Question about Oster 4724 Rice Cooker
Rice burning at bottom of cooker
My rice keeps burning or atleast turning brown when I cook. 2 Cups of white rice (med grain) with 3 cups of water. Seems easy enough, put it in, plug in the cooker, push the button, a little while later...Perfect rice...except for the perfect part. I thought the rice cooker would take out the guess work. Is there anyway for me to adjust the cooker so it doesn't burn the bottom of my rice?
  • 1 more comment
  • Anonymous Mar 13, 2014
    please send a manuel of the rice cooker
  • Anonymous Mar 27, 2014
    Please give us the contact number for tiger Rice Cooker in Saudi arabia
  • Anonymous Mar 30, 2014
    how to prevent rice from getting kind of brownish at the bottom of the cooker?
I also have this problem and I fixed it by adding in a little more water and by removing the power cord from the outlet immediately after the cooker finishes it's cycle. Not ideal, but it does save my rice.
Posted on Apr 28, 2008
  • minh pham
    minh pham Mar 08, 2016
    How to rice cooker RZ-MC10j hitachi, I've tried many times to cook but its doesnt work, please help if you've cooked this model. Tks very much
Your cooker, along with mine, cooks very hot. If it is new then you can take it back, but if you want to cook with it then you need to stir the rice often. About every 5 minutes should be good. As soon as it is done you need to remove it from the cooker. Let's see how that works.
Posted on Aug 31, 2007
    New Friend:
Avenia rice cooker keeps blowing fuses
Posted on Jun 11, 2013
2cup rice with 4 cup water. Why is the water boiling out of the cooker?
Way too much water! Use the same amount of white rice to water and a third of a cup more when using brown rice.
Mar 16, 2015 | Farberware Kitchen Appliances - Others
Lost direction on how to use my rice cooker and havn't used it in a while
To cook rice, fill center basin of base with water. Place the rice bowl on basin. Add rice and water as follows. For white rice add water in a 1:1 ratio to rice plus 1/2 cup. For brown rice add water in a 1:1 ratio to rice plus 3/4 cup. Examples: 1 cup white rice, 1-1/2 cup water; 2 cups brown rice, 2-3/4 cups water. Put lid on and plug in and in about 50 minutes you should have delicious rice.
Please rate this answer. Thank you.
Mar 27, 2010 | West Bend 86712 12-Cup Rice Cooker
Need directions on how make rice on my oster rice cooker
There are many types of rice. Follow specific directions for variety used.
2. Accurately measure rice and water then combine in rice bowl.
Pour specified amount of water in water reservoir. Cover and steam.
3. For softer rice, increase by 1 – 2 tablespoons the water mixed with rice
by the specified amount of water on the chart. For firmer rice decrease
water mixed with rice by the same amount.
4. Check doneness and consistency of rice at minimum time specified
for each type, stirring rice at the same time.
5. When checking/stirring rice, be careful not to drip the condensate into the
rice bowl which would reduce the quality and flavor of the steamed rice.
6. Use only clean water in water reservoir
7. Rice may be seasoned with salt, pepper or butter after steaming.
Combined In Rice Bowl Approx. Time
Type of Rice Rice Amount Water
(Minutes)
Brown
Regular 1/2 cup 1 cup 42 – 45
Parboiled 1 cup 1-1/2 cups 45 – 50
Long Grain and Wild Rice Mix
Regular (6 oz. pkg.) Mix 1-1/2 cups 50 – 55
Quick Cooking (6-1/2 oz. pkg.) Mix 1-3/4 cups 18 – 20
Instant 1 cup 1-1/2 cups 15 – 18
White
Regular 1 cup 1-1/2 cups 45 – 50
Long Grain 1 cup 1-2/3 cups 50 – 55
Oct 25, 2009 | Oster 5712 10-Cup Rice Cooker
Rice Measurements
You use one cup of water for each cup of uncooked rice. You end up with about 2 cups of cooked rice for every cup of uncooked rice. Different varieties, such as brown rice, take more water, up to 2 cups of water per cup of uncooked rice. If the resulting rice is too dry, you can add more water and restart the cooker.
I am not sure, but I believe that 16 cups refers to cooked rice, so you should not put more than 8 cups of uncooked rice in the cooker.
Feb 23, 2009 | Black & Decker Kitchen Appliances - Others
My mom just gave a used rice cooker for christmas and it didn't come with any kind of instructions. Where can I find them?
you cooker should have a lever , down to cook rice , it will "pop" up when the rice is done, allow to sit 4-5 min to allow the rice to finish steaming.
2 cup med grain rice & 3 cups water yeilds about 6 cups cooked rice
Jan 05, 2009 | Black & Decker RC400 7-Cup Rice Cooker
My Aroma ARC 930 Over cooks white rice
try 2 cups rice 3 cups water using Medium grain rice, your adding too much water
Dec 31, 2008 | Aroma ARC-930 20-Cup Rice Cooker
I am using Wolfgang Pucks Rice cooker for the first time. I do NOT want to make a ton of rice. How do I make a smaller amount?
standard would be 1 cup rice is min lesser amounts do not cook well,
1 cup med grain rice -1 &1/2 cups water yeilds about 3 cups cooked
* you can freeze the extra rice great for fried rice when thawed or in soups
Dec 14, 2008 | Kitchen Appliances - Others
Lost my instruction book...want instructions to make rice in cooker...ratio of rice and water please
I have a Toastmaster 3 cup rice cooker but think the ratio would be the same.
Long grain white rice - 2 rice measuring cups - water to 2 cup line = 8 (1/2 cup) servings
3 rice measuring cups - water to 3 cup line = 12 (1/2 cup) servings
Long grain brown rice - 1 1/2 Rice measuring cups - water to 3 cup line - 6 (1/2 cup) servings
For fluffy rice: After cooker shuts off, allow rice to stand for approx. 15 minutes, covered, before serving.
Hope this helps
Oct 19, 2008 | Salton RA5 5-Cup Rice Cooker
How do I cook rice in my steamer where do I put the water?
there is normally a special rice bowl, which looks like the lid upside down which is used for rice cooking and should be placed at the highest point in the upper steam bowl and place the lid on top. for 1 cup of white regular rice, use 1 1/2 cups of water, steam for 45-50 mins for 1 cup long grain rice use 1 2/3 cups of water, steam for 50-55 mins for 1/2 cup of brown regular rice, use 1 cup water and steam for 42-45mins
Jul 10, 2007 | Black & Decker HS2776 7-Cup Rice Cooker
Oster 4724 Rice Cooker Logo
1,793 people viewed this question
Top Oster Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Irene Tulloch
Ben Eng
Level 1 Expert
Are you an Oster Kitchen Appliances - Other Expert? Answer questions, earn points and help others
