Question about LG Televison & Video
Lg 22ls4r hdtv screen flickers
Hi i recently purchased an lg 22ls4r hdtv and when i connect it to cable/sky tv the screen flickers and goes purple/blue/red for 5-10 secs before going back to normal, also if watching the same channel for a period of time it does the same thing flickers and washed out purple colour. please can you help?
    New Friend:
Disconnect the TV from your sky box and watch TV with just aerial. If this cure the problem, then it is the sky box that may cause the problem. If not then your TV has a problem. Check the colour setting and make sure it is not in saturated mode. Otherwise take it back to the shop.
Posted on Jan 08, 2018
5 Suggested Answers
SOURCE:
SOURCE: Polaroid FLU-2632
I had the same problem. It's caused by the picture setting on your Sky box. Go ibto Services, select Picture Settings and set the mode to PAL not RGB.
Posted on Jul 19, 2007
SOURCE: LG LCD Flat screen 32 screen blank red light blinking cable on
The Lg lcd was srtruck by a remote and now looks like a small crak on the inside towards the bottom right hand corner and there is no picture but audio does work
Posted on Nov 09, 2008
  • 20 Answers
SOURCE: 42 LG Plasma picture distorted and flickering
replace the control module.
Posted on Mar 11, 2009
yammy_alf
  • 666 Answers
SOURCE: RCA 37" FLAT SCREEN NON STOP FLICKERING/FLASHING SCREEN
you need to remove main ckt, (m.board) some part need to re solder specially in hot area. (lost contact i one of the flickering problem you encountered.
Posted on Mar 26, 2010
Crackle Then Stop
Check the firmware on the tv. I would imagine youre connected with hdmi, and some tv's (lg, vizio mainly) have had firmware issues. check teh lg website for updates.
Jul 01, 2012 | LG 32LG30 32 in. LCD HDTV
Lg 42pc1dv have just purchased a lg bluray player and hdmi cable selected corret socket get the picture ok but no sound, all works fine on daughters tv.
hi. i have the same problem with my sky HD box and the same lg tv as you,
did you solve the no sound through HDMI.
Nov 25, 2010 | LG 42LC2D 42 in. LCD HDTV
I have a LG 50PX1D-UC plasma TV with a black vertical line
You could have a Driver Board that has a loose connection or a Ribbon Cable that has a intermittent connection to the Plasma Panel, or a defective Plasma Panel. Either one could cause the problem and I would recommend only a Qualified Service Person to check it out.
Here is LG's Customer Service Number. 1800-243-0000. They could direct you to a Local Service Facility.
I hope this helps,
Sky Assoc
Oct 25, 2009 | LG 42PX5D 42 in. Plasma HDTV
LG 42LC2DB LCD TV Flickers when Ps3 is connected via HDMI port
Make sure you have the PS3 set to the correct frequency for the TV. Many cannot accept 1080p / 24fps etc.
Try different settings.
I hope this helps.
Mar 28, 2009 | Televison & Video
Tuning to pick up sky feed
Sounds like from discription the sky feed is set up for analog channel 6. With my TV-HVR-1600 card, there is an option in the wintv application when you click the menu button in the application that says channel suite. If you select this option, you should find and option for analog source. Select analog source in this screen and you should be able to manually add channel 6 in the box at the top of the analog souce screen. Also if you have the sky feed connected and you you click the scan button on this screen, it should detect automatically is the sky feed is on.
Aug 20, 2008 | Hauppauge WinTV HVR-1600 - ATSC HDTV...
Screnn going blank
sounds like sky tv issue, try different cabling
Jun 02, 2008 | Samsung HP-R5072 50 in. Plasma HDTV
Lg plasma
there are 2 types of flicker, one is the lamps that drive the display and the second is the sync signal of the video.
I assume the video sync is the flicker you see,
I would try connecting a different way to make sure it is not the tv,
connect using the aux /rca connectors to cable box.
and or connect using the cable direct bypassing the cable box.
I have seen several complaints about the hdmi cable signal being incorrect in some way,
this is the same issue that the svideo connector had in its early adoption signal was too hot or too low.
another thing to watch out for is the low light sensor on the front of tv if it gets an incorrect reading it can flicker the back light though it should be slow in doing so.
some times the flicker you see is not flicker but ac running through the sides of the picture from an ungrounded cable source.
how does it perform if you play a dvd player , with and without the cable box connected.
Apr 29, 2008 | LG 42PX5D 42 in. Plasma HDTV
Plasma
if your tv is on warranty take it back to best buy for a replacement.good luck
Apr 27, 2008 | LG 42PX5D 42 in. Plasma HDTV
Sky+remote code for my lg tv
The cose you need is 0206
Sep 15, 2007 | Televison & Video
Televison & Video Logo
190 people viewed this question
Steve Allison
Steve Allison
