Question about Waterpik SWI 615 Sinusense Water Pulsator Includes 15 Soothing Saline
What soap do you use to clean a Waterpik SWI 615 Sinusense Water Pulsator?
The instructions specify "dish detergent" but they don't specify which kind of soap. I'd like to get this right considering I use this thing to shoot water up my nose.
  • 2,113 Answers
All detergents are basically sodium laurel sulphate or sodium loreth sulphate. Even toothpaste, hand soap, bar soap, laundry soap, dish soap contains this ingredient.
It allows oils to mix with water by reducing the surface tension so as to make the water molecules (packets) smaller. By doing so the molecules can get at and dissolve oils where it could not get to previously.
Water is already the worlds greatest universal solvent (every element on the periodic table has been found dissolved in water). Sodium laurel sulphate is toxic though and should never be in the human body and perhaps should never even touch the skin as it might be adsorbed.
It makes you wonder about toothpaste. No wonder they give instructions for children's use to not use more than the size of a pea. They suggest to rinse thoroughly. Detergents don't kill bacteria. They just help wash them away. Detergent washes any food that the bacteria may eat.
Keeping an item dry is the best way to kill bacteria. Antibacteria soaps will just help create a super bacteria or super virus. It will just make things worse over time.
Basically use any detergent... rinse well... keep it dry, and avoid the antibacteria soaps.
Posted on Nov 20, 2013
What bottle brush do you use to clean a Waterpik SWI 615 Sinusense Water Pulsator?
Any bottle brush will do if it fits into the unit to do the job. If the bristles are polyester or another kind of plastic it will not absorb bacteria. Wash and rinse the brush well after use and don't use it for anything else.
Jul 27, 2013 | Waterpik SWI 615 Sinusense Water Pulsator...
Pump running but water won't go through
I had the same problem for the longest time until today. I took a super soaker squirt gun (hand style with single pump on top) and shot it up the hole wear the water intake is for the pump (on the bottom of the white plastic part that has the trigger and water pump inside) while holding the trigger down to have the pump running, too. Did it a couple times for good measure. ;) When I tried it with the tank attached, it worked again. After that, I ran some rubbing alcohol through it to clean it up a bit but you could probably use hydrogen peroxide or distilled white vinegar as well. I'm guessing that the salt and baking soda mix eventually builds up and plugs it. Definitely plan on keeping the squirt gun handy in case it happens again. Hope this helps.
Dec 19, 2011 | Water Pik Waterpik SWI 615 Sinusense Water...
Built-in dishwasher. dishes not clean, plus nasty white residue on everything...
Hi
The white residue is from the new environmentally safe soap. Check your soap and see if it is phosphate free soap and that will be your issue. Also either you have hard water or you're seeing either calcium or lime deposits. You should use the jet dry for every load. There should never be any suds in a dishwasher. Do not use liquid dish detergent for the dishwasher.Try running a load without dishes, using vinegar, or a bottle of Dishwasher Magic. Another possibility could be you're not getting enough water. The level should be close to the heater(check your tech sheet to be sure). The water temp should be at least 140 deg.F (no matter what the box says) Also, use a good brand of detergent (Cascade) and be sure your wetting Agent dispenser is full. (jet dry)You should not have to pre-wash your dishes..just scrape them well.The detergent actually needs some dirty dishes to work properly..fats, protien, etc. to make up 1 more chemical for the detergent.Another important step is to run the hot water faucet before running your d/w to "purge" the cold water out of the line.
Also check this links for some helpful information:-
http://www.appliance-repair-it.com/dishwasher-leaves-white-film-on-dishes.html
http://askville.amazon.com/dishwasher-washes-dishes-clean-white-residue-problem/AnswerViewer.do?requestId=6117170
http://lgknowledgebase.com/kb/index.php?View=entry&EntryID=6192
Please get back to us if you have further query else please accept this particular suggestion.
Thanks for contacting fixya.com
Aug 23, 2011 | Kenmore 16602 / 16604 / 16609 Built-in...
My dishwasher doesn't seem to be washing the
Hello
Water Inlet Valve
A dishwasher's water inlet valve is its most common part to fail. When your dishes are not being fully cleaned, quite often a faulty water inlet valve is to blame. Test your dishwasher's water inlet valve, and if it is no longer functioning as it should, you will have to replace it.
Upper or Lower Spray Arm
Your dishwasher has a lower spray arm. It may also have an upper spray arm at the top of the dishwasher. These spray arms are designed to shoot high pressure, high temperature water at your dishes. It is possible that the holes of the spray arms, where the water comes out, are blocked with debris, affecting wash quality. You should inspect your dishwasher's spray arms regularly. Clean out the spray arms as need be.
Heating Element
Water temperature is a key element in achieving clean dishes. A dishwasher's heating element is not designed to heat the water that enters it. Rather, the heating element is designed to maintain the heat of the water that enters the dishwasher. Its a good idea to run the hot water in your sink for a couple of minutes before you run the dishwasher. Just to make sure the water is nice and hot before it enters the dishwasher. If the water is unable to stay hot, it can adversely affect your dishwasher's cleaning ability.
Filter/Drain Grate
There is a filter in your dishwasher. Its function is to keep large particles of food and foreign objects away from the pump. Many of the newly-manufactured dishwashers have self-cleaning filters, and routine cleaning isn't a concern. However, some other dishw ashers need to have the filter removed and cleaned regularly. If the filter or grate is clogged or blocked with debris, it may interfere with the normal functioning of your dishwasher. Consult your owner's manual for specific directions for removing your dishwasher's filter and cleaning it.
Detergent or Detergent Cup
It could just be that you aren't using enough soap to completely wash your dishes. Your dishwasher may be designed to dispense soap at two different times during the wash cycle. If you don't fill all of the detergent cups, then the diswasher will lose a cleaning cycle. Also, if you use a gel-type detergent, try switching to a powered kind. Powders tend to dissolve better in hot water. And don't buy in bulk. Detergents are most effective in the first two weeks. After that, they decrease in potency.
Alternatively, your dishwasher's detergent cup could be defective in some way. It is possible that it is gunked up full of built up detergent, and a thorough cleaning may be enough to get it working again. If that doesn't do the trick, you probably need to replace the entire detergent cup assembly. If your cup isn't even opening, please see our section My dishwasher detergent cup won't open.
Aug 09, 2011 | Viking 24 in. Professional Series VUD040...
I have a Kenmore built-in dishwasher and just recently when I take the dishes out there are food particles or residue on the dishes after the wash. I changed from capsule soap to liquid soap thinking that...
Do you have hard water? Many states have passed laws that outlawed phosphate as an ingredient in dishwasher detergent. If you have hard water, the detergents don't work very well anymore. The residue is probably hard water deposits (calcium and magnesium). Not harmful but it looks awful on your dishes. There are some new products that were designed to solve this exact problem. They are inexpensive and effective. Can't say the name or I'll get banned (again). Internet search will uncover it.
Jul 20, 2011 | Kenmore 13742 / 13744 / 13749 Built-in...
Dishwasher does not clean dishes. Some soap remains in soap dish. Have tried on the enrgy saver cycle and 1 hour cycle.
Hi jerry1413,
Firstly, make sure you are using powdered soap, and not the 3 in 1 tablets. The 3 in 1 Tablets only release certain parts of itself on certain temperatures, and because all dishwashers aren't alike, they won't have the best of results on all makes & models. Cycles aren't run the same way on every Make, and don't follow the same order either. Trust Me ;-) , stick to Powder.
Furthermore, check the following link for some advice and suggestions on getting your dishwasher to clean properly again:
WHAT TO DO IF YOUR DISHWASHER ISN'T CLEANING WELL ANYMORE...
Kind Regards :-)
* If you found this solution helpful, please rate it?
Jun 18, 2011 | Kenmore Elite Stainless Steel 24" BuiltIn...
I have a Maytag dishwasher with sanitize, steam clean, etc. Should I use powder or liquid detergent?
It is best to try a few different ones... different detergents work differently with the different dishwasher/water combo's... ya can never tell what the best soap will be till ya try them in your DW with your water...
Also get some TSP and add that it will help the soap work better...
DishwasherResidue and Film on Dishes
heatman101
May 04, 2011 | Maytag Dishwashers
Soap residue on glasses, dishes & flatware...what can I do..I use Cascade & JetDry
Instructions Things You'll Need:
  • Vinegar or lemon juice
  • Gel dishwasher detergent
  1. dishwashers have a rinse aid dispenser. If your dishwasher has this dispenser, fill it up periodically and it will release the appropriate amount of rinse aid automatically at the right time during the wash cycle. This will help your dishes rinse more cleanly.
  2. Rinse aid in solid form
    Some older dishwashers or basic models do not have an automatic rinse aid dispenser. In this case, you can buy rinse aid in solid form that attaches to your dishwasher rack. Solid rinse aid can be hard to find in stores because it is not commonly used, but it can be purchased online.
  3. Vinegar or lemon juice
    Appliance repairmen will tell you that one of the common problems they see with dishwashers is the buildup of excess detergent. If there is too much detergent in your dishwasher, your dishes will not rinse cleanly, no matter how good the dishwasher is or how much rinse aid you use. To clean the excess detergent that has built up inside your dishwasher, put 3 tablespoons of vinegar or lemon juice (concentrate is fine) in the empty dishwasher and run the dishwasher through a complete cycle with no dishes. Do this twice, for two complete cycles of the empty dishwasher with only vinegar or lemon juice added. The acid in the vinegar or lemon juice will break up the detergent that has built up in your dishwasher's interior.
    After you have cleaned the detergent buildup from the inside of your dishwasher, follow the steps below to keep the buildup from happening again and to help your dishes rinse cleanly and prevent residue from accumulating on the dishes.
  4. Gel dishwasher detergent
    Switch to a liquid or gel dishwasher detergent. Any brand will do.
  5. Fill one compartment half full Dishwashers will effectively clean dishes with much less detergent than manufacturers often recommend. The bleach in the detergent, combined with the extremely hot water used in the dishwasher wash cycle, will clean and sanitize your dishes completely, even in small amounts, and using less detergent helps prevent buildup and residue from accumulating on your clean dishes.
    Fill only one detergent compartment(the one that snaps closed) half full with gel detergent. Snap the opening closed and run your dishwasher as you normally would. Your dishes will come out sparkling clean with no buildup or residue, plus you'll save money by using less detergent!
Feb 02, 2011 | Dishwashers
Dishs are duty and glasses have white film & dirty
If your dishes or glassware appear with a white film or a white powdery residue or spotted following a complete wash cycle, adjusting the amount or type of detergent you?re using and adjusting your hot water heater?s water temperature may solve the problem. But before you do either of these, put a rinse additive (such as Jet-Dry) in the rinse dispenser to improve the sheeting action of the water.
Next, you?ll have to determine whether the film is removable or permanently etched. To do this, soak a glass in undiluted white vinegar for about 15 minutes. Or, wash the glass with warm water and concentrated dishwasher detergent or a high-phosphate detergent (such as Glass Magic).
If the film comes off, it is probably caused by hard water minerals, improper amounts of detergent, or unsuitable water temperature.
Permanent etching is often caused by a combination of soft water and excessive heat or detergent. If glassware is permanently etched, there isn?t anything you can do to make it clear again. But you can avoid future etching by taking these steps:
1) Be sure hot water entering the dishwasher is no hotter than 140 degrees F. Don?t use extra-hot settings such as ?Power Scrub,? and use the ?Energy Saver? dry cycle.
2) Adjust the detergent amount.
3) Don?t pre-rinse your dishes before loading them in the dishwasher. Food particles on the dishes actually help the detergent and drying agents clean better.
A common cause of poor washing results is improper loading?dishes that block or impede the spray arm(s) or prevent the soap dispenser from opening. On the other hand, if your dishwasher has chronic problems with good washing, the problem may not be your dishwasher. A good first step is vary the amount of dishwasher detergent you're using and try switching brands.
Other possibilities: Your home?s water pressure may be too low, your water may be too hard, or the water temperature may not be hot enough.
In order for your dishwasher to fill to the appropriate level, water pressure should be from 20?120 pounds per square inch. If you suspect that your water pressure may be low, turn off all faucets or other users of water (such as washing machines and sprinklers) and then put a half-gallon jug under the kitchen faucet. Turn on the hot water full-blast. If the jug doesn?t fill within 14 seconds, your water pressure may be too low for proper dishwasher operation. Call your city water utility to discuss your options, or avoid drawing water elsewhere in the house or yard during dishwasher cycles.
The right amount of detergent to use depends on how large your load of dishes is and how hard your water is. Hardness is measured in grains of minerals?the more grains per gallon you have, the more detergent you?ll need. If your water has 12 grains or more of hardness, fill both dishwasher soap cups completely with detergent. If that doesn?t work, consider installing a water softener. (For more information, see the article Water Softener Systems.
To check water temperature, hold a meat thermometer under the hot water faucet for two minutes; if it doesn?t register a minimum of 140 degrees F., turn up the temperature dial on your hot water heater. (However, if you have a newer dishwasher that heats the water internally, it isn?t necessary to turn up your hot water heater.)
If your dishwasher has worked fine in the past but suddenly your dishes aren?t clean after the dishwasher completes all cycles, listen to the spray arm(s) spinning inside during the wash cycle. If spinning poorly, wait for the machine to cool down, remove the spray arm(s) by unscrewing the hubcap(s), lifting the arm(s) off, and then cleaning out the spray holes in the spray arm(s) with a stiff piece of wire.
Please rate the solution if you feel I've helped you
Jun 10, 2010 | Whirlpool Gold 24 in. Built-In Dishwasher...
Detergent is left in dispensers and dishes are not clean.
make sure you are getting hot water to D/W might also try different soap
Oct 26, 2009 | Dishwashers
Waterpik SWI 615 Sinusense Water Pulsator Includes 15 Soothing Saline Logo
667 people viewed this question
Top Waterpik Health & Beauty Experts
Andrew Taylor
Andrew Taylor
Jay Plesset
Are you a Waterpik Health and Beauty Expert? Answer questions, earn points and help others
