Radio Communications Logo
Anonymous Posted on Jun 01, 2017
H17 stopped connecting
I bought this bluetooth about a month ago on Amazon.com, and it worked fine until yesterday. I dropped it (not a big drop, I have dropped my phone from worse than this, and it still works) so I don't see how it could be damaged, but half the time it won't turn on. When it does turn on, sometimes it will connect to my phone, and sometimes it won't. When it does turn on the call quality is horrible. Any help on how to fix this would be great. Thanks in advance.
5 Related Answers
Anonymous
  • 60 Answers
  • Posted on Jul 16, 2007
SOURCE: how do i connect my bletooth h350 to my phone
Hi, follow the steps to get your product paired. Step A - PUT HEADSET IN PAIRING MODE Note: To turn off headset With the headset power off, press and hold the Call button for 6 to 10 seconds until the blue indicator light turns on and remains steadily lit. (The light will flash while you hold the Call button.) If the indicator light is flashing or does not remain steadily lit, turn off the headset and repeat step above. Step B - SET THE PHONE TO LOOK FOR YOUR HEADSET Select (Menu) > Settings > Connection > Bluetooth Link > Handsfree > Look for Devices. The phone lists all Bluetooth devices it finds. Select Motorola H350. Press OK or Yes to pair (link) the handsfree device. Enter the passkey 0000 and press OK. Note: Passkey cannot be changed from 0000. When your headset is successfully paired with your phone, the blue indicator light changes from steadily lit to flashing. additional help http://www.motorola.com/mdirect/manuals/QG-H300_9495A08A.pdf all the best sreejith 2 Step A - PUT HEADSET IN PAIRING MODE Note: To turn off headset
informatica
Greg Cann
  • 1114 Answers
  • Posted on Aug 04, 2007
SOURCE: help getting my bluetooth setup with my cell phone
There is an online guide, link below: http://www.motorola.com/mdirect/demos/how2_h500/h500.html You can more information on the link below: http://www.motorola.com/consumer/v/index.jsp?ps=y&itemID=5041586a336a0110VgnVCM1000008206b00a____§ionName=SEC_TYP_00012&prodType=-1&vgnextoid=38b5f7c0c1a0b010VgnVCM1000008206b00aRCRD&show=globalSupport&catID=7af81300ec3b0110VgnVCM1000008206b00a____&pg=PG_TYP_00003&productID=e3bbb177d4ecc010VgnVCM1000008206b00aRCRD
DENNIS MITCHELL
  • 1003 Answers
  • Posted on Jan 14, 2008
on your phone go into menu look for connectons or bluetooth turn this function on then hold down hook button(big button with phone symbol) on the bluetooth until it stays solid (mic still folded in) then flip out the mic then pair phone phone will usually ask bond or pair with headset select yes enter passcode 0000
A
Anonymous
  • Posted on Aug 12, 2008
SOURCE: rival rice cooker stopped working
Mine just did as well today. Thought I blew a fuse, but no, just not working, although it did finish the pot of rice.
Anonymous
  • Posted on Feb 04, 2009
SOURCE: motorola h710 bluetooth will connect to phone but no audio
I disabled the bluetooth from my phone. I then turned off my phone and rebooted it. Once the phone was turned back on, I paired it up with the bluetooth and then it worked. So disabling and removing everything and starting over worked.
My "Millennium" spa has stopped circulating. The heater turns on but soon turns off within a minute or so. What should I look for to fix the problem??
I would start at the termostat,you could check water temp with cooking thermometer.let me know what you find out.
Nov 29, 2013 • Pool & Spa
I bought a viseeo ck390 bluetooth hands free car kit and am after an installation manual
Have been using one of these for a few months- worked fine at first, but now keeps dropping bluetooth signal. Have to restart car for it to reconnect:(
Yellow- radio mute
Red- battery +
Blue- ignition
Black- ground
Good luck
Nov 29, 2011 • Cell Phones
1helpful
2answers
How to activate the bluetooth on my nuvi1300
To activate your Bluetooth, touch Tool>>Settings>Bluetooth.
For Bluetooth connection, touch the button to pair a Bluetooth device with wireless technology or any device you want to connect with. To disconnect from other Bluetooth device, touch the drop from the screen. To wipe off the Bluetooth device you paired to your nuvi, Touch remove from the nuvi paired list, and it will delete it from the nuvis memory.
8helpful
Have a new motorola bluetooth h17. it pairs with the ps3 but wont connect, just error 8001000c. i even changed the audio settings to match the device and still wont connect
pairing motorola h17 with Ps3. Go to settings then to manage bluetooth scan find bluetooth (enter passcode 0000) hit triangle connect.(only first part keep reading) Now go to audio devices section under settings and change imputs to the motorola h17. If you don't go to audio devices the bluetooth wont stay connected. It will connect for like a second and stop.This drove me crazy for a day until I discover the fix. now go back to manage bluetooth and connect bluetooth and it should stay connected > you will see blue circle.
Bought a NetGear WPN111 RangeMax Wireless USB 2.0 Adapter a few months ago. It was working fine up until a few days ago. It started dropping my internet connection, and now it won't even detect any...
Hi
firstly you can try upgrading the drivers on the adapter. following is the link for the latest drivers http://kb.netgear.com/app/answers/detail/a_id/12520
If the problem still persists
try changing the wireless settings on the wireless router.
1helpful
Screen will not light up.
Well as crazy as it seems, by dropping it you most likely damaged the backlight for the phone thus making it not light up anymore.
Razr phones are notorious for being damaged easily. There is little you can do but replace it or accept it the way it is.
Sorry for the mishap, and I hope this gives a little clarification on the subject. Thank you for stopping by Fixya.
No voice
I have the same problem. I bought it from amazon.com a few months ago and had to send the first one back because of the same issue. However, this one did not present the problem until it was past the return window for amazon.com. :-(
Was working fine until now.
uninstall device and try to reinstall if this doesn't work go to www.n1wireless.com about 30 bucks
Top Motorola Mobility Radio Communications Experts
ADMIN Eric
ADMIN Eric
ADMIN Andrew
ADMIN Andrew
Are you a Motorola Mobility Radio Communication Expert? Answer questions, earn points and help others
