Question about Samsonite Silhouette 11 Hardside Spinner
Need Wheels D02(0)18075 STREAMLINE MPC
I need to purchase and install 2 of the 4 wheels on this bag
2 Suggested Answers
SOURCE: Ref. Model D02(0)19083 Streamline MPC
GO TO SAMSONITE.COM THERE IS A SECTION WHERE THEY GIVE YOU A 800 NUMBER TO ORDER PARST
Posted on Nov 13, 2010
How to replace wheels on hartmann garment bag
Some wheels are attached to the bags through screw or bolts, which are securing hardware and easy to remove. When such wheels need replacement, you can replace them by yourself. Some are attached to the bags through rivets, which require you to ask for professional removal and repairing service in case that they are broken. Some wheels of rolling garment bags can't be removed and replaced.
Aug 21, 2012 | Cars & Trucks
I need to put in another steering collum and I dont know how to do it.its a 91 ford F150.hope you can help me.I got another one out of the junk yard for 125,00 is that a good price .thanks for helping my...
I'd say $125.00 is a good price for a steering column.
First, have to remove steering wheel (but I don't have instructions for the steering column. For that, maybe try alldata.com, but that will cost):
STEERING Steering Wheel REMOVAL & INSTALLATION Without Air Bag EXCEPT F-SUPER DUTY STRIPPED CHASSIS MODELS AND MOTOR HOME CHASSIS MODELS Fig. 1: Remove the screws from behind the wheel - F-150 model without air bag 88288p12.jpg
Fig. 2: Pull away the cover with the wiring still connected 88288p13.jpg
Fig. 3: Disconnect the wiring at the steering wheel 88288p14.jpg
Fig. 4: Matchmark the steering wheel 88288p15.jpg
Fig. 5: Remove the center nut from the steering wheel 88288p16.jpg
Fig. 6: Use a steering wheel puller to remove the wheel 88288p17.jpg
Fig. 7: Remove the steering wheel from the shaft 88288p18.jpg
Fig. 8: Correct steering wheel installation 84928058.gif
NOTE: The factory recommends that the front wheels be set in the straight-ahead position and you paint or make chalk marks on the column and steering wheel hub for alignment purposes during installation. Of these two safeguards, it is more important to mark the column so even if the column is moved slightly, the steering wheel can still be repositioned in its original position.
  1. Disconnect the negative battery cable.
  2. Remove the one screw from the underside of each steering wheel spoke, and lift the horn switch assembly (steering wheel pad) from the steering wheel. On vehicles equipped with the sport steering wheel option, pry the button cover off with a suitable prytool.
  3. Disconnect the horn switch wires at the connector and remove the switch assembly. On trucks equipped with speed control, squeeze the J-clip ground wire terminal firmly and pull it out of the hole in the steering wheel. Don't pull the wire out without squeezing the clip.
  4. Remove the horn switch assembly.
  5. Remove the steering wheel retaining nut and remove the steering wheel with a puller. WARNING
    Never hammer on the wheel or shaft to remove it! Never use a knock-off type puller.
  6. Install the steering wheel in the reverse order of removal. Tighten the shaft nut to 40 ft. lbs. (54 Nm)
F-SUPER DUTY STRIPPED CHASSIS MOTOR HOME CHASSIS MODELS
  1. Set the front wheel in the straight-ahead position and make chalk marks on the column and steering wheel hub for alignment purposes during installation.
  2. Disconnect the negative battery cable.
  3. Remove the one screw from the underside of each steering wheel spoke, and lift the horn switch assembly (steering wheel pad) from the steering wheel.
  4. Disconnect the horn switch wires at the connector and remove the switch assembly.
  5. Remove the horn switch assembly.
  6. Remove the steering wheel retaining nut and remove the steering wheel with a puller. WARNING
  7. Install the steering wheel in the reverse order of removal. Tighten the shaft nut to 30-42 ft. lbs. (41-57 Nm).
With Air Bag Fig. 9: Remove the air bag module and disconnect the wiring harnesses 88288g00.gif
CAUTION
Read the air bag service precautions in Section 6 prior to doing work involving an air bag equipped steering column component. Always wear safety glasses when servicing an air bag vehicle and handling the air bag to avoid possible injury.
  1. Turn the front wheels to the straight-ahead position.
  2. Disconnect the battery-to-starter relay cable for at least one minute to let the air bag back-up power supply discharge.
  3. Remove the air bag module from the steering wheel (refer to Section 6).
  4. Disconnect the horn/speed control wiring from the steering wheel.
  5. Remove the steering wheel retaining bolt.
  6. Install the Differential Bearing Cone Remover/Replacer, No. T77F-4220B1, or equivalent, and remove the steering wheel. Route the contact assembly harnesses through the steering wheel as it is lifted off of the shaft. To install: NOTE: Make sure the front wheels are still in the straight-ahead position prior to installation.
  7. Route the air bag sliding contact wiring through the steering wheel at the 3 o'clock position. Position the steering wheel on the shaft an align the marks. Make sure not to pinch the contact wire. WARNING
    Make sure no air gets trapped between the steering wheel and air bag sliding contact.
  8. Install a new steering wheel retaining bolt, then tighten to 23-33 ft. lbs. (31-45 Nm).
  9. Connect the horn/speed control wiring and clip in place. Connect the air bag wire harness. Tighten the module retaining nuts to 35-53 inch lbs. (4-6 Nm). NOTE: When the battery cable has been disconnected, then reconnected, some abnormal driving symptoms may occur for the first 10 miles (16 km) until the PCM re-learns it adaptive strategy.
  10. Connect the battery to starter cable. Verify the air bag warning indicator light on the instrument panel.
Sep 24, 2010 | 1991 Ford F150
Need rear wheel for my chicco litewat stroller
Hi, With he Chicco strollers there are at least 2 mechanisms for the rear wheels. You need to check which versions you have. 1) you will find a metal ball press stud on either side Of the chassis. Take a screw driver and push that metal ball in as far as you can to clear the housing for the wheel. Then pull the wheel away from the chassis. 2) Repeat for the other side 3) if both rear wheels come away WITH two a v shaped hinged metal rod then you can simply replace the rear wheels. I have seen them on eBay. 4) if yours pulls away and the hinged bracket has a material strap to it then these are not meant to be removed or at least I would not necessarily recommend that but of course the choice is still yours. You may need to purchase a replacement chassis again can be purchased on eBay. Hope this helps. Liz.
Jul 29, 2010 | Chicco Liteway Stroller by
I purchased a Polaris 3900 on 6/2/2010 and have already replaced two filter bags. Both times the bag has become wedged between the chasis and the wheels tearing the bags. Any suggestions?
First, make sure that the velcro closure on your pool cleaners bag is sealed tightly. If the velcro is coming lose, it could be the problem. Next, make sure that your wheels are operating at the proper RPM. Too little RPM could cause the pool cleaner to be sluggish and not create the proper tension to keep the bag floating. It should be between 30 and 36. If it is running at less than 30 RPM, there are few things that you can do to fix it. If an adjustable valve is installed on the cleaner line, open it completely so water can flow freely to the cleaner. Check the filter screen in the in-line filter
for debris that restricts water flow and clean if necessary. Also clean the skimmer, filter, and pump baskets. Check the hoses, connections and swivels for leaks that cause loss of water pressure. Finally, if none of these solutions work, remove the blue restrictor disk from the UFW.
Jul 02, 2010 | Polaris 3900 Sport Pool Cleaner ()
My rear wheels keep poppping off. I've hammered and glued, but they won't stay on. Do I need new wheels or a new axle assembly?
Greetings,
You may need to just purchase the the little c-clips that hold the wheels onto the axle. Kirby Vacuums actually have a hub cap on their rear wheels that can be removed to access the axle end with the c-clip. If you take a flat head screwdriver, and pry off the plastic part of the wheel off of the rubber part, you should be able to see the end of the axle. There should be a little tiny c-clip at the end of the axle that holds the rear wheel in place. Is that clip there on both sides?
If yes, then you may need to replace the entire axle assembly. If they are missing these clips are available for purchase through many online websites including our own, govacuum.com.
If this repair didn't fix your Kirby, please contact me, I'm happy to try and diagnosis this further with you. If it did help, please rate the repair as helpful, thank you.
Chris J.
Mar 13, 2010 | Kirby Ultimate G Bagged Upright Vacuum
Where can I get replacement wheels?
Greetings from GoVacuum.com,
I just wanted to let you know that we are an authorized Riccar dealer, and we can certainly get the replacement wheels for your Riccar 4812 upright vacuum cleaner.
We stock some parts, and what we don't stock we'll order for you. We don't currently have the wheels on our site, but if you still need the wheels, you may email me at chris.jones@govacuum.com.
We do stock a lot of parts for your 4812 Riccar, including the following;
Riccar 4000 Series Bags That Fit the 4812. Paper Bags 12pk.
http://www.govacuum.com/ricc103.html
Riccar 4000 Series Exhaust Filters for the 4812 Part RF4-2;
http://www.govacuum.com/ricc117.html
Riccar 4000 / 8000 Series Drive Belts Part # A20-R2P
http://www.govacuum.com/ricc112.html
Foam Filter Underneath of Bag Riccar 4812 Part B622-0500
http://www.govacuum.com/ricc133.html
I look forward to helping you if you still need to get the wheels for your vacuum.
Thank you,
Chris J.
GoVacuum.com
Jan 11, 2010 | Riccar 4812 Vacuum
Need to check turn signal contacts in column,
Best thing to do, honestly, is to purchase a chilton's or haynes manual when you are working around the air bags. Better safe than sorry.
Mar 14, 2009 | 1992 Buick LeSabre
Samsonite Silhouette 11 Hardside Spinner Logo
46 people viewed this question
Top Samsonite Luggage & Travel Experts
ray gallant
Tom Chichester
Are you a Samsonite Luggage and Travel Expert? Answer questions, earn points and help others
