Question about Briggs & Stratton Garden
Obvious solutions won't start Lawn Mower!!!
My mower was working for the first half of the summer season. After stopping to change the bag one time, it had not restarted. I waited about 15 min, then it started and I completed the lawn. The two times after that I mowed the front and back with a strap holding down the engine brake. As of late I have replaced: air filter, spark plug, and a wire that appeared to be charred. It was a skinny wire going between what seemed like relays. I also pulled apart the carb and cleaned it even though it was pretty clean and didn't need it. Prior to all the fiddlin around I had noticed the old plug was black and greased up. I figured I was burning rich because of it and that the old air filter was restricting the air flow. Two days ago I assembled everything and the mower fired up. I was relieved. I let it run for 30 sec or so, then prepped to cut lawn. I placed the bag on the back and (out of habit, primmed it again, flooding it) tried to start it up to mow the lawn. Since it was flooded I pulled the plug out turned over the piston and stroke out the cylinder. Put the plug back in and nothing! Days later and no priming. It still won't start! What else could it be? What is the next step to trace the problem? Its not bad gas,or lack of it, low oil as I checked it. They are fine. I got spark after grounding it to the block. Any Ideas? Paul
  • Paul M Jul 30, 2013
    Solution: It turns out the solution was the engine brake cable wasn't fully disengaging from the fly wheel. Years ago my handle had bent from the weight of the motor and deck. It was wrecked where the handle meets the deck. I fashioned the handles so that the handles were shorter since I cut off the bent part at the bottom. This meant that I created some extra slack in all of the lines. I never had a problem for 4 cutting seasons, but this is what preveted the spark plug from getting spark! Not only does the engine brake create resistance on the fly wheel, but I found out I needs to be fully disengaged to send a signal to a relay to send current from the coil to the spark plug. Hopefully, this addition to your troubleshooting check list finds the reason your mower won't send spark to the plug. Hope this helps. Thanks.
    Renaissance:
    An user who is expert in 3 categories / brands.
  • 2,069 Answers
Sounds like it's a fuel issue.
After the Carb rebuild, you put gas in the tank and started it up immediately. and ran it only 30 seconds.
If you look at the gas tank now, is it empty? Is there gas flowing out by the air filter? You sounds mechanically smart, just wondering if you messed up something with the carb rebuild and gas is flooding up into the carb. Check the Oil again, is it overfull from gas getting into the oil?
Posted on Jul 28, 2013
  • 5 Answers
SOURCE: Continuously stalling and extreme difficulty restarting.
The brass "Bolt" that holds the "cup" on the bottom of your carburetor is also the main fuel metering jet for the engine. Get yourself a can of automotive carb cleaner, the aerosol type that comes with the small red plastic tube on the side of the can. Remove the "Bolt" and "cup". (Tip: tilt the carb side of the mower UP about 45 degrees and support it with whatever you have, wood, bricks etc. This will help stem the flow of gas from the tank while you have the "cup" removed.) Examine the "Bolt" and you will see one or two small holes in the side of the "Bolt" between the hex head and the threads. These are the metering orifices. Use the carb cleaner to throughly clean the "Bolt" orifices. (Tip: DO NOT attempt to 'drill' the orifices clean) Next, use the red plastic tube to spray carb cleaner up through the hole on the carburetor that the "Bolt" screws into. Be liberal with the cleaner. Finally, clean the "cup" with the spray one more time for good measure. Put everything back together. (Tip: easy does it on tightining the "Bolt") Level the mower, check for leaks and verify the oil level is OK. If the plug and air filter are up to snuff you should be good to go. (Tip: how old is your fuel? You should keep it around for only about 30 days unless you use fuel stabilizer. These little engines LOVE fresh fuel) Good Luck.
Posted on Jun 27, 2009
  • 16 Answers
SOURCE: lawn mower died while mowing and won't restart
check the carb and air filter... also make sure its not gas from last season and make sure the oil is good.
Posted on Aug 20, 2009
SOURCE: Mower stops running after I've been mowing for
Mower stops running after mowing about 5 minutes. acting like it was running out of gas unitl eventually stops. I wait 10 minutes and then it restarts, runs good, then erratic...then quits again?
Posted on Aug 24, 2009
  • 143 Answers
SOURCE: 4.5hp B&S engine on a bolens mower..won't idle steadily
This is called hunting, your fuel-air ratio is not right. Your carb. jets need cleaned
Posted on Sep 05, 2009
Testimonial: "Thanks...always get great advice on here...."
  • 12 Answers
SOURCE: Lawn Mower will not stay running then will not restart
I think we all understand the frustation penaone.
I noticed u didn't clean the fuel tank, water, dirt, and rust in it can give u problems. But u need to clean the lines and carb. again also. One of the kids filled my mower gas tank with driveway gravel once, and after I cleaned things out, the mower never run so good. Also your spark may be grounding out somewhere before it gets to the spark plug. Check for a bad spot in the wires from the magneto. Some of that may be behind the flywheel though.
ballping
Posted on Jul 29, 2010
Lawn mower doesn't start
you have unseated valve seats the hotter it gets the wores starting get this a warranty repair
Feb 24, 2013 | Briggs & Stratton Garden
Cub push mower starts but won't run. i changed fuel and spark plug. what next?
MAKE ADJUSTMENT TO CARBURATOR,TURN SET SCREW COUNTER CLOCKWISE, HALF A TURN,TRY STARTING MOWER,IF IT STARTS TURN QUARTER MORE,THAT SHOULD DO IT, GOOD LUCK
Aug 10, 2012 | Cub Cadet Street Sign- tractor lawn riding...
Mower starts but if it stops then it will not start for the rest of the day????
Mowing the lawn is a necessary chore throughout the growing season. It prevents your landscape from looking unkempt and keeps your home looking nice and neat. How well your lawnmower works can make a huge difference in how you perceive this task. If the mower runs well and does what it is supposed to, then the job might not seem too onerous, but if your mower stops every time it gets hot, then it can turn a job that should only take a little while into an all-day affair. There are a few reasons why your lawnmower might stall after warming up
Jul 29, 2012 | Craftsman 675 Series 190cc 22" Briggs ...
Mower won't start after short use
have you change your air filter for the season check anything to do with your carb area to much dust in air can get in to carb causing to engine to work harder
Jun 05, 2012 | Briggs & Stratton Garden
Black & Decker cordless lawn mower won't start
Hi Sandi-
This could be an issue with the battery itself or charger. The best way to know is to have the battery tested. You can follow the link to locate your nearest service center to have them tested.
Thanks
Black + Decker Customer Care Find Service Center
Jan 15, 2012 | Black & Decker Black Decker Cordless 24...
What oil to I use in toro self propelled lawn mover is 5w30 ok
Hi jonconbuck...
5W30 is ok during the winter season...but use 10W30 or 30 W non detergent during the summer season
Please take time to rate me
Sep 11, 2011 | Toro Power Lawn Mower
Electric lawn mower slowed down then stopped working?
The carbon brushes on your mower have worn and, need to be replaced; order them from black & decker
May 21, 2009 | Black & Decker 19" Electric Lawnhog...
The bag from my lawn mower keeps coming off. How do I prevent this?
You can call the company for help, or even make sure that the screws that are attached to the strap that goes around the bag are really tight.
But THE best solution there is duct tape! It works on everything!!
just roll it until it is secure, it may look poor or whatever, but it should keep it secure for ages!
Sep 01, 2008 | Troy Bilt 5.5hp Self Propelled Mower
Having a hard time to fill the bag and almost not cutting grass
Well it could be your blade on the mower, over the years i have had to profect my blade sharpening skills.
sometimes when a blade is shapened its not done correctly causeing a lack in the blade tossing the grass properly and more or less turning into mulch on the lawn.
You should have your blades on a push mower if used once a week through out the season sharpened once a season then
if you have large amounts of rocks, sticks and pinecombs then 2x a year
if you only use it here and there then ushally ever 2 years is good.
another issue could be the engine bogging down when going over heavy or wet grass. this is no fun..
what I do with my lawn mower is clean the bottom and spray it with PAM cooking spray has been far the best solution, spraying the bottom of the deck and blade.
Now saying that if you try this method then remember no wet grass so dont over water your lawn.
some people like to use POR 15 on the under side of their mowers as well but I havent tryed this yet but hear it works great.
so there is ways to prevent slow and no discharge into the grass catcher.
hope this helps but yes I would say clean the underside of your mower and have you blade sharpened by a professional. dosent cost much and so much more worth it.
Aug 14, 2008 | Troy Bilt 17 Inch 29 Cc Gas Powered...
Garden Logo
224 people viewed this question
Top Briggs & Stratton Garden Experts
Phil Walker
Phil Walker
John Trevino
donald boissonneault
Are you a Briggs & Stratton Garden Expert? Answer questions, earn points and help others
