two major causes of a dehumidifier or air conditioner to freeze up the evaporator coil. First is lack of air flow try cleaning or replacing the air filter if it has one; make sure the fan is running and the coils are clean. Second is a low charge of refrigerant requiring a refrigerant leak check; repair and recharge. A slight overcharge will keep a dehumidifier from freezing in cooler ambient temperatures.
Sep 25, 2014 | Dehumidifiers
Haier CPN12XH9 Portlable Air Conditioner/Heater - The upper water plug (which I can't find a picture of on any manual) accumulates water while the lower tank (where water should be) is dry. Unit is only...
Not up on the unit, but water condenses on the evaporator of an a/c unit dropping onto a tray, as self evaporating, would assume that the drain from that tray is fed to the top of the compresor, which will have a tray around the top, heat from the compressor will evaporate the water, same as with a fridge. In dehumidifier mode, water would need to be collected, rather than evaporated back into the atmosphere, defeats the object other wise. so is lower tank around compressor? that would be for a/c mode upper tank for dehumidifier
Aug 05, 2014 | Haier CPN12XH9 12,000 btu Portable AC Air...
Using as heater and unit is blowing cold air
A heat pump is an air conditioner that reverses its refrigerant flow. In the cooling mode, the evaporator is cold to the room and its condenser is hot. In the heating mode, a valve reverses the refrigerant flow and makes the evaporator warm and the condenser cold.
Nov 24, 2013 | Soleus 10,000 Btu Portable Ac Air...
Is it possible in aircon to used it with no compressor??
Nothing in air conditioning is new. It has been done for many years.
There are three types of "compressorless" refrigeration that I can think of.
1. ) swamp coolers or evaporative coolers - these work on the process of adiabatic saturation in low humidity environments. Evaporating water removes energy from the air, makes it cooler and more humid. This is a win-win when the air is very dry, but the process doesn't work well in humid environments, were water evaporates less readily.
2.) Peltier junction solid state coolers. These are essentially a thermocouple driven in reverse. Conduction between the hot and cold plates is hard to control and at low voltages these devices need a lot of current. These units are not as efficient as mechanical refrigeration.
3.) Absorption refrigeration cycle. In these systems a solution of ammonia in water (or water in a lithium bromide brine) is used. Heating the water (or brine) drives out the ammonia (or water vapor) and takes the place of the compressor in the cycle. This cycle is useful if you have a source of waste heat. You essentially recover the energy in the waste heat to run a refrigeration unit. A few demo units have used solar energy as the heat source, but I don't think this is common
Sep 18, 2009 | Dehumidifiers
I NEED TO KNOW WHAT PERCENTAGE MEANS ON A DE-HUMIDIFIER
In plain English, the Percentage setting on your de-humidifier is the percentage of moisture that you want to maintain in the air. Relative humidity level range from about 10% (VERY dry air) to almost 100% (VERY damp air). When relative humidity is 100%, water vapor in the air will turn into rain, condensation, dew, snow or frost. 50% humidity is usually a comfortable level, but that will also depend on air temperature. The more moisture there is in the air, the warmer it feels and conversely. Warm air will hold more moisture than cooler air.
Your body is cooled when moisture on your skin evaporates into the air, carrying body heat with it. As the humidity in the air rises, less of your body moisture is able to evaporate and thus your body feels wamer. Lower humidty allows moisture from your body to evaporate more quickly and you feel cooler, both at the exact same temperature.
Jun 28, 2009 | Kenmore 54701 Dehumidifier
NewAir Af-351 Portable Evaporative Cooler With Built-in Air Purifier - Logo
27 people viewed this question
Top NewAir Dehumidifiers Experts
Bill Long
Gil Shultz
jasbo
jasbo
Are you a NewAir Dehumidifier Expert? Answer questions, earn points and help others
