Question about Refrigerators
Tc22nl what is the width of an Amana TC22NL frig
Need the largest refrigerator for fixed 32" width Current refr. is Maytag double door that is 31-7/8". Don't want another Maytag. Prefer GE, LG, Samsung etc. Can be double door, three door, top or bottom...
newer frigs are deeper and the with can be the same . but i do like the 3 door maytag and there s a model that fits . this 3 door is mfg under kenmore / amana / whirlpool / majic chef / . the lg 3 door is not a maytag product . . whirlpool builds the maytag so you may find it under many brand names . . also the g e is not a maytag .. what ever you decide to purchase make sure you can get parts in your area for it .. hope this helped mm Majic **** ...
Oct 23, 2010 | Refrigerators
There is a strong acrid odour coming from my Amana refrigerator. This frig is 15 years old and has a top freezer.
It may be a refrigerant leak in the coil and it will stop working soon. When this happens it's time for a new box. 15 years is a good run.
A new coil could cost as much as a new frig and that's without labor cost.
I hope this helps
Aug 23, 2010 | Amana Refrigerators
Amana side by side refrigerator wont cool properly after moving from one house to another
have a two year old side by side amana frig. the freezer side works fine, the frig is at 56 degrees at coldest setitng. HELP, can't get repair guy for five days cause we live in rural area.
Apr 19, 2010 | Amana ARS266ZBS Side by Side Refrigerator
Amana refrigerator not cold
The fan that should circulate air between the two compartments has failed. These usually have 'sleeve' bearings which can become sticky and fail to start up without help. Go to the Sears/parts website and enter your Amana model number; if you are lucky, they will have a line drawing of your model which can aid in finding how to access the fan:
Sears Parts Dept.
They have info for thousands of non-Sears items and most can be ordered via that website as well.
Feb 25, 2010 | Amana ABB1927DE Bottom Freezer...
I woke up this morning to a flooded kitchen due to the ice maker, in my Amana refrigerator, not making ice and just pouring out water. What is the problem?
Either the switch in the ice maker is stuck keeping the valve open or the valve has stuck. Unplugging the frig will tell you which it is. If the water stops when the frig is unplugged it is the switch. If it does not then it is the valve.
Eric
Dec 12, 2009 | Amana ATB1832AR Top Freezer Refrigerator
Freezer on the bottom
Because there are many models like the model number listed above your post I will need you to confirm the model number on the refrigerator. The photo below shows were to look for the model number. Some like yours have a simple defrost system and some have circuit control boards. Everyone has these problems with every brand, Your model is Amana and also a Maytag brand. Let me know so I can help you get this going thanks, Sea Breeze
http://servicepartstec.blogspot.com/
May 28, 2009 | Amana ABB1927DE Bottom Freezer...
Ice cream and bread don't freeze, food in frig DOES freeze
Not fixed but I do not want to spend MORE money to find out what's wrong with this AMANA piece of ****. Apparently, from research on the net, the compressor or motor is not strong enough in this unit to actually do the job...but if anyone has any suggestions, I'm happy to hear them...
May 16, 2009 | Amana ATB1832AR Top Freezer Refrigerator
Bottom freezer on Amana refrigerator is too warm,
is there frost building up in the back of the freezer wall?mike
Mar 16, 2009 | Amana ABB1927DE Bottom Freezer...
Amana frig
1.Dirty condenser coils where heat is transfered to the room air. 2.Frost build-up on back wall of freezer section which would indicate a defrost system problem.
May 20, 2008 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Refrigerators Logo
42 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
