Question about BlueStar RNB36 (Gas) Kitchen Range
Replacing a 4-point gas re-igniter.Where is it located in the range?
Hotpoint gas range rgb745 electric igniter not working
Make sure igniter is getting power before you replace it. Also check the switch that feeds the igniter.
For parts go to attached. Search Over 2 1 Million Appliance Parts
Oct 07, 2015 | Hotpoint RGB745 Gas Kitchen Range
On my whirlpool gas range only 1 burner out of 5 will ignite. oven light works, oven ignites. only 3 months old and worked fine until now.
Most often when cleaning, soapis left behind and obstructs the flow of ignition gas normally directed at the exact point of the spark. Check this area and use a small wire brush to clean these area of the burners that do nto work. Let us know if this helps. Eric Campion
May 19, 2012 | Whirlpool GFG461LVS Stainless Steel Gas...
Gas range won't ignite. We had PGE and come over
This sounds like a failed burner igniter, also called a spark module. These are pretty easy to replace since the module itself is located at the back of the stove under an access panel. The price is around 40 to 60 dollars. Lately it seems that these newer stoves have weaker spark modules. I see dead modules on models less than 2 years old, where it used to be more like 5 or more years on the older ones.
Mar 24, 2010 | Kenmore 79012 / 79014 / 79019 Gas Kitchen...
Gas oven not lighting
Hi the problem here is the igniter. Take the floor of the oven out and then the flame spreader. The igniter will be located at the back of the burner. Set the oven for 350, if the igniter does not light then test it with an ohms meter it should read continuity. If it reads open you should replace it. If the igniter does glow it still could be bad, the igniter should glow bright yellow to the point you can't look at it. If the igniter glows orange/yellow it is bad you will need to replace it. If you have any other questions please feel free to comment. Mike
Feb 13, 2010 | GE JGBS20 Gas Kitchen Range
Oven will not heat up
When the bake igniter becomes weak or burns out, your oven will not bake. The bake igniter is usually mounted on the oven burner. It's about 1 inch by 4-8 inches (depending on the model), and comes in round or flat styles. If you don't see the igniter glow at all, it's probably burned out. Replace the igniter if found defective. Note: one of the exceptions could be that your oven is set to automatic mode instead of manual. If this is the case, set your oven to manual mode and check again.
If the bake igniter glows red and not bright yellow or white, it is probably because it is too weak. When this happens, the safety valve would not let the gas out into the oven burner. A weak igniter must be replaced.
A faulty igniter is probably the most common cause, however there are others:
-- defective thermostat(located inside the top area of the units body structure)
-- defective selector switch(located on the control panel, or part of the integrated control board key pad.)
-- defective gas safety valve(located on the gas valve assembly)
-- defective gas valve coils(located on the gas valve assembly)
-- defective flame sensor(located on the gas valve assembly)
NOTE(If everything checks out ok with the ignitior, and burner/valve assembly, this will lead to a failing control board)
Nov 03, 2009 | GE Profile Spectra JGBP90 Gas Kitchen...
No gas to oven
Hello, even though the igniter is glowing it does not mean it is drawing the correct amps to open the safety valve. If your igniter is glowing orange replace it. Igniters should glow brillient yellow to the point where you cant look at it. replace the igniter and you will be good to go. Good Luck!! Mike
Oct 01, 2009 | Wolf Range WKGD-2 Gas Double Oven
No spark
Replace your Invensys U-67204-8 0+4 Module: http://www.toolbox.invensyscontrols.com/appliance/linkedElements/ElectronicSparkIgnition_SparkReignition.pdfwith a Tytronics 4 Point Re-ignitor #RI 120E-4: http://www.tytronics.com.au/__files/f/2792/4 Point Re-Igniter.pdf which has replaced the older Invensys Module on BlueStar Ranges like the RNB304BV1 - 4 Burner Range (also used in some Viking Ranges): http://bluestar-store.mwrc.net/en/product.php?product_id=40478 Call Prizer-Painter 800-449-8691 for instructions if not sure how to do this. Also, may want to do some cleaning first overall on the Burners and the Igniters - BlueStar Part #741801: http://bluestar-store.mwrc.net/en/product.php?product_id=37702 or replace if broken: http://www.bluestarcooking.com/bluestar-service-videos.html#
Apr 18, 2009 | KitchenAid 30 in. KGCS105GSS Gas Cooktop
Oven in DCS gas range doew not turn on
Well some of the older ones have a unit that is sorta like a pilot light which keeps you safe by not letting out gas before it ignites so as to not blow up. This macanism is probably bad. I use to replace them on Tappan ovens. They would last a couple of years and then would go out and to replace them then was about $80.00. Easy to do. They are usualy located inside the oven somewhere and look like a glass eye on one end with a small 1/4 inch gas line connecting to the other end.
Jul 30, 2007 | DCS RGS-486GD Gas Kitchen Range
Gas kitchen range
Most problems with gas ranges have to do with the flame--either it isn't quite right or it's nonexistent. Most new gas ranges have "electronic ignition," a spark igniter that starts the flame as gas flows through the burners. If, when you turn on a burner, it fails to spark but you hear sparking at other burners, the igniter or the burner switch probably needs replacement by an appliance repairperson. If your range has a pilot light, be sure the pilot light is lit.
Jan 18, 2006 | Crosley CE35100AA Electric Kitchen Range
BlueStar RNB36 (Gas) Kitchen Range Logo
56 people viewed this question
Top BlueStar Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a BlueStar Kitchen Range Expert? Answer questions, earn points and help others
