The display showed COMM ERR on the screen. Oven won't turn on. Now error display goes away but sometimes shows up and will show COMM ERR or sometimes it will show just a bunch of jargon. The display doesn't stay on for long. Any idea how to reset the oven?
SOURCE: GE Profile oven beeps and displays FO
Your electronic oven control(clock) is bad and must be replaced.
SOURCE: GE JBP45G oven display module keeps on showing
I can easily explain the "PF". It means your EOC or electronic oven control/timer is losing power for some reason, hence the "PF", for power failure.
I`d suspect the control itself is defective or at fault as they have built in transformer`s that can become faulty.
I would first insure your power supply cord is secure and in good condition in the wall or you don`t have loose wires going to the timer.
Hope that help`s move you forward, let me know if I can assist you further.
Good luck.
macmarkus :)
SOURCE: oven does not work,no display.
the display board itself would be the culprit,the part might be under warranty,if under 5 years consult manual or manufacturer for coverage....the part is probably expensive
Testimonial: "It appears as though this will require a repair person with all the parts. Nothing I can do on my own. Thank you for the input."
SOURCE: Touch pad for the oven does not work
eith touch pad or control board un plug the touch pad if it returns the board is bad if it dont the touch pad is
SOURCE: error code
The E1- F5 error is a door lock error.
The control (TIMER) has likely failed in this instance - BUT...
Sometimes when you disconnect power to a range and reconnect it the electronic range control gets confused.
You should disconnect power again for 15 seconds and reconnect and see if that helps.
If it doesn't cure the E1- F5 error hold the bake button in until E0- F2 appears in the display.
This is the error for a stuck button on the keypad and is the way to clear the memory of the electronic range control.
Sometimes these work, but if the control has failed it won't make any difference.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.T$%^%ETG
Hello & Welcome to FixYa
F7 error code is displayed when the clock assembly/electronic range control (ERC) goes bad and needs replacement. Please get back to me if you have any other questions.
Kevin
