Question about Samsung SyncMaster Computers & Internet
Pink and Green Horizontal lines across screen
Samsung SyncMaster P2350, I have a feeling it is a hardware problem, but I would like to have someone else give me an opinion
  • 221 Answers
Normally, horizontal lines on an LCD or LED monitor indicate a bad control board inside the monitor. However, occasionally the problem can be caused by loose or bad cable connections. The only things that you can really do is to disconnect both ends of the monitor cable and reconnect them firmly. Also, you can disconnect the monitor cable completely and just leave the power cable. With only the power cable attached, you can turn the monitor on and off. The monitor should have a "startup screen" or display a message that says something like "Video Cable Disconnected". If the green and pink lines are still present without your computer connected, then the monitor has gone bad. The good news is that Samsung SyncMaster monitors usually carry a 3 year warranty, whereas most monitors only have a 1 year warranty. You may be able to have the monitor replaced at no cost to you if it's less than 3 years old.
Posted on Jul 27, 2013
SOURCE: a thin horizontal line across the screen
I know I have seen thin lines in the past on older CRT monitors, these are usually wires which support the aperture grill. LCD is just a panel so this must be something different. What color is the line? It is probably an error in the scanning process.
Posted on May 10, 2007
SOURCE: A pink vertical line appears suddenly on the screen
i have a samsung 15inch monitor.which is only 6month old.giving blue vertical line along the right side of monitor (almost 2 inches from right side) how to remove it plz someone help me.my mail id is kakhilesh83@yahoo.com.thank you..
Posted on Apr 04, 2008
alvinbga
  • 130 Answers
SOURCE: samsung syncmaster 204b
Yes. There is no vertical deflection. The circuit that controls vertical deflection is bad. This is an easy fix for a TV tech. Take it to the TV repair shop.
Posted on Jun 20, 2008
SOURCE: Samsung Monitor Syncmaster 913V Montior Screen shows patches of screen on desktop and playing videos
try to reset the monitor to its default settings.
Posted on Aug 24, 2008
SOURCE: Ghosting, Flickering, Green Sparkeling Lines, Color Washout.
I had a similar problem on a different monitor and fixed the green sparkles by selecting a lower refresh rate.
Posted on Sep 06, 2008
How do I correct pink and green bands accross HP-R4252 Plasma TV
First of all try, changing the input device to some other and see whether you see the same problem. Then connect your present input to a different TV and see. If you feel the input is ok, and it is a problem in the display, this is a case to be handled by a qualified service technician.
Jul 16, 2012 | Samsung HP-R4252 42 in. Plasma HDTV
I have Samsung syncmaster 943N and have problem with vertical line in left corner of the screen??
You need to contact Samsung Customer Support toll-free at 1-800-726-7864, or visit www.samsung.com/us/support/ for Live Chat, e-mail, and Twitter support options.
Jun 25, 2012 | Samsung SyncMaster 943N/943NX
My SyncMaster 2233 has problem, it has two straight lines, one blue, one pink, across the screen, from top to the bottom. I'd like to know how to get rid of it.
If the lines are very thin, they are broken pixels. You have to replace the monitor. I've heard of people taking their finger and trying to rub the lines out, but I have never had success with this before.
Sep 13, 2011 | Samsung SyncMaster 2233BW 22" LCD Monitor
I have purchased Sony Bravia LCD BX 42, which has a very thin horizontal line across the screen, how to fix the problem
my sony bravia BX42 has a color green horizontal line and it makes bigger and bigger until some color pink was appeared then I am worried if it will not turn to normal as it goes :(
Aug 29, 2011 | Sony BRAVIA KDL52XBR2 Television
VGA connector wiring detail
Pink - red input - pin 1 green - green input - pin 2 blue - blue input - pin 3 ground shield wire - pin 6,7,8 and 10 black - ddc 5v - pin 9 violet - screen raster - pin 11 white - data or sda - pin 12 orange - clock or scl - pin 15 yellow - vertical signal - pin 14 clear - horizontal signal - pin 13
Sep 11, 2009 | Samsung SyncMaster 753S 17" CRT Monitor
Sounds like a hardware problem. You should probably return it as soon as possible.
Dec 19, 2008 | Sony VAIO® VGN-AR370N12 PC Notebook
Aug 15, 2008 | Samsung SyncMaster 204B 20.1" LCD Monitor
Solid line completly across screen, monitor is brand new
Your comp's video card refresh rate (in Hertz, abbreviated Hz) may not be totally compatible with the monitor. Check the properties of your video card, and change the refresh rate (you may have to look around for it) to 60 Hz. This is a pretty standard refresh rate that works with just about every monitor. If it's already there, I'm afraid someone else will have to try and help!
Hope this helps, and please rate my answer, good OR bad.
Feb 04, 2008 | ViewSonic OptiQuest Monitor
Samsung syncmaster 204b
Dec 14, 2006 | Samsung SyncMaster 204B 20.1" LCD Monitor
Computers & Internet Logo
365 people viewed this question
Top Samsung Computers & Internet Experts
Computer Repairing
Computer Repairing
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
