Question about Venturer PVS1950D Car DVD Player
Replacement EZ View Cable
Does anyone know where I can get a replacement monitor cable or what the part number is?
I have a hp-f1523h flat panel monitor i need to know how to open up so i can replace the video cable
lay down face down on table,unscrew all screws in back,leave them in the back,lift the back off and replace cable
Jun 22, 2014 | HP Pavilion F1523 15" LCD Monitor
Lg flatron ez t713sh
First thing you need to try is check if all the cables are connected properly, just to make sure. These include the power cable and the cable from the monitor to your video card.
In case your video card has more than one output for monitor, you can try it to see on which one it will work.
Let me know if this fixes your problem or if you need any additional assistance.
Jan 07, 2014 | Computers & Internet
There are multi colored vertical lines on LCD Screen going to a total black screen. Laptop connected is to an external monitor = normal display on the external monitor I removed and reinsert the video...
Unfortunately, you're not going to be able to get a new cable as Toshiba will not sell OEM replacement parts to anyone but an authorized repair center.
This may just as likely be a problem with the sockets/plugs as with the cable itself, as they are rather fragile. It may be worth spending a few bucks for a used cable just to see if it will solve your problem. Also be sure that the thin plastic shim found on the top of most of these cable ends is still there, as they can come off rather easily, and the lack of it will cause a poor connection.
Your other alternatives are (1) Toshiba repair center, or (2) using the external monitor.
Hope that's helpful.
Dec 31, 2010 | Computers & Internet
Missing power cable
Power cables appear to be standard now. You should be able to get one at any electrical store.
Mar 16, 2010 | Liquid Video A170E101 Monitor
Ribbon Cable on Necvox RE-9269D broke need replacement
You can go check at RadioShack or order the ribbon cable from EBay - http://cgi.ebay.com/HP-DV6000-DV9000-E220709-E118077-Power-Ribbon-Cable-/300393384553?pt=LH_DefaultDomain_0&hash=item45f0d74a69#ht_500wt_951
Oct 09, 2009 | Necvox RE-8169D 8 All-In-One Motorized...
Blue hue on screen
Try a different known working monitor on the vga port of your laptop. If the replacement monitor works then you definitely know its a problem with your original monitor. If the replacement monitor shows the same blue hue then you know the vga port is bad on the laptop which would mean replacing the motherboard since its connected to the laptop.
May 30, 2009 | Acer AL2016W 20" LCD Monitor
My Xbox (not 360 or live) Says i have problem number 12
DVD parameters are incorrect. Check IDE cable, power cable for looseness. If everything is fine, a replacement is more thatn likely a sure fix.
Apr 11, 2009 | Video Game Consoles & Games
Does anyone make a ez view to rca adapter pvs1960
It would be very easy to have the cable made up by a independent electronics shop. I have made several
myself.
Dec 28, 2008 | Durabrand Two Screen Car DVD Player
Samsung crt monitor
The monitor is probably on protection.
To start unplug monitor from power and from computer and test computer with different monitor to find out if it is monitor or computer fault.
If it is computer fault and no video signal , then test:
  • Video cable.
  • Video adapter on PC (sometimes integrated on motherboard)
  • Motherboard.
If it is monitor fault , then the monitor is on protection.
When on protection you keep having a flashing led on front of the monitor , and monitor turning off by itself after a while, that indicates a fault condition.
The flashing light indicates a diagnostic state called protection.
When the Monitor goes on protection there are only two possible causes.
1The internal circuits are jammed because of electrostatic charges accumulating on capacitors, or because of a wrong voltage read by the main chip on your monitor controller board. this started the protection circuit.
2 The protection circuit detected a wrong voltage or a broken contact, identified an internal fault and kicked in , starting the flashing light.
If you are in situation one, then the monitor will reset just unplugging power cord for one or two hours,sometimes even minutes.
If you are in situation 2 , then there is an internal fault.
Common faults that can occurr are a blown capacitor on power board, faulty convergence, fault on alignment circuits, flyback problem , or a fault on Digital board.
Check also the video cable or any external connection cable, if the cable is shorting, or the connector is bad, you can get same flashing state because of the video cable.
Try moving the video cable, and if the cable is not built in, then also try a replacement cable.
Jul 12, 2008 | LG Flatron Ez T710BH 17" CRT Monitor
Monitor to monitor 9 pin. rounded ends cable.
www.18002526123.com or call the number. I found this in the manual. The cables are called EZ View cable (122-004020-208)
Dec 21, 2007 | Durabrand PVS1966 Portable DVD Player
Car Audio & Video Logo
Top Venturer Car Audio & Video Experts
Hjalmer Lamminen
Hjalmer Lamminen
seankane89
Level 1 Expert
Are you a Venturer Car Audio and Video Expert? Answer questions, earn points and help others
