Question about Westinghouse Protege 52" InstaLoc Ceiling Fan 72190
I have a InstaLoc 72023 ceiling fan. I am trying to locate the following parts; 3 blade brackets Part #72806-12
How do I remove/replace blades on a Harbor Breeze fan?
The blades (wood or fiber board) usually attach to a metal bracket with a 90 degree bend in it by 3 small screws. This bracket is then attached to the fan with two more screws. At times I have loosened the 3 screws using a long screw driver. Other times it's easier to unscrew the two screws that attach it all to the hub. Unless you can bend the metal parts back into their normal position and replace the fan blades with ones of equal size and weight, you have a tough job ahead of you. You might be better off replacing all the blades at once, to guarantee their length and weight. I'm an extreme recycler and when I see someone getting rid of a fan, I pick up all the parts for the future. You can get yourself fan blades, glass globes that go over the light bulbs or whatever you might need this way.
Oct 12, 2014 | Dryers
Bent ceiling fan blade brackets
This is what you need to do:
So how do you contact the Hampton Bay Replacement Parts Department?
Simply call 1-877-527-0313 then select option #2. This department will then help you find the replacement part you need for your hamton Bay product.
Dec 23, 2012 | Dryers
Who made an M52 series ceiling fan? 5 blades, 4 lights
I have a 52" A.C. Ceiling Fan, M52 Series, Fan 82F4, 120V, 60 Hz 1.0A, File No# E143948, TR/HD: 0596, Serial No# 026351-027900, and have had the fan stored for awhile now and it seems I've misplaced/lost, the mounting bracket that fits inside the cover where the stem and ball are located and mounts to the bracket box inside the ceiling. Any ideas of where I can find one so that I don't have to purchase an entire new ceiling fan (again). I've tried 2 ACE Hardware stores, Home Depot and Lowes and no one carries them.
Jan 31, 2012 | Dryers
Hunter breeze low profile ceil fan, 5 blades 3 lights, Wobbly
Can you describe the mounting bracket for this fan?
If it is a ball mount, then there is a groove in the ball that connects to a tab in the mounting bracket. if the tab is gone or the ball is not sitting down in the bracket so that it is secure , then that is the problem. You may be able to find a replacement brachet in a home depot type store .
Please Vote !!
May 26, 2010 | Hunter 20436 Beacon Hill White Ceiling Fan
Are there replacements parts available for a model AM-1 6 blade fan ser #005727 (fan blade brackets)
can you tell me if it is possible to use short rod instead of long rod because it is too low? 52" ceiling fan portland II
Mar 03, 2010 | Dryers
I need a blade bracket for a brushed nickel finish
You will only be able to obtain a replacement from either a Minka Dealer that happens to have one in stock, or from Minka directly.
As the Minka is very restrictive with their distribution, it would be best to contact them directly with a request for a replacement part/
Here is the web site for Minka and you can see your model, the Acero, listed on the ceiling fan section. If you look at the bottom of the page, you'll find a "contact us" link that you can use to request information about getting your replacement part. There is also a "dealer contact" link at the top of the page, so you can locate a nearby dealer that might be able to order the part for you, etc.
http://www.fixya.com/PostAnswer.aspx?thid=3102757&prdid=120103&ref=unsl
Hopefully you'll be able to get the replacement blade bracket, as your fan model is still in production, and as such, should have spare parts available.
I hope you'll find this Very Helpful and best regards!
Oct 04, 2009 | Minka Acero Brushed Nickel Ceiling Fan
I have a 4 blade HB cieling fan. 2 above 2 blades. Where to put the reciever seems to be no room. Instructions were missing.
The receivers in my 3 hampton bay fans actually slides into the upper portion of the hanging bracket ( the thing you screwed into your ceiling fixture that the fan hangs off of)..
It fits rather nicely once you make room for it with the wiring etc
Hope this helps.
Jul 07, 2009 | Hampton Bay 24002 Ceiling Fan
Fan Parts Hunter Fan Type C Model 25436 No. 017626
Cool Breezes Cool Breezes carries parts for old fans that Hunter no longer carries parts for COOL BREEZES 1335 W Campbell RdRichardson, TX 75080
(972) 690-4580push2talk //-->
Sep 18, 2008 | Dryers
Ceiling fan replacement parts
Here is the link for SOME parts for Minka Aire Fans. They don't necassarily need the model number, just the balde dimensions for replacement. Hope this helps you.
Mar 23, 2008 | Dryers
Westinghouse Protege 52" InstaLoc Ceiling Fan 72190 Logo
37 people viewed this question
Top Westinghouse Dryers Experts
stevensmn
Level 1 Expert
Are you a Westinghouse Dryer Expert? Answer questions, earn points and help others
