Question about Garden
Starter cord on lawnmower will not pull out
The starter cord on my lawnmower will not pull out. It seems like it is stuck. I am pulling back on the blade control like I'm supposed to.
    Sergeant:
  • 340 Answers
Hi Mary. You will need to remove the starter box on your mower. The coil box may be rusty or the pully may need fixing. Try using some oil spray and see if the pully now works. If the starter coil is clean the mower may be ceased.
Posted on Jul 29, 2013
2 Suggested Answers
  • 6468 Answers
SOURCE: Lawnmower hit a stump and now can't pull starter cord
you may have bent the crank shaft if it pulls hard and pulls back then remove the flywheel and check the key
Posted on Apr 02, 2012
My starter cord will only pull out about 6 inches and then it's stuck...
If the recoil will only pull out a little and it appears to be good when you removed it, then pull the plug on the engine and pull the recoil rope 3 times all the way. Important - watch the plug hole each time to see if black debris blows out. Then squirt 1 time WD40 in the cylinder head thru the plug hole. Clean, gap the plug or replace if required. LM19 I think, plug is marked. RE-install plug, attach laminator connector. Pull recoil rope again, should be free if engine isn't seized. Make sure oil has been changed this year, 30W, and is full. Check air filter also while you are doing this basic maintenance.
Jun 19, 2016 | Honda HRX217VKA Lawnmower
I have a Snapper self-propelled lawnmower and The starter cord will not pull out to get it started. What do I do next?
Hi Patricia,
There is probably a safety lever that has to be pulled back toward the handle in order to release the flywheel. (This lever is on the top side of handle.) Once you have it firmly against the handle it should start. To stop the mower, simply release the lever. There may also be a 2nd lever to engage the self-propelled (located under the handle). It may be difficult to start with this one pulled.
Jim
May 23, 2016 | Briggs & Stratton Garden
Fix recoil when pull cord on sanli lawnmower broke
Take the starter assembly off the mower. Unwind the spool using whatever method works (2 screwdrivers?) until you capture the remaining. cord. Pull it all the way out. Pin the spool so that it can't retract. Remove and replace the cord. Re-assemble. Back to cutting grass!
Mar 15, 2015 | Garden
Pull cord on my lawnmower is inoperative
You need to take the Starter cord assembly off and see if the Nylon gearing that 'grabs' the centrifical wings is broken OR those wings are rusted in a way that they do not make contact with the nylon piecs of the Starter.
Dec 07, 2012 | Craftsman 55 Torque 158cc 22" Push Lawn...
Apr 01, 2012 | Garden
Try to pull cord but seems seized on my self propelled lawnmower
Look underneath at your blade - it could be bent and hanging up. If not, remove spark plug and try to pull starter cord. If it won't move then you may have seized the motor and a new mower may be in order.
Hope this helps!!
Nov 16, 2010 | Toro Lawn Mower With Toro Power Tools
Pull start won't pull, seems stuck.
When you pull the cord it will turn the blade. Therfore if the blade is stuck or clogged with clippings the starter cord will seem stuck. In addition, the throttle on the handgrip need to be fully depressed for the starter cord to work. Last, some mowers have a saftey which lock the starter if the wheels are engaged. Hope this helps. Bob
Apr 11, 2010 | Garden
Craftsman Walk behind lawnmower how to replace the starter pull string
Remove cowling to acces pull start assembly. Have new cord on hand. Remove old cord fragments. Wind rotor 4-5 revolutions to tension spring and hold while threading new cord into slot. Knot new cord and slowly let it wind back into assembly.
Jul 09, 2009 | Yard Machines 158cc Push Lawn Mower #11a...
Garden Logo
147 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
