Question about Dryers
Creda TVR2 dryer making noises during drying
The dryer is one years old, and is making noises during drying - see clip at: http://imageshack.us/clip/my-videos/547/my1hysjlljfrwthlccbocw.mp4/
  • Galili Galili Jul 27, 2013
    I just want to add that it dryes clothes well, and does not have any other problem. The machine doesn't move while drying.
  • 686 Answers
SOURCE: Loud Noise While Drying
Your rear drum bearing is dried up and need to be re-gresed with high temp grease
Posted on Mar 04, 2009
pumpkinman
  • 1165 Answers
SOURCE: Ge Dryer making loud rumbling noise
drum bearings are going up
Posted on Jun 19, 2009
SOURCE: Re-Hoover nextra8 hnc380 Tumble dryer
Had this problem with mine. Its the belt tensioner pulleys that have seized and cause the noise.I got 2 net tensioners and fitted them myself.The parts come to about £15 but its a total strip down to replace the parts. been working fine now for about a year
Posted on Oct 08, 2009
erpaalai
  • 999 Answers
SOURCE: Dryer is making a rattling noise.
Rattling could be anything from a bad idler or support pulley or coins in the vanes. If you can hear it you can find it pretty easily.
Eric
Posted on Jun 13, 2010
heatman101
  • 43501 Answers
SOURCE: GE Electric Dryer DBXR463EG0WW making loud griding noise when on
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryer Repair Squeaks, Grinding, Clicking and Knocking Noise
heatman101
Posted on Sep 29, 2010
Hi I have a Creda Simplicity TVR2 tumble dryer, the drum is rotating ok but it doesnt get warm air going through it. the drying process takes a lot longer than usual. Is this something we can repair...
hellojean, the problem may be down to the heat sensors these's usually 2 of them and they are located at the back of the dryer with wires attach to them.you need some 1 with a multimeter to test them if 1 is faulty change both of them.if theses are ok the the element is the next thing to test hope it helps
regards
shaun
Sep 20, 2011 | Dryers
My creda mode tcr2 isnt drying my clothes anymore
If your dryer is not drying like it once did or if you just have nottaken the time to give yourself a clean dryer in a long time then youneed to do that. At least once a year the dryer cleaning should takeplace. Lint build up in the dryer duct is one of the main causesfor your dryer to fail.
Here is the rest of this tip about DryerMaintenance
heatman101
Jul 30, 2011 | Dryers
My Creda TVR2 will not start
Hi
If you have the machine powered on and on button on.
The only other thing is to ensure is the door is fully closed as there is a safety interlock on the door.
Try pressing the door firmly but harder and see it machine starts.
Please dont forget to vote this answer was helpful and accept it.
Many thanks
Feb 17, 2011 | Dryers
My creda tvr2 only spins one way.. does anyone know why it won't spin in the opposite direction!!
sounds like a timer fault, the reverse contacts in the timer are not making contact.
Apr 06, 2010 | Dryers
Snapped belt
Watch the video and it will give you the idea, it may be a different model but it's all about the same to replace.
Nov 06, 2009 | Dryers
The belt is broken on my creda tvr2 tumble drier and i dont know where to get to it to replace it
If you are in the U/K, then got www.hotpoint.co.uk, and follow the links.
Please rate my solution.
Thanks.
Nov 01, 2009 | Dryers
Frigidaire LEQ332DSO Squealing Noise
sounds like rear bearing is dry you will need to remove drum to get to it pop clips in top and raise 2 phillips scews 1 in each side remove front remove belt from drum lift drum up in rear and remove ck to make sure plastic bearing is not worn down to metal bracket if it is it will need to be replaced
Jul 07, 2008 | Frigidaire GLER341A Electric Dryer
Creda
remove the rear panel screws, remove side panels, pull drum backwards, slide belt down front of drum and under, refit rear panel screws refitting drum at the same time, place belt around motor spindle and reasemble, job done.
Dec 24, 2007 | Washing Machines
Connection of new circuit board to creda tumbe dryer TVR2
Nee
d more info. Need dryer brand, model and serial numbers.
Nov 09, 2007 | Dryers
Dryers Logo
Top Dryers Experts
