Question about Water Heaters
Richmond water heater
My electric Richmond water heater keeps popping the ECO and then I have to reset it. Why?
  • Water Heaters Master
  • 5,245 Answers
robocop
  • 90 Answers
SOURCE: need reset code for hot water talk
Go to www.richmondwaterheaters.com and see if they can assist you with it. Just click on residential products on the left side of the page.
Posted on Jan 22, 2009
  • 74 Answers
SOURCE: water heater not heating it's a richmond water heater
Now change the thermostats........this is the only other thing it could possibly be.
Posted on Apr 27, 2009
SOURCE: i have a richmond gas hot water heater model
resetting your lock out for richmond power vent
Posted on Nov 26, 2009
  • 744 Answers
SOURCE: pilot light on water heater goes out frequently
Check the following:
See if your heater has a pilot gas adjustment valve. It should be on the gas control valve somewhere. Not all heaters have these. It will be a screw on the valve that can be turned.
Make sure the thermocouple sensing bulb is squarely in the pilot flame and also check that the fitting where the other end of the thermocouple connects to the main gas valve is tight.
Check the pilot gas orifice (where the pilot gas comes out) for carbon build up - you may need to remove the pilot gas line and thermocouple assembly to get to this. This problem is pretty common.
Check the gas pressure to the heater. Run the hot water in the dwelling until the hot water heater starts. Check the flame on the main burner and see what color it is - it should be blue with possibly some yellow-tipped flames. If not, there could be a problem with the gas pressure at the heater or venting. If the heater has a gas pressure regulator, it may be out of adjustment or defective.
Finally, and this isn't very common, the pilot light can be extinguished if there is a draft problem, usually associated with an issue with the flue pipe venting system for the heater or another nearby gas consuming appliance.
Posted on Dec 31, 2009
Testimonial: "thank you. will try these suggestions tomorrow. really appreciate it."
SOURCE: need reset code for richmond
I am poting this here hopefully it will help someone else. I have a richmond 40 gallon power vent water heater and it was not working. It was flashing 2-3 on the LED. I used this procedure and it started up..
you can reset the control by unplugging the blower during start up, leave unplugged for at least 5 seconds, plug back in and within 30 seconds cycle temp control from hot to low 6 times.
Posted on Apr 13, 2010
Richmond 40 gallon. What size elements?
Richmond 40-Gallon 6-Year 4,500-Watt Medium Residential Electric Water Heater # ...Double 4500 watt heating elements for faster recovery
Jul 21, 2015 | Water Water Heaters
Richmond encore 3kw electric water heater stuck on standby mode no hot water this is a brand new unit never used!
About the only DIY repairs available are on following link:
http://waterheatertimer.org/How-to-wire-Tankless-electric-water-heater.html
Richmond is made by Rheem. They may tell you to call installer. Or give you name of local repair technician.
Gene
Water Heater Timers Save Money
Apr 13, 2015 | Water Water Heaters
Have 75 gallon gas water heater. Can I run 90 PVC off top power vent without vertical PVC first? Have Richmond unit.
1) I believe you can immediately elbow the PVC pipe.
There is a limit for how many elbows can be used between blower and termination, and limit is determined by diameter of PVC pipe.
2) Copy following link for venting resources and typical Rheem and Richmond power vent manuals, and diameter-elbow pdf from Bradford White.
http://waterheatertimer.org/How-to-troubleshoot-gas-water-heater.html#venting
3) Richmond is Rheem. Product manual will show specifications for venting.
Product warranty is voided if installation does not follow specifications shown in manual.
Feb 20, 2013 | Rheem Richmond 75 Gal Natural Gas 6 Year...
RichmondG40PVpower vent gas water heater
1) Type and brand water heater unknown.
Copy following link for Rheem-Richmond tankless error codes:
http://waterheatertimer.org/Troubleshoot-Rheem-Tankless-water-heater.html
2) Question posted under Richmond tank-type power vent.
Error code 24 appears to be Rheem-Richmond tankless water heater.
3) Add a comment with more information about type, brand, age of water heater including what you have tried so far.
4) Call service technician to catch up on required yearly maintenance.
Dec 28, 2012 | Audiovox Richmond 6G40-36F 6-Year Tall Gas...
WHERE IS THE RESET BUTTON ON THE 6EM30-2 FROM AUG 2004?
Electric water heater has panels located on front of water heater.
Remove top cover, and insulation to reveal thermostat and element.
Stand on dry surface, including boards or plywood.
Do not hold screwdriver in mouth.
Do not touch any metal.
Red reset button is located on thermostat.
Push in reset.
If reset will not re-engage, then thermostat may be bad, or some other problem exists.
http://waterheatertimer.org/How-to-replace-thermostat-on-electric-water-heater.html
Screw terminals on thermostat are live.
When finished, insulation and cover must be put back over thermostat so thermostat not exposed to cool air that will cause thermostat to misread tank temperature.
Put ear against tank to hear bubbly-fizzing sound that says water heater is working.
If water heater is leaking or wet, do not touch unless circuit breaker is turned off.
Electric water heater is fully repairable by homeowner.
ECO red reset button trips when upper thermostat senses overheating.
You many have underlying problem if reset continues tripping:
http://waterheatertimer.org/How-to-troubleshoot-electric-water-heater.html
Dec 09, 2010 | Audiovox Richmond 6EM30-2 30-Gallon 6-Year...
What does fvd interface malfunction mean
richmond lock out how to reset or restart my hot water heater
Oct 14, 2009 | Audiovox Richmond 6G40-36F 6-Year Tall Gas...
Water heater not heating it's a richmond water heater
Apr 27, 2009 | Audiovox Richmond 6G40-36F 6-Year Tall Gas...
Water Heaters Logo
187 people viewed this question
Top Water Heaters Experts
Paul Carew
Gil Shultz
Are you a Water Heater Expert? Answer questions, earn points and help others
