Question about hotmail.com
Why have you dumped my E-mail address?
I have had my user name and password for ages. My daughter used the computer while she was staying with us. Why can't I use my regular E-mail address. This is very annoying as I have to sort out insurance for my car. You can be too security conscious.
I can't get to configure my e-mail account"ojopojj@yahoo.com so that i can access it through Microsoft outlook
Per office.microsoft.com:
Add your Yahoo! Mail e-mail account
  1. On the Tools menu, click E-mail Accounts.
  2. Click Add a new e-mail account, and then click Next.
  3. Click POP3, and then click Next.
  4. Under User Information, do the following:
    1. In the Your Name box, type your full name the way that you want it to appear to other people.
    2. In the E-mail Address box, type your Member ID (or username), followed by the @ symbol and domain name.
  5. Under Server Information, do the following:
    1. In the Incoming mail server (POP3) box, type the server name from the chart below that corresponds to your e-mail address.
    2. In the Outgoing mail server (SMTP) box, type the server name from the chart below that corresponds to your e-mail address.
  6. Under Logon Information, do the following:
    1. In the User Name box, type your Yahoo Member ID (or username). Do not include the @ symbol or domain name.
    2. In the Password box, type your password.
    3. Select the Remember password check box.
 Note   You have the option to have Outlook remember your password by typing it in the Password box and selecting the Remember password check box. Having Outlook remember your password means that you won't have to type your password each time you access the account; however, it also means that the account is vulnerable to anyone who has access to your computer. Use strong passwords that combine uppercase and lowercase letters, numbers, and symbols. Weak passwords don't mix these elements. Strong password: Y6dh!et5. Weak password: House27. Passwords should be 8 or more characters in length. A pass phrase that uses 14 or more characters is better. For more information, see Help protect your personal information with strong passwords.It is critical that you remember your password. If you forget your password, Microsoft cannot retrieve it. Store the passwords that you write down in a secure place away from the information that they help protect.
  1. To verify that your account is working, click Test Account Settings. If there is missing or incorrect information, such as your password, you will be prompted to supply or correct it. Make sure your computer is connected to the Internet.
  2. Click More Settings.
  3. On the General tab, under Mail Account, type Yahoo! Mail.
  4. Click the Outgoing Server tab, and then select the My outgoing server (SMTP) requires authentication check box.
  5. Click Use same settings as my incoming mail server, and then click OK.
  6. Click Next, and then click Finish.
 Notes
  • Do not select the Log on using Secure Password Authentication (SPA) check box.
  • Unless specified by Yahoo! Mail, all server and address entries are typed in lowercase letters.
Sep 25, 2010 | Dell Vostro 1400 Notebook
Tip
How to setup your email into your iPhone
First, you need to know your IMAP incoming and outgoing mail servers. These servers can be provided by your email service provider. Once you have these info, you may follow the steps below:
1.Go to 'Settings' on the main menu on your iPhone.
2. Click on Mail, Contacts, Calendar...
3. Select Add Account and tap 'Other'
4. Add mail account and then fill out the lines with your name, e-mail address and password then tap 'Save'.
5. Select IMAP and then use the information below:
* Incoming Mail Server *
- Host Name: type the IMAP incoming server
- User Name: type your complete email address
- Password: your e-mail password
* Outgoing Mail Server *
- Host Name: type the IMAP outgoing server
6. Tap Save button.
Thank you!
on May 03, 2010 | Cell Phones
Tip
To Set Up Your E-mail Account in Microsoft Outlook
1:In Microsoft Outlook, select Tools > E-mail Accounts.
2: On the E-mail Accounts wizard window, select "Add a
new e-mail account" and click Next.
3: For your server type, select "POP3" and click Next
4: On the Internet E-mail Settings (POP3) window, enter
your information as follows:
Your Name
Enter your first and last name.
E-mail Address
Enter your e-mail address.
User Name
Enter your e-mail address, again.
Password
Enter the password you set up for your e-mail account.
Enter pop.secureserver.net for your incoming mail server.
Enter smtpout.secureserver.net for your outgoing mail server.
5: Click “more settings”. On the Internet E-mail Settings window, select
the "Outgoing Server" tab.
6. Select "My outgoing server (SMTP) requires authentication."
7. If you did not change the SMTP relay section, select "Use same
settings as my incoming mail server". If you changed the user name
and password in the SMTP relay section of your Manage Email
Accounts page, select "Log on using" and enter the user name and
password. The following example assumes you did not change your
SMTP relay section in your Manage Email Accounts page.
8: Select the "Advanced" tab and change the "Outgoing server (SMTP)"
port to 80 or 3535.
9: Click OK.
10. Click Next.
11. Click Finish.
on May 10, 2008 | Microsoft Office Outlook 2003 for PC
I cant get my bellsouth.net incoming mail or outgoing. had to set up my computer ater losing everything what do i put for my incoming mail server(pop, imap, http incoming mail pop, imap or...
Im assuming you are using outlook express, if not, I apologize, but steps should be similar for other types of software:
    2. In the E-mail Address box, type your e-mail user name, followed by @bellsouth.net.
    1. In the Incoming mail server (POP3) box, type mail.bellsouth.net.
    2. In the Outgoing mail server (SMTP) box, type mail.bellsouth.net.
    1. In the User Name box, type your full e-mail address, including the @bellsouth.net domain.
  1. To verify that your account is working, click Test Account Settings. If there is missing or incorrect information, such as your password, you are prompted to supply or correct it. Make sure your computer is connected to the Internet.
  3. On the General tab, under Mail Account, type BellSouth.net.
  5. Select Use same settings as my incoming mail server, and then click OK.
Notes
  • Unless specified by BellSouth.net, all server and address entries are typed in lowercase letters.
Good Luck!
Aug 10, 2010 | Computers & Internet
Yahoo mail does not recognize my user name and password
The access of Yahoo mail account login problem to the users in entering the username and password. So as to avoid this step the user can setup account key to their account and the user just only needs to add on verification code to their account. To follow the step you can visit the referred link- https://gonetech.net/yahoo-helpdesk/setup-yahoo-account-key/
Mar 28, 2010 | Yahoo Mail
There is no problem I want setup an email address for my daughter
If you are wanting an address that is mobile, (meaning, can be checked on any computer), this is fine but if you contact your isp they can sit up one that can be used at home and can be checked online also. she would have her own password and user name.
Just go to yahoo.com, click on "signup" and follow the directions. As a parent I would keep the password around handy.
Oct 26, 2009 | Yahoo Mail
Hi There, In the US, getting my yahoo email (using Mail program on a MacBookPro) (yes I have yahoo plus) works like a charm. But here in Canada, most of the time, the password gets rejected... what's give?
To set up access to a free Yahoo! Mail account in Mac OS X Mail:
* Install MacFreePOPs and make sure the freepopsd service is running.
* Select Mail | Preferences... from the menu in Mac OS X Mail.
* Go to the Accounts category.
* Click + at the bottom of the Accounts list.
* Type your name under Full Name:.
* Enter your full Yahoo! Mail address (e.g. "example@yahoo.com") under Email Address:.
* Type your Yahoo! Mail password under Password:.
* Make sure Automatically set up account is not checked.
* Click Continue.
* Make sure POP is selected under Account Type:.
* Enter "Yahoo! Mail" under Account Description:.
* Enter "localhost" (without the quotation marks) under Incoming Mail Server:.
o If you run into problems using "localhost", try "127.0.0.1".
* Type your full Yahoo! Mail address ("example@yahoo.com", for example) under User Name:.
o Mac OS X Mail probably has already entered your user name, and it's enough to append "@yahoo.com" to complete the address.
* Click Continue.
* Click Continue again, ignoring the error. We'll take care of that in a bit.
* Make sure Password is selected under Authentication:.
* Leave Use Secure Sockets Layer (SSL) unchecked.
* Click Continue.
* Select an existing mail server to send mail under Outgoing Mail Server:.
o You cannot send mail through MacFreePOPs. If you have no outgoing mail server through your ISP, you can use a Gmail or AIM Mail account's.
* Click Continue.
* Now click Create.
* Highlight the Yahoo! Mail account in the Accounts list.
* Go to the Advanced tab.
* Enter "2000" (not including the quotation marks) under Port:.
* Close the Accounts window.
* Click Save.
Access Free Yahoo! Mail with Mac OS X Mail Using IMAP Over IzyMail
To add a free Yahoo! Mail account in Mac OS X Mail using IzyMail, which provides access to all mail in all folders seamlessly:
* Make sure your Yahoo! Mail account is registered with IzyMail.
* Click + under the accounts list.
* Make sure IMAP is selected under Account Type:.
* Type "Yahoo! Mail (IzyMail)" under Account Description.
* Enter your name under Full Name:.
* Type your complete Yahoo! Mail address under Email Address:.
* Click Continue.
* Enter "in.izymail.com" (not including the quotation marks) under Incoming Mail Server:.
* Type your full Yahoo! Mail address under User Name:.
o If your Yahoo! Mail address is qwertui@yahoo.com, do type "qwertui@yahoo.com" (omitting the quotation marks).
o Mac OS X Mail probably has already entered the user name for you. If you already find "qwertui" in the User Name: field, just append "@yahoo.com".
* Enter your Yahoo! Mail password under Password:.
* Click Continue.
* Type "out.izymail.com" (without the quotation marks) under Outgoing Mail Server:.
* Make sure Use Authentication is checked.
* Enter your full Yahoo! Mail address under User Name:.
* Type your Yahoo! Mail password under Password: again.
* Click Continue.
* Click Continue again.
* Now click Done.
* Cloe the Accounts window.
* Click Save.
* Open the _Draft folder under Yahoo! Mail (IzyMail) in the folder list.
* Select Mailbox | Use This Mailbox For | Drafts from the menu.
* Open the _Sent folder under Yahoo! Mail (IzyMail).
* Select Mailbox | Use This Mailbox For | Sent from the menu.
* Open the _Trash folder under Yahoo! Mail (IzyMail).
* Select Mailbox | Use This Mailbox For | Trash from the menu.
* Open the _Bulk folder under Yahoo! Mail (IzyMail).
* Select Mailbox | Use This Mailbox For | Junk from the menu.
Done!
Aug 15, 2009 | Yahoo Mail
Verizon email account setup on my iPhone
Try this on the iPhone:
Incoming settings:
POP Account Information:
Name: The name you want in the header when you send mail
Address: Your full email address-e.g., My.Address@verizon.net
Description: anything you want (This will be the name in the list of mail accounts)
Host Name: incoming.verizon.net
User Name: the first part of your email address-e.g., My.Address
Password: Your password to Verizon netmail or your desktop mail client
Advanced:
Incoming Settings
Use SSL: Off
Authentication: Password
Delete from Server: your preference
Server Port:110
Aug 12, 2009 | Apple iPhone Smartphone
I need help setting up my email on my iphone
1) If this is the first email account you're setting up on your iPhone, tap Mail. Otherwise, from the Home screen, tap Settings.
2) On the Settings screen, tap Mail.
3) On the Mail screen, under Accounts, tap Add Account.
4) On the Add Account screen, tap Other.
5) Select POP and then enter your account information using your keypad. Name Enter your name. Address Enter your email address. Description Enter a description of this email address. The description displays in your email account list on your iPhone. 6) Enter your Incoming Mail Server information.
Host Name Enter pop.secureserver.net. User Name Enter your full email address as your user name. Password Enter your password for your email account. 7) Enter your Outgoing Mail Server (SMTP) information.
Host Name Enter smtpout.secureserver.net. If you need to change your port, use one of the following for your outgoing mail server, depending on the port you want to use:
smtpout.secureserver.net:25
smtpout.secureserver.net:80
smtpout.secureserver.net:3535
User Name Enter your full email address as your user name. Password Enter your password for your email account. Note: The user name and password for your outgoing server is the same as the user name and password your entered for the incoming server.
8) If SSL mode is enabled, under Outgoing Mail Server (SMTP), tap Advanced.
9) Set Incoming Uses SSL and Outgoing Uses SSL to OFF.
Jul 16, 2009 | Apple iPhone Smartphone
Pop email settings with godaddy domain
I FINALLY GOT THE ANSWER! I ALSO HAVE A GODADDY EMAIL ADDRESS AND USE A HTC TOUCH PHONE FROM SPRINT. I've entered the following settings and my email now works like a charm! This is for a POP3 email address, not an IMAP email address.
You cannot send the email unless you have a sprint email address. Email must go through the Sprint server in order to be sent (incoming mail does not).
Call Sprint Tier II (877.345.7895) and ask them to set you up with a User Name and Password for the outgoing mail server. All the rest of the settings are as follows:
EMAIL SET UP Email Address: You@YourGoDaddyDomain.com Your Password: the password you use to access your go daddy account Check SAVE PASSWORD Click NEXT UNCLICK TRY TO GET EMAIL SETTINGS AUTOMATICALLY FROM THE INTERNET. Click NEXT. Your Email Provider: Internet Email Click Next Your Name: Dales Wife Account Display Name: 'GoDaddy Email" or whatever you'd like to call it so you can identify this account (you can have several email accounts sent to your phone). Click NEXT Incoming Mail Server: pop.secureserver.net Account Type: POP3 Click NEXT User Name: Again enter You@YourGoDaddyDomain.com Password: Enter your password again Check SAVE PASSWORD Outgoing (SMTP) Mail Server: smtp.sprintpcs.com CHECK Outgoing server requires authentication UNCHECK Use the same user name and password for sending email Advanced Server Settings: DO NOT Check: Require SSL for Incoming e-mail DO NOT Check: Require SSL for Outgoing e-mail Click DONE to return to previous screen Click NEXT Outgoing Server Login: TheNameGivenToYou@sprintpcs.com Password: When you call Sprint Tier II they will ask you what password you'd like. Check Save Password. Automatic Send/Receive: I use every 5 minutes and it doesn't seem to run my battery down. Click FINISH. This has been driving me crazy for two months now so I really hope this information helps somebody else out. Best of luck! NOW, if anyone knows how to remove those annoying envelopes when I access my mail - I could use the help. There are three envelopes there (one for GoDaddy mail, one for Outlook and one for Picture Mail.) I do not use Outlook or Picture Mail and would love it if I could remove those.
Dec 20, 2008 | HTC Touch Pro Smartphone
hotmail.com Logo
Top hotmail.com Computers & Internet Experts
David Payne
David Payne
Mike
Are you a hotmail.com Computer and Internet Expert? Answer questions, earn points and help others
