Question about Frigidaire Cooktops
Burners will not work on my frigidaire cookstove model fgef306tmfa
Burners wont work any more
Good Morning Fern mullen, I appreciate your post!
Based off what you have described your burners are no longer working on your Frigidaire range. This could be an issue with your control panel or the switch. I would recommend performing a reset on your range and you can do that by disconnecting power from the range for at least ten minutes. If that does not help correct your issue I would suggest having a technician out to your home for a proper diagnosis and repair. Best of luck! -Matt
Feb 28, 2015 | Frigidaire FGEF306TMF 30" Freestanding...
Top main burner want turn off
Switch is either bad in it or has food/grease build up not letting it shut off.
Unless its a newer model and is push button?
Nov 12, 2014 | Frigidaire Stove/Oven/Range Glass Main Top...
Frigidaire electric cooktop locked
I appreciate your post, friend!
I noticed your question is labeled under Frigidaire cooktop model, FEC30S7E. I have located the Use and Care Guide for your cooktop and I was unable to locate a lock feature. You could perform a reset on your appliance and you can do that by unplugging the power cord or flipping the circuit breaker off for ten minutes.
If that does not correct your issue could you please provide me with your model number? Usually you can locate the serial tag (which lists your model number) inside your burner box or on the outside of the appliance base. With that information I can look further into your model. I look forward to assisting you. -Matt
Oct 09, 2014 | Frigidaire 31 in. FEC30S7E Electric...
Frigidaire ceramic stovetop burner not working
The switch controlling the burner is just a voltage controlling unit (rheostat). It needs to be replaced
Aug 30, 2014 | Cooktops
1 burner of 4 does not get enough gas to work properly
The burner probably hes plugged holes for the gas to get through.
You can clean them out with a tooth pick or paper clip.
Feb 17, 2014 | Frigidaire Stove/Oven/Range Cooktop -...
The front right burner is not working
If the radiant burner is not working, but the other 3 are, then you will need to replace the burner with this part.
Feb 09, 2011 | Frigidaire 31 in. FEC30S7E Electric...
I have a frigidaire 1950's? custom imperial pull out range with double side by side ovens above it. I have 1 lg & 1 small burner that does not work. How do troubleshoot the problem to see if I need new...
Where do you live? I have the same model from a house I bought that was built in the 1950's and looking to sell it. They usually go for a pretty penny but I need to unload quickly. The parts can be very expensive. Let me know or call if you have any questions...
Mark
Florida
cell: 863-934-3851
Mar 23, 2009 | Cooktops
Smooth surface frigidaire electric cooktop
hi there,
you will need to replace the elements. it's quite common for them to stop functioning.
Sep 30, 2008 | Frigidaire 31 in. GLEC30S9E Electric...
Frigidaire smooth cooktop PLEC30S9EC
Smalltree, You may want to make sure that they have 220 wired to the cooktop. I've seen a lot of new construction where they are hooking the cooktops up to 120V and wondering why they're not working. Check this first and post back..Catriver.
Nov 02, 2006 | Frigidaire PLEC30S9EC Stainless Steel...
Cooktops Logo
21 people viewed this question
Top Frigidaire Cooktops Experts
Dan Webster
Dan Webster
Are you a Frigidaire Cooktop Expert? Answer questions, earn points and help others
