Question about Janome Sewing Machines
Bobbin case makes a scratchy noise when sewing, worse at higher speeds. When I 'pretend' to sew without the bobbin holder in place to try and diagnose where the noise is coming from, there is no noise when the needle goes up & down. When I insert the bobbin holder, without the bobbin and the needle goes up & down and there is this scratchy sound as the bobbin case rotates, like its rubbing the housing area. Have cleaned the whole machine, oilled it and changed the needle. The tension seems not right too... threads not looking accurate.
    Problem Solver:
  • 17 Answers
Have you checked to be sure the needle is inserted correctly? Try turning it.
Posted on Jul 27, 2013
  • 323 Answers
SOURCE: Janome memory craft 5700, purchased 2004
Take out your bobbin case and examine it for nicks, scratches and or rough spots.If the problem is not too bad it may be possible to buff out the bad spot with an emery stick or emery cloth. If that isn't possible or it makes too much noise after you buff it you will have to replace it. Look especially along the edges and underneath.
sewman7
Posted on May 23, 2008
SOURCE: Thread in needle or bobbin keeps on breaking
The tread only breaks in the needle. what can i do . i don't get to sew anything . I tread the needle and get everything ready and start the machine and as quickly as that the tread is broken and the machine has not sewn at all.
Posted on Apr 07, 2009
  • 323 Answers
SOURCE: can't reinsert bobbin holder
There's probably still some thread or lint inside the race (where the hook Goes). Remove the hook, and look for discolorations in the race. Use your finger nail not a screwdriver to remove these. They are bits of thread.When you finish put a drop of oil on the hook. Sew it off on scrap fabric. sewman7
Posted on Apr 27, 2009
SOURCE: Needle hitting bobbin casing when sewing.
your needle is too long
Posted on Nov 29, 2009
kirkx
  • 2019 Answers
SOURCE: I have a janome 8050
The key to proper stitches is that tension on the bobbin must equal the tension on the upper thread spool as well. The bobbin has a tension screw that may have come loose or the thread is not properly in the tensioner. For example, the bobbin could be in backwards. Or the tension of the top could be too light and allowing the tension on the bottom to pull the thread down too much.
Open the bobbin tray and watch while you slowly rotate the hand control to see it make a stitch.
You will probably be able to figure out what is wrong.
Posted on Apr 08, 2011
Top thread is hanging up somewhere under feed dogs. With and without bobbin in place. Any suggestions.
1. Make sure to adjust the bobbin tension. Also, make sure the bobbin is correct for the machine. If it is too tall it will surely have problems. (see attachment for bobbin tension adjustment)
2 Always thread your machine with the pressure foot up. As you thread give gentle tugs to check for hang ups. This has to be corrected.
3. Adjust the top tension to four to begin with. Final tension adjustment can be made when you give a trial sew.
*Always oil race w/one drop of oil before the bobbin case is placed back. This is done only about every 10000 stitches.
Aug 14, 2015 | Brother XR 7700 Computerized Sewing...
Noisy bobbin bounces in case
If you just had serviced a month ago I would take back and tell them to fix the problem you did not have before they serviced it, or try calling maybe then can advise over the phone.
Jul 17, 2017 | Sewing Machines
Husqvarna making squeaking noise
try changing the needle
try a different bobbin--make sure the bobbin is turned the right way
in the bobbin case
also try a different thread
make sure the top has not come off the thread take up lever
also the machine may have a timing problem and need to be
serviced
Dec 08, 2012 | Sewing Machines
Loud clunking noise when sewing. . . then it starts to stutter then it stops & gives me an error. It doesn't occur when reverse sewing though
try these suggestions
change the needle
rethread the machine top & bobbin
make sure to use every thread guide
make sure the bobbin is not damaged or warped
make sure the bobbin is not over full
make sure the bobbin is inserted correctly into the bobbin case
make sure the bobbin case fits securely into the machine unless it's
a drop in bobbin
if these suggestions don't help then the machine may need to be
checked at a repair shop
Sep 11, 2012 | Brother CS6000i Computerized Sewing...
Bobbin case is moving and making noise
then the bobbin case may need to be replaced, you can either take the machine
to a sewing machine shop to have it checked to see what wrong with the machine
& make sure it's the bobbin case or buy a new bobbin case & see if that solves
the problem & if it doesn't then you'd still have to take it in to be checked
Apr 27, 2012 | Brother XL-2600I
Rattle in the bobbin area.
make sure the bobbin is not warped or damaged
also make sure the bobbin fits securely in the bobbin case
does the bobbin case fit securely in the machine?
the bobbin case could be getting old & might need to be replaced.
Apr 12, 2012 | Sewing Machines
My brand new Janome Sewist 500 is making noise - it's clunking as I sew. I'm sewing two layers of cotton twill, stitch A, length 2, tension 5. Help!
have you checked to see if the bobbin is in the bobbin case correctly
is it still under warrenty? you might want to take back to the place you bought it from & let them check it
Mar 09, 2012 | Janome Sewist 500 Sewing Machine
E6 error code on cs6000i
it's possible that it's a mechanical or electronic problem or something has worn or is loose, it needs to be serviced
Feb 06, 2012 | Brother CS6000i Computerized Sewing...
Makes too much noise
Check that your needle is fully up into the needle housing, and is in flat shank to the back.
Also change the needle if it has been in the machine for more than 6 hours of sewing as the needle will go blunt and this can make squeaking or popping sounds as you stitch.
Lastly, are you sure that the bobbin case is in correctly and hasn't been put in incorrectly. It should have a stitch finger which locks up into the top of the rotary hook if its a vertical bobbin case and bobbin design which I'm pretty sure your machine is.
Jul 27, 2010 | Elna 2005 Mechanical Sewing Machine
Loud noise while sewing
Could you let us know which machine this is.....
In the meantime....the damaged bobbin is not good, replace it/them........if you have a top loading drop-in bobbin, check for needle damage on the plastic bobbin case (remove needleplate to access).
If there is evidence of needle strikes, if mild, you could try to use very fine wet & dry emery paper to smooth, if severe, buy a new bobbin case.
There may be a load of lint under and around the bobbin case too, remove and clean up this area. If very dirty, use methylated spitit on cloth or cottonbud (QTip) to remove grime (don't soak)
Bargainbox
Jan 27, 2008 | Sewing Machines
Sewing Machines Logo
149 people viewed this question
Top Janome Sewing Machines Experts
Tally Girl
Tally Girl
Douglas Plant
Douglas Plant
Irene Tulloch
Are you a Janome Sewing Machine Expert? Answer questions, earn points and help others
