Question about Skil 7 1/4" Magnesium "Mag 77" Wormdrive Saw With Twist Lock Model # SHD77M 72
Center bolt spins freely
Had to replace the outer flange/blade clamp on my Model 77 Skilsaw as it cracked from fatigue. I found the correct replacement part but now I find that the center bolt that hold the blade clamp on just spins freely. Easy fix or major repair?
    Top Expert:
  • Skil Master
  • 49,170 Answers
There was probably a hole in the flange that you discarded that was used to put a pin/ nail/ bolt/ etc in from the body of the saw to hold that flange from turning while you did the nut up. Unless that hole is there you will have no way of holding the shaft to tighten the nut.
Posted on Aug 04, 2013
2 Suggested Answers
brewerstool
  • 141 Answers
SOURCE: I need the outer flange/blade clamp for my skil model 77 type 16
The replacement part is 1619X02969. And you can get it from directly from boschtoolservice.com ($3.75).
Posted on Oct 13, 2009
Finding a part for my skilsaw model77 type 16 I need a outer blade clamp/outer flange they stopped making them
check for other makes as many manufacturers use a generic part here
Skill is part of another company as well
It will be available , the trick is to find which saw uses it
Feb 21, 2018 | Blade Saws
I need the outer flange/blade clamp for my Skil model 77 type 15
This sounds like a worm drive. Try going to this web site to order your part.
http://www.ereplacementparts.com/skil-shd77-f012sd7700-worm-drive-skilsaw-parts-c-130_160_7479.html
This is the part for the blade clamp washer $5
Blade Clamp Washer
This is the flanged plain washer $4
Blade Clamp Washer
and retaining ring $4
Retaining Ring 2610341359 for Power Tool eReplacement Parts
Dec 03, 2014 | Skil Saws
Skilsaw 5380 blade installation problem.
Don't know exactly, but on amazon you can find user manual. here Skil Circular Saw Model 5350 Owner Manual Operating Guide Paperback 1988 . Hope this was helpful. cheers skilsaw-5380-blade-installation-problem-uh3jsoynacgcqh0wcsujgpyu-3-0.jpg
Jan 20, 2013 | Skilsaw 5380 Circular Saws
How do you change the blade on a Husqvarna partner K750 concrete saw?
The blade bolt is 13mm,on the opposite side there is a hole in the belt guard to insert a 6mm pin to lock the front pulley, once locked undo the blade bolt counter clockwise, once removed, remove the outer clamping flange, you can then remove the blade, the standard arbour is 20mm, this can be changed if you wish to a 25.4mm, or a 22mm, depending on the arbour size of the blade you wish to fit, the arbour just pulls off the shaft with a suitable puller. Refit the the blade and outer flange, tighten the bolt securley.
Jul 27, 2011 | Garden
The blade on my Delta Model 36-075 miter saw spins freely - motor works fine - i disassembled down to the gear drive - the gear appears to be fine no missing teeth or obvious damage. Does the inner shaft...
hi, on your Delta saw shaft has two flanges which one goes in front of the blade and the other behind the blade. These flanges have two flat spots in the center of it which over the shaft, the blade has the same cut out so you need to check your shaft, flanges and blade to make sure they are all locking on the shaft. Do not forget to unplug the saw before you do any work.
Feb 09, 2018 | Delta Saws
The blade seams stuck. It wont spin freely evin though there is nothing blocking it from the outside.
did you recently replace the blade and if so did you make sure the inner flange is on correctly and the placement of the inner and outer flange are correct. Let me know what you find.
Dec 28, 2009 | Bosch 4000 - 07 Electric Table Saws
Need lower blade guard for Skilsaw Model Model 77
Yes I do Know where, here you go !
http://www.toolpartsdirect.com/skil/skil-34.html
Nov 09, 2009 | Skil 7 1/4" Magnesium "Mag 77" Wormdrive...
Oct 11, 2009 | Skil 7 1/4" Magnesium "Mag 77" Wormdrive...
Skilsaw motor runs blade won't turn
It sounds like you bought a lemon possibly. I am thinking that the gears are bad. What you can do is remove the blade and unplug the saw. locate where the screws holding the bearing cover are and remove them to get to the gear and check it. Let me know if you need more help
Jun 27, 2009 | Skil 7 1/4" Magnesium "Mag 77" Wormdrive...
Where is the blade lock button on a skilsaw 5150 2 1/8hp ???? i can't get the blade off and turning the saw bolt the same direction as it spins isn't working.
First, there is no blade lock button on the Skil model 5150. I called the Skil customer service and they emailed me the exact manual for this circular saw. The method I used to loosen a VERY TIGHT blade stud was: spray with WD-40, imbed the blade in scrap wood, set Skil wrench (usually found in back of foot under handle) on so it could be struck going in counter-clockwise direction. Use hammer to strike handle of wrench a couple of times. To replace blade, finger-tighten blade stud, then use wrench to tighten 1/8 turn or (45°).
Jun 25, 2009 | Skil 7 1/4" Magnesium "Mag 77" Wormdrive...
Skil 7 1/4" Magnesium "Mag 77" Wormdrive Saw With Twist Lock Model # SHD77M 72 Logo
129 people viewed this question
Top Skil Saws Experts
JOHN LAPIER
Tejodhar Atreya...
Tejodhar Atreya...
Are you a Skil Saw Expert? Answer questions, earn points and help others
