Question about Poulan 42-Inch Steel Deck 17.5 HP Briggs & Stratton I/C Engine With 6 Speed
Belt part number
Please whats the belt number or serial number for 2006 Hyundai Tucson v6? My own got cut n got lost cant find it or know d number to get a new 1. I also need the diagram to fix new belt.
this is the Dayco part number.this is the 2.7L 6 cylinder engine with A/C.the belt routing diagram is under the hood on the radiator shroud.this belt is $28.99 at Autozone.if needed they can print you a belt routing diagram on most vehicles,for free! Dayco Serpentine/Belt
  • Part Number: 5060790
Oct 31, 2015 | Hyundai Cars & Trucks
How long is the deck belt for a snapper riding mower LT 150H38IBV
Go to the Snapper Website, Go to Manuals/Parts lists, enter the model and serial number of the mower. Scan for the proper diagram, copy the belt serial number. Go to a belt specialty retailer, present the belt serial number. They should be able to supply the belt length, and probably the belt.
Sep 12, 2015 | Snapper Garden
Where can I get a belt and what is the part number
Have to use ur model number to get part number for belt,any where which salesmower parts should be able to help or once u get ur belt number search the net,butu have toknow which belt u need.
Aug 29, 2015 | Garden
What size belt does a Hoover Elite Rewind use?
The part number for the single belt is 38528040 or a 2 pack 40201190, the belt number should also be on the model number sticker and these can be ordered online or at a local vac shop
Sep 23, 2014 | Hoover Vacuums
Belt replacement
The part number is normally on the belt. You might be able to find an exploded view of your dryer on the internet, perhaps in an online manual, with the part number listed. Once you have the number you can google the number of go directly to the manufacturer.
I have found a number of parts this way.
Oct 29, 2013 | Danby DCD5505W Electric Dryer
NEED THE PART NUMBER FOR SONY TC-WE435 DUEL CASSETTE PLAYER BELTS
Flat belt part number is..
301657001.. BELT (CAPSTAN)
and square belt part number is...
302440501.. BELT (FR2)
Above said info are taken from TC-WE435 cassette player s/m.
Thanks.
Dec 25, 2009 | Sony TC WE435 Stereo Dual Cassette Deck...
Belt for Powermatic 15" Planer (Planer Model M-0460213)
Order the first one through Powermatic, then order any new replacements from the number on the belt. Or you can measure the pulley belt width and use a metal tape measure to find the total length by running the tape (number side in) over each pulley rim. Then order as a standard hardware source belt. Make sure the motor is bolted down about midway in it's mounting slots when measuring.
Sep 07, 2009 | Powermatic 1791210 Model 15S Deluxe Planer
I have a sanborn magna force 5hp air comp. The belt is missing and would like to know the length for replacement
The web address below will provide you with the information necessary to order a belt for your compressor. Check the model number first however to insure correct part.
http://www.mastertoolrepair.com/165tgc51b850tgb8p165tg51h850tgh8p-p-1454.html
I have replace the V belt on my compressor with an automotive type belt to save money (and better quality). I used a tape measure around both pulleys to get the length. Check the motor/compressor for adjustability as this will help when tightening the belt. If the motor/pump is already positioned all the way out, re-adjust to closed position and remeasure. Now for width of the belt; automotive belts are sold by length and width and use a common numbering system of five digits. The first two numbers printed on the belt refer to the width and the last three refer to length. Measure the width of the pulley grove. My pulley measured about 1/2" . Auto belts were available in 13/16", 15/16" and 17/16" widths. These belts are marked with first two numbers as 13 or 15 or 17. Next use the measurement around the two pulleys. My compressor measured 47 inches around the pulleys. So the automotive belt number for my compressor is 15470. If the measurement around the pulleys was 471/2" then the belt number would have been 15475. The last number refers to 1/2" either a (0) or a (5) Most autopart stores will ask you for the year and model of car for your belt but ask to see the belts with tape measure in hand and check for size using the numbering system for a guide. If your compressor uses a flat style belt you can buy from www.grainger.com. Measure around the pulleys the same way for length. Good Luck with your project.
Apr 13, 2009 | Air Tools & Compressors
I have a bissell 7.5poweramp uprite vacuum with a broken belt for the brush. What size belt would i need to fix this?
Not sure with having the model number, there may be a number on the belt, like style 7 etc. If no number, get me the model number and I can find out.
Feb 28, 2008 | Vacuums
Poulan 42-Inch Steel Deck 17.5 HP Briggs & Stratton I/C Engine With 6 Speed Logo
24 people viewed this question
Top Poulan Garden Experts
Roland W VanLue
Roland W VanLue
Phil Walker
Phil Walker
Are you a Poulan Garden Expert? Answer questions, earn points and help others
