Vacuums Logo
magda orfanou Posted on Jul 27, 2013
S3755hoover I have problem in the motor ivive in creece I bay the vacuum from us it difficuly to fix? in greece
Anonymous
Level 1:
New Friend:
  • Contributor 2 Answers
  • Posted on Jul 29, 2013
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
131
Points
I berned the motor.i operete with transformer in Greece where can fix it in greece
How do i fix dyson DC41 Animal vacuum upright cleaner it has burning smell coming from motor and it blew the fuse box when i WENT TO VACUUM. the wire flex is a bit over twisted
You most certainly shorted this out and will need a new cord. Easy fix but you will have to take it apart and find where it failed. I doubt the motor fried but it is possible. When you take it apart look for the burn mark left by the electrical arc. That is the point you fix.
tip
Aerus Electrolux: Don't Void Your Warranty
Aerus Electrolux Warranty
Aerus carries a great warranty on their machines, up to 20 years limited on top of the line models. However, there are some things that WILL void the warranty. The following are probably the most common.
Use of generic/made-to-fit bags. There’s a reason genuine bags are strongly advised for use with the Aerus and previous Electrolux vacuums, and it’s not just the strength of the bag. Fine dust particles will get through generic bags and result in a damaged motor.
Vacuuming wet carpet and liquids. Although you may try to make sure you don’t use your vacuum on liquids, children, other family members, and/or house cleaners won’t necessarily be as careful/caring. If kids notice the vacuum doesn’t work anymore, they may try to hide the evidence, thus you may not know about the problem.
Keep in mind that if you have your carpet steam cleaned, it can take a week or more to thoroughly dry. Vacuuming during this time will result in water/mud getting into the motor, ruining it almost immediately. A wet bag will also usually break open, sending contents through the motor. The motor will have to be replaced, but it won’t be covered by a warranty.
Dismantling of vacuum by unauthorized persons. If you’re having a problem with your vacuum, and you think it’s an easy, quick fix, don’t. You may get it fixed, but this will void the warranty for future problems. It’s simply not worth it.
Commercial use. The Aerus commercial upright is made for tougher work, but only carries a one year limited warranty. Even though your machine may have a longer, better warranty when used properly, using it as part of a cleaning or similar business voids the warranty. Solution; Don’t do it.
Aerus Electrolux does NOT warranty machines sold over the internet, such as on E-bay. Only those purchased through an authorized franchise or representative carry Aerus' warranty.
Be aware of your machines’ capabilities and warranties. An Aerus Electrolux owner has made a wise investment in a top-of-the-line home cleaning system and generally desires to maintain the system in prime working condition, with full benefits.
Contact Aerus for additional information. You can find a local shop/consultant through their home page: http://aerushome.com/
on Aug 22, 2010 • Vacuums
Where do get your vacuum fixed motor
Vacuum Motor Repair Video - Collapsed impeller housing ...
? 1:46
https://www.youtube.com/watch?v=YaMBHkf0LUk
Sep 17, 2008 - Uploaded by Steambrite
If you just purchased a brand new vacuum motor for your carpet cleaning extractor, and it's making a ...
How to Fix a Vacuum Cleaner: 13 Steps (with Pictures ...
www.wikihow.com > ... > Appliances
wikiHowVerify that your vacuum cleaner is plugged in and turned on, and that the ... It may not be economical to replace the entire motor (it can cost as much as a new ...
Powers off when I let go of button
Most often the on/off switches are made of plastic, and are subject to breaking.
A local repair shop can fix it for you if they have access to parts.
You might be able to buy parts online at Amazon or e-bay.
God bless your efforts.
Code sankey 2300
where can fix it the motor in Greece.? i berned the motor I operete with transformer in Greece. I take the vacuum in US
model S3755
2helpful
2answers
Need a new aerus motor for epic series 6500 SR
ebay is the most reasonable place to purchase one $34-$50 dollars
Replacement Motor for a Miele S143 Vacuum Cleaner
Your vacuum should still be under warranty. If they dealer does not fix it for free call Miele directly.
2answers
Does not vacuum effectively. It smells like it is burning. I have only had this one year and hardly use it. When I brought it to a local vacuum repair place, he wanted to sell me another one, and, of...
The burning smell may be the motor that's on its way out. Vacuuming with a blocked pipe or sucking up liquids may cause the motor to burn prematurely. The motors arent very expensive, but on the small vacuum cleaners it is sometimes more cost effective to go for a cheap second hand vacuum than to fix it. Depends on if the guy that fixed it is trustworthy, but i can guarantee you the secondhand machine will not have a lifelong guarantee on it. ask for prices on the motor and decide which you can afford.
Dyson dc14 animal is falling apart! The canister keeps falling our and now the carpet/floor adjuster doesn't work AND the brush wont turn....tried everything. I live in Half Moon Bay, CA (near San...
the best sol would be to search for vacuum repair half moon bay, ca. To see if there is a vac shop near you. my suggestion's would be either Vacuum Cleaner Shop #(877) 822-8227 or Vacuum solotions #(502) 348-4900. hope this helps
Top Vacuums Experts
AskDyson
AskDyson
Anonymous
Are you a Vacuum Expert? Answer questions, earn points and help others
