Question about Audio Technica Audio-Technica ATH-M45 Headphones
Fix headphone wire
The right channel is out. My guess is it is the wire
I WHICH TO PURCHASE SOME HEADPHONES FOR SRF 59
follow this steps and fix it. God bless you
    • 1
Locate the faulty connection along your cord. Plug in your headphones and play sound through them as you jiggle the cord at various points to locate what part of the cord is cutting in and out.
    • 2
Cut the cord using wire cutters an inch or so past where the fault in the cord is. If this is at the connector, cut the entire connector piece off. If it is near the headphones, cut off enough to eliminate the faulty section and still allow the cord to be reconnected.
    • 3
Strip the end of the cut cord. There are three wires in the cord: the left channel, the right channel and the ground. The left and right normally are colored, and the ground is bare.
    • 4
To repair a poor connection where the cord meets the headphones, match the wires with the correct leads coming from the earpieces and twist them together. Wrap the wires with electrical tape.
    • 5
To repair a bad connection at the connector jack, acquire a new 1/8-inch connector and attach the cord's inner wires to the appropriate points on the connector. Connect the left channel wire to the tip, the right channel wire to the ring, and the ground wire to the sleeve. Solder all the wires in place.
    • 6
Connect the headphones to a sound source and test for proper function. Jiggle the cord at the new connection to make sure it is secure and does not cut in and out.
Oct 27, 2013 | Sony Audio Players & Recorders
Bose quietcomfort 15 right headphone stopped working
My guess is that the flimsy wire connection inside broke. I have worked on Bose earphones that do not even have any strain relief provisions.
Jun 25, 2017 | Bose QuietComfort 15 Headphones
I recently bought Conga Wesc headphones but I have a problem with the extension cable. When I listen to music without the extension cable works both audio channels but when I connect the extension cable...
Since the problem goes away when you don't use the extension cable, the cable is the trouble. One of the wires inside is broken. A new cable is what you need.
Jul 04, 2011 | Wesc Conga Headphones
Audio jack has malfunctioned in headphones
You might cause more damage to it, please find a local electronic repair shop near you and let then check it.
Jun 06, 2010 | Philips SHP 2500 Consumer Headphones
Loose connection in Bose headphones
Cut the ******** and replace it with a new one. You will need to solder the wires on to the new one. Keep the old one, cut it open and it will tell you which wires go to which terminal.
Jan 06, 2010 | Bose QuietComfort 2 Consumer Headphones
Hello, the channel of the right ear does not work
It's more than likely a small wire that has snapped inside the cable due to stretching it's probaby not worth fixing as the wires are very small and delicate ,nowadays people just buy a new set of headphones.John
Jul 30, 2009 | Dynex Behind-the-Head Headphones for Apple...
No sound in right ear
Check for a loose connection in the wire. Wiggle (carefully) the wire around both the headset where it sits on your heat. Also, check the other end (plug) to see if there are any shorts. If this simple "wiggle" test shows nothing, there may be a problem with the driver (speaker) in the right channel in your headphone.
Another thing to check and this should be obvious: make sure your balance on your stereo/receiver is set to be in the middle and not to the left.
Mike
Nov 21, 2007 | Technics RP-HP1200 Headphones
Right speaker channel low, both front and and back, even the headphones
There might be a levels adjustment in the setup menu for distance or something, might check that before opening unit up.
Jul 08, 2007 | Sony STR-DE445 Receiver
Audio Technica Audio-Technica ATH-M45 Headphones Logo
27 people viewed this question
Top Audio Technica Audio Players & Recorders Experts
 Grubhead
Grubhead
Greg Cann
Greg Cann
Clif Roberts
Are you an Audio Technica Audio Player and Recorder Expert? Answer questions, earn points and help others
