Foxconn lga775 672m01-1.1-8eksh ddr2 mb manual
I need to hook up the front panel need a manual
SOURCE: memory upgrade from ddr 256mb to ddr2 1g
mhtml:http://www.foxconnchannel.com/upload/Compatibility/200703291139540676P4M800P7MA-MEM-070212.mht
Posted on Apr 15, 2008
SOURCE: Need Diagram of front panel hook up for Aopen AX6LC
Still need help with this problem!
Posted on Oct 13, 2008
map9966
  • 2351 Answers
SOURCE: Need manual for MSNV-939 MB
Hi hickoryhi138,
The motherboard your referring to is made by Mach Speed.
Click on the link provided & scroll to the bottom of the link to download the manual; http://www.machspeed.com/specs/MSNVspecs.pdf
Drivers are also listed on the link.
For the manual (Only), click on the next link; http://www.machspeed.com/manuals/MSNV-939manual.pdf
Go to page 19, Header for Front Panel Facilities: JPANEL1
Knowing what wire color is positive & which is negative varies from case to case. Check the group of front panel wires. Most likely one wire from each 2-pin connector will share the same color. Like the color white which is common for ground/negative. Other colors, blue, green & red are commonly positive. The only exception is the speaker wires. Mach speed only uses two wires across four pins. Black is most common for ground & red is for positive.
Good luck hickoryhi138!
Thanks for using FixYa.
Need more information? Post here.
Mike
Don't forget to vote.
Posted on Mar 14, 2009
  • 20 Answers
SOURCE: I lost my user manual and how to connect the front panel?
go to foxconn support website and you can download a copy of the manual for this motherboard
Posted on Jul 10, 2010
  • 206 Answers
SOURCE: Dear All! Where the heck I
Click here to go to foxconn support manual download all the way at the bottom of the screen.
Posted on Aug 10, 2010
Please help, need drivers! ACPI x64-based PC Microsoft Windows 7 Ultimate Processor: AMD Sempron,1800 MHz (9 x 200) 3200+ Motherboard: Foxconn K8M890M2MA Series (2 PCI, 1 PCI-E x1, 1 PCI-E x16, 2 DDR2...
This sounds like one of those store bought computers - Dell, HP, Asus, Acer, etc - is there a brand and model number available if so - these sites will have all the drivers for the particular model.
May 01, 2017 | Computers & Internet
Problem With ddr2 (Upgrade From ddr 512mb 400 to ddr2 1gb 800)
If it works fine with one stick of ram. Then it is the ram that is incompatible. You can try different settings but you may end up that the stick isn't compatible. Hope this helps let me know if you have any other questions.
Thank you,
Lee
Nov 05, 2009 | Foxconn P4M800P7MA-RS2 Motherboard
Can i use ddr2 on my Foxconn l s-36 motherboard?
Could not find that MB listed. My suggestion would be to go to http://www.crucial.com/ and run their scanner. It is safe and will tell you what you have what your MB will hold and what kind of RAM it takes.
Thanks for using Fixya.
Aug 29, 2009 | Foxconn Computers & Internet
Foxconn n15235 memory support?
The Foxconn n15235 isn't the correct designation.This is a propritary designation from EI SystemsFont Definitions */ @font-face {font-family:PMingLiU; panose-1:2 2 3 0 0 0 0 0 0 0; mso-font-alt:新細明體; mso-font-charset:136; mso-generic-font-family:roman; mso-font-pitch:variable; mso-font-signature:3 137232384 22 0 1048577 0;} @font-face {font-family:"\@PMingLiU"; panose-1:2 2 3 0 0 0 0 0 0 0; mso-font-charset:136; mso-generic-font-family:roman; mso-font-pitch:variable; mso-font-signature:3 137232384 22 0 1048577 0;} /* Style Definitions */ p.MsoNormal, li.MsoNormal, div.MsoNormal {mso-style-parent:""; margin:0cm; margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:12.0pt; font-family:"Times New Roman"; mso-fareast-font-family:PMingLiU; mso-bidi-language:AR-SA;} @page Section1 {size:595.3pt 841.9pt; margin:72.0pt 90.0pt 72.0pt 90.0pt; mso-header-margin:35.4pt; mso-footer-margin:35.4pt; mso-paper-source:0;} div.Section1 {page:Section1;} --> the motherboard in your system is actually a Foxconn’s P4M800P7MB.
User Guide can be downloaded here.
http://www.foxconnchannel.com/support/downloads_detail.aspx?ID=en-us0000569
System Memory
· Two 240-pin DIMM slots
· Supports DDR2 533/400 memory
· Supports 128 Mb/256 Mb/512 Mb/1 Gb technology up to 2GB
Jan 27, 2009 | Foxconn 6627MA-RS2H Motherboard
Foxconn P9657AB motherboard installation problem
You're Foxconn board uses the Award bios.
The long beeps you are hearing are telling you there is a problem with you're memory.
You're pic does not look like the Foxconn P9657AB-8EKRS2H MB as shown in the user manual. Found on This link.
http://www.foxconnchannel.com/product/Motherboards/detail_overview.aspx?ID=en-us0000297
The pic on Foxconn's site does but not the manual listed.
The motherboard uses four 240-pin slots with 1.8V for DDR2 memory only.
(Question? Did you're ECS MB use DDR2 memory)?
If you have more than 1 DIMM installed remove all but 1.
Move the DIMM into the closest slot next to the CPU.
Boot the PC & check for beeps. If still presant move the DIMM to the next slot & try again. Continue this through all four slots. Than try another DIMM. If the mother board continues to beep as mentioned than call Foxconn. (There is a bios update mentioned below for memory).
The CPU may come into question. (It’s revision). You may have to call Foxconn for this information. (580-272-0035). They do not place this information in their user manual. Most users have to call. The rev of the CPU may conflick with the memory causing you to receive the bios beeps. (I have had to return 2 boards for this reason). I picked an Asus board over Foxconn.
I have come across this with Foxconn motherboards these past two years. Suggest you update you’re bios. Foxconn has a revision dated, 3-28-2008 for memory before you call. After bios update test the memory again for beeps. Still there? Return the board is my suggestion.
It’s a guess that the red led will go away after the memory issue has been addressed. Normally there is a green led on most motherboards. This means standby. The board has power connected. I could not find any reference in the user manual * .pdf, for R450.
Good Luck ninjo61!
Mike
Jun 20, 2008 | Foxconn P9657AA-8KS2H Motherboard
Memory upgrade
Hi Dave,
Foxconn 945G7MA-8KS2
Memory (Page 10 in user manual).
This motherboard includes four 240-pin slots with 1.8 V for DDR2. These slots support 256 Mb, 512 Mb and 1 Gb DDR2 technologies for x8 and x16 devices, and support maximum memory bandwidth of 8.5GB/s using DDR2 533 memory,
10.7GB/s using DDR2 667 in Dual-Channel interleaved mode, You must install at least one memory bank to ensure normal operation.
Need you're manual? Click on the link below.
http://www.foxconnchannel.com/support/downloads.aspx?ProductModel=945G7MA-8KS2&TypeID=en-us0000001
Foxconn 945G7MA-8KS2 motherboard main page link.
http://www.foxconnchannel.com/Product/Motherboards/detail_overview.aspx?ID=en-us0000024
To upgrade with 1GB. This includes S/H. (Free S/H).
http://www.zipzoomfly.com/jsp/ProductDetail.jsp?ProductCode=80098-35
TigerDirect less S/H. (S/H not included).
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=1026780&CatId=1647
I did find others for less on the surface. Untill you go to check out & get slammed for shipping (ground), falls between $4.99 to $9.99. I use Corsair myself. Never had a problem.
Have more questions, feel free to ask.
Mike
Apr 18, 2008 | Foxconn (945G7MA-8KS2) Motherboard
Memory upgrade from ddr 256mb to ddr2 1g
there is a jumper setting to slect which type of memory you want to use, check your manual for details on how to change it
1> enusre the rams are in correctly
2>ensure your main board supports the amount of memory and the speed of the memory
3> verify jumper select to correct memory type is set correctly
if the main board aint compatable with the memory you brought that will cause the same problem
Jan 02, 2008 | Foxconn P4M800P7MA-RS2 Motherboard
Computers & Internet Logo
256 people viewed this question
David Payne
David Payne
