Question about Refrigerators
Hotpoint ctx14cpgl ad
No defrost
2 Suggested Answers
Maytag317
  • 1136 Answers
SOURCE: hotpoint fridge model CSx20KATA AD defrost timer
Hi, This model does not have a defrost timer. It actually has a motherboard. If you have a defrost problem, the nore common part to check first is the defrost heater or termination switch ( bi-metal). These two parts are located inside the freezer compartment behind the rear panel where the frost is building up.
These two parts must have continuity. If one or noth of them have no continuity, they need replaced. Please use a hair dryer (NOT a sharp object the remove the frost from the evaporator coils.
If you need any more help or need to order the part, I can help you and we can order the parts off my web site WWW.Whirlpoolpartssurplus.com
Let me know if I can help.
Thanks
Vic
Posted on May 11, 2009
How do I fix my refrigerqtor hotpoint double door not defrostiong
Generally, if you unplug the refrigerator and set the freezer and refrigerator temperature controls to off then plug it back it, this will put the refrigerator in forced defrost mode. Keep the doors closed and allow defrosting to last for about 20 minutes. Then unplug again and reset the temperature controls to mid-range or a little above, and plug it back in. If this does not reset the defrost cycle, you probably need service.
Mar 07, 2015 | Hotpoint Refrigerators
Hotpoint fridge freezer ff200 tx displays error code A1?
These tempratures are pretty cold should be around 0 deg. but it sounds like you might have a bad defrost timer or defrost thermostat the frost should not come back if defrost system is working
Jul 26, 2014 | Hotpoint Freezers
Hotpoint FFA71 NOT DEFROSTING
Self defrosting feature is not working. Check defrost thermostat, defrost heater, defrost timer for proper operation.
Until repair is made, defrost the unit and turn back on until it freezes up again. Check the ice block at rear of freezer. If the ice is confined to the area around the refrigeration line coming into the freezer it is low refrigerant level. If the block completely covers the evaporator it is a non working defrost mechanism.
Nov 21, 2013 | Hotpoint FFA70 Bottom Freezer Refrigerator
Hotpoint refrigerator not defrosting
Is it not defrosting, or defrosting and re-freezing the meltwater as ice? Check drain clear. Further checks are 1) defrost timer 2) defrost heater 3) defrost klixon
Aug 08, 2012 | Hotpoint HSS25GFT 25.0 Cu. Ft....
My Hotpoint Side-by-side temperature flucuates(model #HSS25GFTA). Items in freezer melt at times and then re-freeze. Same is noted for the fridge. Service tech added freon; however, problem continued. ...
You are correct on your evaluation of the " tech " the # 4 thermistor is bad . This tells the main control board , the temp of the coils , if they need defrosted , when they are thru defrosting . This thermistor is the 1 " long , torpedo looking piece , clipped on the top left of the coils , with 2 white wires going to it . Part number WR55X10025 . It would be advisable to also replace the # 5 thermistor , located at the bottom of the freezer , slightly in front of the drain , also with 2 white wires going to it , slid into a housing . This thermistor , is the freezer thermistor , which tells the control board , the freezer temp and when to cycle off due to selected temperature .
Sep 23, 2010 | Hotpoint HSS25GFT 25.0 Cu. Ft....
HOTPOINT FRIDGE - COILS FROSTING UP
as you know your unit is not going through defrost cycle. you need to replace either the control board, defrost heater and or defrost thermostat. ge is known for their defrost heaters going out.
Jun 24, 2009 | Hotpoint FFA90 Bottom Freezer Refrigerator
Hotpoint fridge model CSx20KATA AD defrost timer
Thanks
Vic
May 11, 2009 | GE GSS25SGMBS Side by Side Refrigerator
Wiring diagram for a Hotpoint FF73P
I am having a problem Fridge Freezer hotpoint ff73p
my fridge temperature is +23 need help
Oct 25, 2008 | Refrigerators
Refrigerators Logo
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
