Question about Remington Garden
Homelite com hi, I'm Stefano, from Italy. I have an old Remington SL4 Automatic Oiler (the one with no oil pump, but a valve that use engine pressure to eject oil on the chain), and I need to buy some items. I have a Part Manual for this model, but I need to have the Part Manual for the comparised Homelite model (may be Homelite XL12? may be SuperXL? may be XLAO?), to extend my chanse to find parts. Can you help me?
  • Remington Master
  • 1,807 Answers
Homelite XL12 parts manuals
Posted on Jul 27, 2013
  • 583 Answers
SOURCE: Parts needed for a remington SL4
Hi, if you have access to a computor goto GOOGLE type in remington chain saws electric press search and it is all the models ,parts and distributors easy go for it ,any more help needed just come back to me. youdoit
Posted on Aug 13, 2009
  • 4088 Answers
SOURCE: Need replacement Chain oil pump
Go to the Homelite web site, which will get you to HCPI Electronics Parts catalog. You will need the model number. The parts are illustrated as a break-away drawing for various portions of the saw. Hope this helps.
Posted on Sep 01, 2009
dontbother10
  • 2220 Answers
SOURCE: automatic oiler on homelite super xl ao does not
Please see the clarification. Lou
Posted on Oct 05, 2009
dontbother10
  • 2220 Answers
SOURCE: auto chain oiler doesn't work homelite temberman 45
Oil System Plugged:
  1. Remove the clutch cover, bar, and chain, clean the bar groove, any holes and passages on the rear of the bar (both sides, consider rotating the bar), if equipped with a sprocket nose ensure it rotates easily at least one complete revolution. Clean the saw oiler hole and channel. Insert a blunted, hooked piece of wire through the oil filler hole and pull the hose in the oil tank out. Pay attention to the screen or filter on the free end (clean or replace, difficult to determine serviceability). Start the saw and see if it oils when revved up (oozes down side of saw). If yes reassemble your saw. If no, continue with 2.
  2. Work your way through the linkage (use IPL to identify components and locations) cleaning and replacing any defective parts as you go. Carefully check the hoses for cracks especially at bends and connections. If equipped with an oil pump it is usually behind the clutch (clutch is a left handed thread). Please make extensive notes & some digital pictures will help during reassembly.
If it does not oil on completion of 1 it is most likely a bad oiler or worm gear (see IPL).
Timberman 45 does not cross to an IPL I can find. If you can find an IPL it really simplifies disassembly/reassembly, provides component locations and component part numbers. Without the correct IPL I would not undertake a repair.
Homelite/Ryobi.com (authorized parts supplier)
https://www.gardnerinc.com/recons/disclaimer-lg.php - Agree; Choose “Product Line”; “Select OEM” & “Select Catalog” both to “Homelite Consumer Products”. A drop down list appears; self explanatory from here.
The numbers Homelite & Ryobi use do not match the numbers everyone posts. A careful inspection of your saw should find something that matches.
If you have more questions or need additional help please reply below and I will get back to you. Thank you for using FixYa and Good Luck. HTH
Lou
Posted on Mar 14, 2010
suzukiracing
  • 200 Answers
SOURCE: Chain Saw Motor will not start.
Yes it is very important i would recommend also putting in a new spark plug. Thanks for asking and I hope it helps
Posted on Jul 21, 2010
I need to remove the automatic oiler in my homelight chainsaw z3850b
Chainsaw Oil Pump Replacement - Homelite ... - YouTube
? 5:57
https://www.youtube.com/watch?v=8dj0Voh3TTM
Jan 21, 2014 - Uploaded by RepairClinic.com
The most common reason for replacing the oil pump is ... ...Chainsaw Oil Pump Replacement - Homelite Chainsaw Repair (part #309514001) ... spark plug wrench, cord, clutch removaltool, adjustable wrench, needle-nose pliers ... The chainsaw guy shop talk Repair Homelite 150 chainsaw Auto Oiler ...
How to Repair a Homelite XL Chainsaw Oiler - Home Guides
homeguides.sfgate.com > Real Estate Advice > Basic Real Estate Advice
The Homelite XL chain saw is designed to use one tank of oil per each tank of fuel. Fill the oil ... Push the guide bar toward the saw, and remove it and the chain. Clean the ... Automatic Oiler and Oil Line Replacement ..... My Ridevisit'Cars-My
Dec 21, 2015 | Garden
Old Remington SL4 Automatic Oiler
Found a website with all the equivilant homelite XL12 illustrated parts lists. You may need to look down the list to find the exact match.
Jul 27, 2013 | Remington Garden
Chain oiler not working
econvert (4)-svlhhucpg3yfogwt2cgj0zh0-4-7.png Hopefully this diagram will come through if not go to homelite.com, service and support, find parts, parts locator, model xl then to engine internals. You probably have a bad oil pump and these are parts and numbers you might need.
4. Spring..69447
5. Gasket 2 each 69244
6. Plunger A12356B (most common problem)
7. Oil pump body 693431
8. Ball 60051
9. Spring 68570
Jul 04, 2017 | Homelite Garden
My homelite chain saw is not getting oil on the chain from the automatic oiler?
either a faulity oiler or oil lines cloged try using compresed air to clear the lines by blowing in the oil tank
Nov 15, 2011 | Garden
I have a small homelite chainsaw.super EZ on the starter rewind it says automatic, but it has a manual chain oiler, it also has a knob that is labeled trigger latch, it appears also to be a compression...
oil out of the exhaust means that the oil /fuel mixture is incorrect
change the mix to 50:1 ( for the correct mixture there should be a faint wisp of smoke at rpms)
the chain is oiled automatically when the chain is running and the oil will leak out if left with a full oil tank and unused
the idling problem most likely will be from the incorrect oil/fuel ratio or incorrect oil in use --it is not engine oil but 2 stroke oil
do not use e mix fuels in small engines
Jun 15, 2017 | Homelite Garden
Remington SL4 chainsaw gets fuel but does not fire
She has points and most likely a condenser.
Chain Saw Collectors Corner
http://www.acresinternet.com/cscc.nsf/ed1d619968136da688256af40002b8f7/7c5ef158cb0d092988256d35001fa737?OpenDocument
I'd try that site for any help or parts for this Grand Old Lady.
I did a search for "Remington SL4" and found quite a few threads here:
ArboristSite.com Chainsaw thread (free to join)
http://www.arboristsite.com/forumdisplay.php?f=9
Please be kind to her. HTH
Lou
Oct 25, 2009 | Remington Garden
Aug 13, 2009 | Garden
Old homelite XL chainsaw pumping bar oil into engine while runnin
Check that the oiler hole and the hole in the bar that it pumps into aren't clogged. The sawdust running under the chain and be deposited in the oiler hole in the bar until it plugs it solid. That will keep the oil from havintg a place to go and build up pressure.
Feb 21, 2009 | Garden
Remington mighty mite chain saw
hi Wayne
Oiling has nothing to do with compression.It has conection only with engine rotation(rpm).More rpm results more oil and viceverse.Check the oil filter,the oil line,the holes from the bar,the oiler,the wormgear and the oil hose.
wish you all the best savumihai71
May 14, 2008 | Remington Polesaw Wizard
Garden Logo
89 people viewed this question
Top Remington Garden Experts
Phil Walker
Phil Walker
Roland W VanLue
Roland W VanLue
Are you a Remington Garden Expert? Answer questions, earn points and help others
