Factory reset keeps crashing on me every time I try to use my pc
  • 27,725 Answers
Test your PSU power supply unit or replace it if your power supply units fan is not working your PSU is faulty
http://pcsupport.about.com/od/toolsofthetrade/f/powersupplytest.htm
Testing and replacing the PC power supply
http://www.youtube.com/watch?v=hbNxhvm0czs
One bad lead can cause a computer to continue on a cycle of restarting or to shutdown or fail to detect ,boot up a computer hard drive
WARNING Before you start troubleshooting remember that you are dealing with electricity that can KILL.
http://www.kitchentablecomputers.com/static.php - rules
Only work inside the computer case when the power has been switched off and disconnected. Never open the power source.
Some of the below steps recommend removing physical parts within the computer.
While in the computer it is highly recommend that you be aware of ESD and its potential hazards
Test all leads that attach to your hard drive power and data cables IDE ,SATA
the leads from your MOTHERBOARD TO YOUR HARD DRIVE make sure they have a secure dust free connections and are not faulty or just replace them they could be faulty
Make sure all leads that are attached to your dvd \ cd floppy drives have secure connections and are not faulty or just replace them they could be faulty.
Computers need power and data to travel through every working device to continue its cycle and have an end so any faulty leads will end up with a computer error.
Even something as small as a faulty electrical or fan lead can cause you problems
Motherboard and a Hard Drive any leads between them will fail before your motherboard or your hard drive if its a flat ribbon 40 pin type IDE replace it this will be the first to fail.
Check all electrical power input and extensions make sure they are securely seated even the cd/dvd floppy drives need to have current go through make sure these drives are working
also check the Cmos battery and computer RAM modules make sure they are securely seated with no dust built up or in the sockets on some motherboards cmos batteries are soldered in.
Check you CPU central processing unit make sure its securely seated and has thermal paste it might be getting to hot the thermal paste will help disperse the heat
Thermal compound is a sticky paste that is placed directly onto the CPU.
http://www.hardwaresecrets.com/article/Thermal-Compound-Roundup-February-2012/1490
Allowing for a more direct heat transfer between the CPU and HEAT SINK and preventing air gaps from forming between the CPU and heat sink.
Another possible reason could be a memory dump you might be running to many programs at the one time putting to much strain on the CPU central processing unit.
If you can get your computer stable enough
scroll to bottom toolbar bottom of screen right click select task manager
applications you will see whats running if you see anything you dont need running select end now
also under processes see what is ticking over again if you see something you do not need to be running end now or you might uninstall that program and some unnecessary programs
not having enough computer ram can cause memory dumps
If you are not sure if a module is right for your system use the Crucial Memory Advisor tool for a list of guaranteed compatible modules.
first you will need to select the manufacturer from a drop down list then select your product line from a drop down list then select the model then click find it will take you directly to compatible ram also you will have an option to scan your system
you should always for a guarantee on any ram modules when purchasing them or buy working pairs if possible.
You might have a virus or malware.
Download at least one of these of course it will depend on your operating system.
http://www.majorgeeks.com/Microsoft_Security_Essentials_for_Windows_d6242.html
microsoft security essentials your operating system must be registered
Win7/Vista/XP 64 bit
http://majorgeeks.com/downloadget.php?id=4281&file=1&evp=dbb3b0aebe6a6a4ff18089a6489a5e62 anti malware free edition Win XP/2003/Vista/Windows7
http://windows.microsoft.com/en-US/windows/products/security-essentials/product-information
malware protection
http://100-downloads.com/download.php?p=615
windows xp microsoft security essentials
http://100-downloads.com/download.php?p=614
windows 7 microsoft security essentials
Capacitors look like small metallic canisters and they are found in many different computer components including computer monitors, computer motherboards, video cards, power supplies and a variety of other consumer products.
A bad capacitor can cause a variety of computer problems, but if you can identify the faulty capacitor you may be able to replace it and save your computer.
Capacitor
Capacitors, sometimes also called condensers, are used to store energy in an electric field.
In the context of computing, capacitors are used to block the direct current being circulated around the motherboard.
A typical capacitor should last up to 15 years, but some computer manufacturers use substandard capacitors resulting in shorter lifetimes.
Computer Problems
When a capacitor has gone bad on a computer you may experience a large range of problems. The computer may have trouble booting up, or it may shut down without notice after running for only a short period of time.
The most common problems associated with faulty capacitors are that they cause unexpected computer crashes and general reliability issues ranging from read/write issues to distorted screen images.
Identifying a Bad Capacitor
To identify a bad capacitor you will need to open your computer case and locate the capacitors on your motherboard.
A bad capacitor may exhibit swelling at the top or the base of the capacitor or it may sit at an awkward angle with the motherboard, so compare the various capacitors in your computer in terms of size and placement.
Additionally, a bad capacitor may have a funny smell or it may have a brownish residue leaking from the top or the base.
Prevention
Manufacturers claim that capacitors may go bad because a computer is not receiving enough power from a power supply, because of an overclocked processor or because a computer is operating in an environment with too much heat or humidity.
However, some capacitors prematurely fail due to faulty work on the part of the manufacturer.
If you have a bad capacitor be sure to do research as to the lifespan of other products made by your manufacturer.
Identifying bad capacitors
http://www.youtube.com/watch?v=ngA4k32jLGc
Capacitor replacement
http://www.youtube.com/watch?v=s0Pn2tEjY04
How to check a capacitor
http://www.youtube.com/watch?v=U4tnHA0phcc
Replacing a leaking capacitor
Could be a problem with the Hard Drive or the Hard drives PCB
http://www.onepcbsolution.com/
http://www.youtube.com/watch?v=du0Qd_3wFWM
Posted on Jul 28, 2013
I have done afactory reset and reboot. when the phone restarts it keeps flashing up on the screen that google play has stopped working etc etc with all apps and connot get into the phone
Google Play Store not working? Here's what you can do ...
https://www.androidpit.com/google-play-not-working
Dec 19, 2015 - Google Play Store problems like crashing, freezing or lockouts can be fixed with these Play Store tips ... If you're still facing problems after having tried all of the above, then you may have little choice but to do a factory reset.
Can't open Play store after performing factory reset on Galaxy Ace ...
www.simplydroid.com/.../cant-open-play-store-after-performing-factory...
Nov 17, 2012 - 7 posts - ‎7 authors
We generally do the process for small issues but factory reset operation. ... Many timeafter factory reset registration to Google Play failed.
Google Play Store not working: How to fix it
www.ibtimes.co.uk > ... > Smartphones
International Business TimesOct 20, 2015 - Force closing the Google Play Store is the simplest way to fix random ... device to factory or stock settings by performing the Factory data reset.
Jan 19, 2016 | Google Cell Phones
My htc vivid keeps crashing and reboots already have performed factory reset a few times still n/g
try custom ROM from XDA forums. Google for it. Laos, be sure your phone is not under warranty. You cannot claim warranty for it later. This should definitely work.
Oct 22, 2013 | HTC Vivid
Asus 300t crashing
download UBCD (ultimate boot cd) and run @ boot. find memtest 86 and run the tests.if it fails you have bad ram. you should also make sure the fan is running and not getting stuck or anything. try to blow it out with compressed air.
May 28, 2012 | Computers & Internet
My phone is automatically switch off
Talking on the phone with a bluetooth headset and self-rebooted.
Playing abduction and crashed. Self-reboot constantly at the X screen
Took battery out for 15 second, and tried again, same thing.
Did it a second time to fix it.
- reading google.com/reader and crashed. Self-reboot constantly at the X screen
Did a factory reset to see if it helps.
During market downloads of apps, crashed again and rebooted
Phone used edge more than 3g lately in the past few days.
After factory reset, using 3g again.
Had the phone for 3 weeks, so the tech support guy said I can only get it repaired or replaced by a refurb unit...Sounds like a bad deal to me...
and to make it even worst, I bought the google dev g1 a few months ago before this...$1k down the drain...
Feb 14, 2012 | Cell Phones
Nimbuzz crashes on my nokia E5
Often times when apps crash it is due to memory problems with your phone. You should try resetting your phone to factory defaults and erase all your files. It would be a good idea to save anything important to a hard drive first though.
May 05, 2011 | Cell Phones
Keeps on crashing (shouting down with doing anything)
MAY HAVE VIRUS TRY FACTORY RESET IF U GOT THT OPTION ,CHECK YOU TUBE ON UR MODEL AND PROBLEM ,OR WORST CASE HDD FAILING
Jan 08, 2011 | Toshiba Satellite L455DS5976 Notebook
I can't open my messaging inbox it says 'already in use'
try the 3 finger reset after you have backed it up
Sep 22, 2009 | Nokia N96 Smartphone
Dell computer blue screen saying STOP
Try installing the operating system or repairing the operating system.
Feb 22, 2009 | Dell Computers & Internet
Computers & Internet Logo
32 people viewed this question
David Payne
David Payne
