Question about Riccar Sewing Machines
Stitch length problem
Hi, I've not used my machine for quite sometime, so today I thought i'd use it. the tension is fine, I 've cleaned the machine of lint yet whatever setting I turn the dial to, the stitch length remains very small. I've tried testing different types of fabric, needle, threads but nothing seems to make any difference. Can you suggest anything?
  • Riccar Master
  • 7,365 Answers
The stitch length dial may need to be checked to see if it's worn or damaged or may need a adjustment.
Posted on Jul 28, 2013
Testimonial: "OK. Thank you - I thought I would probably have to get it checked over! Shame - I was all geared up to sew. I'll have to try and find a Sewing Machine Repair Centre."
5 Suggested Answers
bugoy31
  • 1238 Answers
SOURCE: Stitch tension problem - bobbin
Good day!
please try this simple tips:
Good day!
A sewing machine operator can often help themselves when their machine does not operate properly.
Here are some simple instructions, which if properly used can save time and mechanics service calls.
TROUBLE;UPPER THREAD KEEPS BREAKING;
This could be trouble;================Do this;
1.Top tension to tight================loosen tension 1 turn
2.Machine improperly threaded=========check threading
3.Thread twisted on guide post========"
4.Thread twisted out of tension======="
5.Take up spring bent or broken=======Check action of spring
6.Thread jumped off pull off finger===Check threading
7.Needle bent or burred===============new needle
8.Bad cone of thread==================try another cone
TROUBLE;LOWER THREAD KEEPS BREAKING;
1.Bobbin tensionspring to tight=======Loosen tension slightly
2.Bobbin threaded wrong===============check threading
3.Bobbin wound to tight or uneven=====try new bobbin
4.lint or thread on bobbin case=======clean inside case
5.Lint or thread inside hook==========clean inside hook
6.Bobbin case nicked bent or burred===check/change case
TROUBLE;MACHINE STARTED SKIPPING STITCHES;
1.Needle bent or burred===============change
2.Needle set in crooked===============Check
3.Thread jumped off take up spring====check threading
4.Thread jumped off pull off finger===check threading
TROUBLE STITCHES SHOWING LOOPS;
1.Forming loops on top of cloth=======Tighten bobbin tension
======================================or loosen top tension.
2.forming loops on bottom of cloth====Tighten top tension
3.Bobbin placed in case incorrectly===remove and replace
4.Bobbin thread slipped from under====check threading of
tension===============================bobbin case
5.Lint or thread in top tension=======clean between tension discs
Thank you and good luck.
Posted on Jun 17, 2011
bargainbox
  • 1388 Answers
SOURCE: i keep getting loops of thread on the under side
Check this solution:
http://www.fixya.com/marketplace/servicepage.aspx?srvid=17197&ctgid=164&brdid=1060&prdid=131120&smid=23884&mthid=1&mpsaugid=347d7805-9ce5-42d2-b812-b602b6cf7437
Posted on Oct 17, 2011
SOURCE: Hi I have a singer 6215 i am not sure what the tension should be on the tension needle thread and the tension on the stitch length dial of my sewing machine i end up with a mess on the underneath of
i always use tension 3 on both works for me on my singer hope it helps
Posted on Apr 27, 2012
SOURCE: Feeder dogs will not feed fabric at all.
it's possible that the feed dogs need a adjustment or they need to be
timed by a sewing machine repair technican
Posted on Dec 06, 2012
I would like to know how to set the machine up for polyester/spandex material
You need a ball point size 70 or a jersey 70 if you can get it. Stitch length 2.3 to 2.5. Re tension, just normal tension setting. If the machine is sewing an evenly balanced zigzag on regular cotton fabric, then tension is fine. If you find the straight stitch on your fabric pops under stretch, then try using a very small zigzag to put some flexability into the seam.
Mar 28, 2013 | Bernina Activa 140
Singer Inspiration 4220/4228--I can't get a good stitch on lightweight material. Can you help?
in your manual on page 6 it has a chart for needle and thread combinations for fine or light materials. For your convenience I have included the download of the manual here. (see pdf page 16)
http://www.singerco.com/uploads/download/492_4228_4220_030707_new.pdf
When using lighter fabrics it is very important that you use the right thread and needle combo. Start with the correct needle and thread for your application then adjust the tension to match.
Good luck
Jul 27, 2012 | Singer Sewing Machines
How do I create a rolled hem with this machine. I see the stitch width knob, but do I need to remove one of the threads for this?
Making a rolled hem on any overlocker is achieved in the following way:
use right hand needle only and top and bottom loopers. Turn stitch length down so threads are closed up (on mine this is 0.5). Your stitch length dial will be one on the right hand side near the flywheel usually. Loosen off the the top looper tension and tighten up the bottom looper tension (these are the right and 2nd right tension dials on front of the machine). On my Bernette I leave the needle at the usual 5, 2 on the top looper and 6.5 to 7 on the bottom looper thread. Move cutting blade position to the right so that you are trimming the fabric quite a bit wider than your stitch, this makes the fabric "roll" underneath inside the stitching to form the rolled edge or hem.
There is also another step that needs to happen where you change or remove a little stitch finger that sits in the pressure foot or just under it. On the Bernettes, you flick a lever to move this stitch finger back towards the operator so it is out of the stitch forming area. On some machines, it is a case of changing the little stitch finger which is screwed onto the pressure foot with a screwdriver.
I really don't know with your Necchi which it is but have a good look at the pressure foot, and around the blade cutting area and see if you can see a lever or check out the accessory bag and see if there is another stitch finger in there, it would be smaller than the one on the foot now. In effect, this finger sits out and the threads wrap around it to form your normal overlock but for rolled hem you want a much smaller finger in place to make a very little seam.
The other variable which makes a very neat job is to use a thread called "wooly Overlock" in the upper looper only. This thread when pulled under tension is tight looking but when you let it go, it fluffs out. So when seaming on a rolled hem it fills out the stitching and covers the edge of the fabric fully giving a smooth look. You can do it without but wooly thread makes a great job and you'll see it on all Ready to Wear seams usually for this reason.
If I am going to roll hem a fine sheer woven fabric like organza or chiffon I will change the needle to make sure it is nice and sharp and also ensure it is a regular point, not a ball point (I seam lots of knits so have ball points in most of the time on mine) Usually a size 80 is fine.
I hope this gets you going with your overlocker, I usually test stitch quite a bit with the stitch length at the normal 2.5 setting and adjust the looper tensions until I've got the stitch looking good, then turn it down to the very close 0.5, just to not waste a ton of thread.
Sep 09, 2011 | Necchi 6002 Sewing Machine
My elna pro 4 DE tension is completely out how do I reset it
Firstly check that you haven't got the thread ****** set for rolled hem, this is sometimes little lever on the sewing plate just in front of the foot. The stitch forms over this ****** for normal overlocking but it is retracted out of the way for rolled hemming. So if you've left it retracted, this will muck up the normal stitch.
Now for a four thread stitch, set all the tension dials to 5, after checking that all the threads are flowing freely from the spools to the tension dials and not catching anywhere. Ensure aerial is fully raised too. Stitch length on 2.5 and differential on 0. Test serge on a medium weight fabric and check the stitching.
Now adjust the cutting blade to fill out the stitch if you are getting looping off the edge. ie if it is looping off the edge move blade to the right a little bit so there is more fabric inside the seam.
And reverse if stitching is pulling up the fabric inside the stitching into a ridge, move blade left a little.
Test stitch again. Now if tension is still out, just adjust the looper tensions in very small increments to tighten up the stitches, only ever 1/2 a number movement on the dial each time and test to see what effect this has. Do top looper if it appears looser on top, lower looper if that one appears to be loose.
If the machine's tension dials have been calibrated correctly, then 5 on all should give you a half way decent stitch and you should be able to just finesse with the blade and minor adjustments on the top and bottom loopers. If you just can't get to this point at all, finger test the tension on the thread below each tension dial by pulling gently and see if they all feel like they are under the same tension, if one is way out then this dial may be faulting. Turn it to zero and see if you can clean it by "flossing" with a piece of clean waste cotton, then turn back to 5, rethread and try again. Sometimes they get a bit of thread or dust in there.
Hope this helps you with the overlocker.
Sep 06, 2011 | Sewing Machines
White XL1760 cant find the setting for the straight stitch.....a, b, c????
You can download a manual for your White machine from the Singer website, link is
http://www.singerco.com/uploads/download/1111_white-1760-xl-x.pdf
Here are the relevant pages from the manual:
Straight stitch settings as follows:
stitch length on 2.5 (selector marked with blue arrow)
stitch width on zero (no swinging of the needle) selector marked with red arrow
stitch selector on A - selector marked with green arrow
Generally all sewing machines will have a similar three controls, because all stitches are a combination of moving the fabric forward a certain amount between the needle going through the fabric - the stitch length; and moving the needle from side to side - the stitch width.
And then a stitch selector for different stitch forms such as a blind hem or shell stitch where the needle is going through a series of different moves in sequence to form a special stitch. You still have the width and length controls to vary this formation.
For general sewing machine information www.sewing.about.com is excellent, there is lots of pages on general tips, cleaning, threading up and sewing machine know how. Try this page to start http://sewing.about.com/od/sewingmachineindex/ig/Sewing-Machines.--9k/
If you are a beginner, then I'd recommend printing out the instruction manual for your machine and putting into a binder, placing beside the machine, and carefully read from the beginning going through all the instructions to wind a bobbin, thread up, three or four times until you can do it without reading the manual, then practice stitching out each of the stitches your machine does. Buy a cheap exercise book and on each page, write the name of the stitch, staple the stitch sample in and either write down the settings used or glue in a photo taken of the machine controls you used. This way you can quickly flick through and refer to your settings next time. ADjusting the top tension dial will also adjust the stitch formation so read the manual and set the tension dial to the setting it suggests but sometimes you'll need to adjust it slightly to get the stitch looking even (balanced between top and bottom thread), especially for zigzags.
Practice a bit and you'll soon feel much more confident using the machine. Also, refer to the cleaning and oiling instructions and do it regularly, along with changing the needle for each new sewing project, about 4-6 hours sewing time. The needle is the most important part of a sewing machine, always use the right sized needle for the fabric. Refer here for info http://sewing.about.com/od/sewingmachineindex/ig/Sewing-Machine-Needles/
I hope this helps you with your White sewing machine, there are lots of great sewing machine books on the market too or in your public library to refer to. Also taking beginner sewing classes will really help you learn how best to use your machine. I've been sewing for over 38 years but still enjoy going to a class and learning a new technique from another enthusiast - life long learner!!
Jul 18, 2011 | Sewing Machines
The machine isn't making stitches. It's threaded correctly. I have been sewing leather recently and it's been acting up since then. I have cleaned the bobbin area. And have adjusted the tension...
Hello
Adjust the Stitch Length;
To make longer stitches, set the stitch length to a higher number. On many sewing machines, four is the longest possible stitch length and two is average.
To make shorter stitches, set the stitch length to a lower number. At a zero, the sewing machine may not actually make stitches, since the needle will go up and down in one place.
Cut a small scrap of fabric, preferably the same type you want to sew with.
Sew a few test stitches on the scrap. Examine the stitches to make sure they're the length you want.
Adjust the stitch length again as needed.
Jul 12, 2011 | Singer Sewing Machines
I've got an Elna 634 overlocker, and want to turn
Just trim the fabric to the desired hem length plus one inch, then overlock around this raw edge with thread close colour match to the fabric.
You then have the choice of either stitching around with a stretch stitch on your sewing machine, or hand sewing.
Being lycra shouldn't change how you hem them unless the trouser leg is extremely close fitting and the hem seam is going to be under tension.
My first choice would be using a twin needle in straight stitch from top side but this finish can pop/break if the hem is under tension. But perfect for most knit hems.
If you hand sew then you can turn up hem allowance and put a length of fusible hemming web inside the hem allowance and press it to hold. Then do a back stitch hand sew around to hold hem in place.
If you sew with the regular sewing machine, then use either the stretch stitch or a very small zig zag, and a ball point or stretch needle.
On ready to wear you would see a coverstitch hem but your overlocker doens't have this stitch.
Jun 12, 2011 | Elna Sewing Machines
Tension problem using zigzag stitch
Most likely the fabric is too light weight to sustain the thread tension using a wide zig-zag stitch. Tunneling will occur in this case.
Loosening the tension (top & bobbin) could also be beneficial.
Sometimes the machine has a special foot (sometimes called overlock) that will help. However, using something to add more body to the fabric, like a wash-away or tear-away fabric stabilizer to the seam or even adding paper will help limit tunneling. Sometimes heavy starch applied to the seamline before stitching will be helpful.
tunneling when zigzagging Threads Magazine Gatherings Forum Sewing...
zigzag stitch troubleshoot
May 08, 2017 | Kenmore 19233 Computerized Sewing Machine
Sewing Machines Logo
112 people viewed this question
Top Riccar Sewing Machines Experts
Tally Girl
Tally Girl
Derek Massey
Are you a Riccar Sewing Machine Expert? Answer questions, earn points and help others
