Question about Refrigerators
No power to right side of side by side refrigerator .
  • 41 Answers
Does it have a power cord connected to both right and left side? if so check with a tester for power. I there's power then check your compressor.
Posted on Jul 29, 2013
My refrigerator and freezer is not cooling. started after power surge yesterday.
Many times a freezer and/or refrigerator do not work right because of a dirty condenser coil...there are also many other things that can go wrong.
If you are hearing a clicking or buzzing then check out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Jan 25, 2011 | Whirlpool Gold White-on-White 21.9 cu. ft....
No display on front except for one led segmet flashing in top right corner
i had the same problem and read somewhere to hold "power freeze" and "power cool" for 12 seconds
Nov 22, 2010 | Samsung RS2578BB Side by Side Refrigerator
Side by side refrig - ice maker and water don't work after replacing the filters. is there a re-set?
Removing a water filter from the inside of your Frigidaire brand refrigerator:
Removing and replacing a water filter - upper right hand corner inside location
Filters situated up front in the refrigerator compartment of Frigidaire-built side-by-side refrigerators are relatively simple to replace. Follow these steps:
  1. Open the door of the refrigerator compartment of your Frigidaire brand side-by-side refrigerator. The filter is located in the upper right hand corner. It has a push button for quick release just to the right of the filter.
  2. Locate the icemaker On/Off power switch and place it in the OFF (o) position.
  3. Push in on the filter release button and pull the filter all the way out to remove it. Remove new filter from its packaging and remove the protective plastic caps. Insert the new filter in the same manner it was removed. Make sure to push in firmly on the filter until you hear the filter cartridge click in place.
  4. Return the icemaker's power switch to the On (l) position.
  5. Condition the filter by running water through the dispenser for about three minutes. This will flush the filter of all fine carbon particles.
  6. In some models, you will have to reset the filter status light. It is located on the ice and water dispenser control panel. Push in on it for ten to fifteen seconds until the green, red, and amber lights flash. If your refrigerator model does not have a filter status light, you should make a note on a calendar, or place a month sticker on your filter to remind you to replace the filter again in six month's time.
Note: Replacing this type of filter is a quick process - there is no need to unplug your refrigerator or shut off the water supply when replacing it. Also, this filter should be replaced every six months.
Oct 31, 2010 | Electrolux 25.9 Cu. Ft. Side-by-Side...
Refrigerator is not geeting power to the compressor?
If you are not getting power to the compressor then check the thermostat or the control board...
Check out this tip that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
heatman101
Sep 21, 2010 | Maytag MSD2756G Side by Side Refrigerator
Think there was a power surge last night. We have an Amana side-by-side, model ARSE 667 BS. The ice is melting, the rest of refrigerator is not staying cool. What could have been damaged by a power...
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
The compressor start relay and capacitor...
If your refrigerator is running but warm, then…
heatman101
Sep 08, 2010 | Amana ARSE667B Side by Side Refrigerator
How do i unhook or turn off water to ice machine?
There should be an on off switch on the right side of the freezer wall you can turn power off that will not allow water to the ice maker.
To disconnect water to the entire refrigerator there should be a shut off valve behind the refrigerator or under the kitchen sink usually.
Apr 18, 2010 | KitchenAid KSRG22FKSS Side by Side...
Temperature problem in freezer, set to 0 goes up to 5-7 degrees ice cream is like soft serve
Your defrost system is going out on this unit. It's a common problem that happens especially after storms or power outages. Give us a call or email us and we'll get the right part out to you asap so you don't loose any more food. We look forward to working wiht you andhelping you get your refrigerator running right again.
Oct 06, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
KITCHENAID REFRIGERATOR KSBS25FKBL00
there is a defrost control board in the box where you turn up the temp on the right it will control that .
Mar 30, 2009 | KitchenAid KSBS25FK Side by Side...
Refrigerator is too cold. Freezing milk and vegs.
sounds like the solenoid door is broke or stuck ,unless you are real handy , just tape up the air inlet in the refrigerator little by little until you get it right.
Dec 15, 2008 | Frigidaire FRS266ZDSB Side by Side...
Maytag msd2756de side-by-side: loud clicking noise from top right of refrigerator
sounds like the adaptive defrost controller part number 61005988. not to bad to repace, the top control panel is removed by pulling down on both rear corners ( youls find little finger holes across the top rear panel to free and pulll foward, the n there are 2 1/4in screws across th efron of control, and 2 phillips head screws jus behind each light bulb, one last 1/4in screw directly on back wall will drop entire panel adn after that youl see the control in the right hand corner unplug the old replug the new . DISCONNECT POWER PRIOR TO REPAIR<
Oct 22, 2008 | Maytag MSD2756G Side by Side Refrigerator
Refrigerators Logo
32 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
