Question about Bissell Powergroom Pet Vacuum
How to attach pet tool adapter? Do I disconnect the flex hose (handle end)? If so, how?
  • Official Brand Answer
  • 315 Answers
Hi Sarah! The flex hose doesn't need to be removed to use the pet tool adapter. Just attach the pet tool to hose and begin vacuuming.
Posted on Jul 31, 2013
2 Suggested Answers
rylee_smith
  • 8619 Answers
SOURCE: clogged hose...
Hi!
Low suction, poor pickup, or no suction may be due to a clog in the vacuum cleaner. If you notice a change in the sound of the motor or a reduction in the spinning action in the Dirt Container, check for clogs. Unplug cleaner from electrical outlet. Empty Dirt Container. Check Upper Tank and Louvers for build up or clogs. Check to make sure Louvers are installed correctly. To unlock the Louvers, grasp the rim and turn toward the left. Pull straight down to remove. If the Louvers are missing or not locked into place, check and clear the tube in the center of the Dirt Container. Remove the Twist ‘n Snap Hose from the vacuum by turning to the left. Check the Suction Inlet, Hose and Hose Wand for clogs. Remove any clogs from the hose using a long, narrow object. Check the Foot Hose for clogs. If needed, remove the screw attaching the Hose Wand Base to the vacuum. Straighten the Foot Hose and unclog with a long, narrow object. If the clog persists, then check the Rotating Floor Brush the Air Passageway for obstructions.
Please do rate this solution as FixYa and revert for further assistance.
Thanks
Rylee
Posted on May 10, 2009
I need to print how to assemble a bissell proheat shampoorer
First locate screw pack (you will need a Phillips screwdriver). 2 long Phillips screws with hex nuts, 2 short Phillips screws. Should be taped to under part of handle.
2, Put upper handle into lower handle.
3, feed the power cord through the tool caddy from the flat side. Place caddy to handle so the hex shaped holes on upper portion.
4. Place the hex nut in the hex shaped hole and insert long bolt through the front of the handle. Do the same on the other screw and tighten them snuggly. Be careful not to over tighten them.
5. Insert small screws into lower 2 holes through the back side of the lower hose rack. Turn until tightened.
6. Attach tool(s) (that would be a small brush or the pet brush attachment to end of hose and on the attachment holder on front of upper handle.
7. Wrap hose around large holder closest to handle and power cord is wrapped around outer holder with rotating clamp.
Hope that helped
Dec 11, 2015 | Bissell 9500 ProHeat 2X CleanShot Upright...
Remove handle from hose electrolux
You don't have to "remove" the handle from the hose to attach other attachments, just depress the tab at the end of the hose and pull the upper wand loose then use the "adapter" to use the dusting brush or simply snap the crevice tool in place to use. If the handle won't come loose from the upper wand, then the described "tab" needs replaced as it's locking up the parts. Hope that helps!
May 17, 2014 | Electrolux Vacuums
Remove hose from 66T6
I know how frustrating this can be. Try turning the hose and wands in opposite directions where they connect. Once the hose and wand is separated you'll be able to connect the pet hair attachment.
Here's a quick link to obtaining a copy of the user guide if you've misplaced yours:
http://www.bissell.com/user-guides/?cid=ccsocial
Feb 07, 2013 | Bissell 66T6 Pet Hair Eraser Cyclonic...
I disassembled the handle to attempt to remover the slip in upper half of handle. (did not figure out how to do tht). Now on re-assembling the handle, I cannot figure how the trigger is held secure to...
HI.These are the steps that may be helpful since you haven't describe the brand of your unit.Open the storage door at the front of the vacuum.Redmove the powered hand tool. Set it aside.Unsnap and remov any attachmets at the attachment storage area.Unclip and remove the wands from the vacuum and set aside.Pull the end of the hose from the hosed tube rack.Twist the other end of the hose from the dirt duck tube.Remove the hose.Unscrew the back of the handle.If you can't remove ,it is held tightly with nbuts located at the back of the compartment bag.Pull the handle carefully from the vacuum.If it has a non built cord wrap,slidethe wrap straight up from the handle too detach it before removing the handle.Once done assemble back.Thank you for choosing fiXYA.
Jul 31, 2011 | Vacuums
WHEN WE USE THE HOSE ON THE VACUUM DUST AND PET HAIR COME OUT OF THE HOLE HELP
A clogged hose is the most likely problem. Disconnect hose at both ends and try dropping a coin through it. If clogged, use a broom handle to push clog back through.
If the hose isn't blocked, check the tank where the hose attaches. Just inside clogs often form. Clean if necessary.
Check the filter, and change if dirty.
Mar 02, 2011 | Bissell Vacuums
How do I attach a mini turbine head to my dyson dc07 upright?
Remove the handle / hose / wand assembly like you were going to use the tools. The mini turbo brush will attach to the open end of the wand.
Apr 14, 2010 | Dyson DC07 Bagless Upright Cyclonic Vacuum
The tool attachment won't spray water-
you almost have to open up the unit and follow the hoses from the handle into the base.fill it with solution and turn on pull triger.hold the triger in and turn off the unit keeping the triger pulled.turn off and start it up and try again.if it don't spray you might have a bad pump.open up the unit and see if all the hoses are hooke up.there should be a plug on the handle .is it plugged in.please leave feedback.i hope i was some help to you...pet
Apr 26, 2009 | Hoover SteamVac F5914-900 SpinScrub...
I have borrowed a kirby from my friend and i would like to wash my couches, please would you be so kind as to assist and let me know what tools i would need to use to be able to do so??
You need the upholstery attachment (it looks like a trigger sprayer with a plastic jar attached)You MUST have the foam screen that fits on the front of the trigger,without it,you will only get solution.The trigger sprayer fits on the end of the hose.The other end of the hose fits on the blower end of the machine.You must remove the bag,and attach the hose at this end.The trigger sprayer deposits the foam,and you work the foam in with a soft cloth or brush.When dry,switch the hose to the suction side,and vacuum out the foam.There is also an adapter (about the size of a styrofoam cup) that attaches to the front of the machine to allow it to be used when using the hose on the blower (bag) side.
Dec 14, 2008 | Vacuums
Eureka Capture Vacuum
Either the filters are clogged, the hose has a clog in it, or the dirt inlet down by the brush roll is clogged. Pull the hose off and see if you have suction at the end of the hose, that will tell you which way to look for a clog.
Feb 18, 2008 | Eureka Capture Upright Vacuum Vacuum
Bissell Powergroom Pet Vacuum Logo
51 people viewed this question
Top Bissell Vacuums Experts
Jim Parker
Jim Parker
Are you a Bissell Vacuum Expert? Answer questions, earn points and help others
