Question about Bosch Refrigerators
Model B26F70SNS broken plastic ice maker shut off arm.
Sea Breeze
  • 4655 Answers
SOURCE: Amana ARB8057CSR Bottom Freezer Ice Maker Arm is broken & stuck
If water still continues going to the Ice Maker unplug the pair of wires on the back of the refrigerator that send water up to the ice maker. Now I see I am a little late answering your post, because I just happened to run across it. I was not here when you first posted the problem. Just let me know if you still need help, Thanks Sea Breeze
seabreezehvac@yahoo.com
Posted on Apr 20, 2009
  • 227 Answers
SOURCE: Kenmore 5814 rotationg ice maker arm gets stuck on pastic piece
Sears should fix it for free.
Posted on Jul 05, 2009
  • 21 Answers
SOURCE: my sears refrigerator has an ice maker that will not shut off
You will have to remove the icemaker from the freezer so you can see if the plastic is broken that holds the arm in position.
Posted on Jul 07, 2009
SOURCE: ice maker arm in freezer
On most automatic ice makers the arm is in the up position to make ice, but check with the manufacture to make sure
Posted on Jul 20, 2009
Bogie Boy
  • 46 Answers
SOURCE: Ice maker on GE refrigerator model TBX21C1 BRRWW
You have a stuck micro switch in the ice maker. Try taking out the maker and remove the metal plate 4 screws and you will see the switch that work on a cam rod. I believe you will find your problem. BB
Posted on Dec 16, 2009
Frigidaire ice maker model jbnd-28 stopped working
Hello - If your ice maker has stopped producing ice completely, please check these, in this order:
It may be turned off. Look for the wire along the right side of the ice maker that looks a bit like a coat hanger. If the wire is in the raised position, the ice maker is turned off. If so, try one of these: If your ice maker has a small red plastic lever, lower it to lower the wire. If there's no plastic lever, simply lower the wire. In either case, the ice maker should begin producing ice again.
Also make sure that the temperature is 8 degrees Fahrenheit or lower. If the freezer is too warm, the ice maker won't cycle properly.
When was the last time the filter was changed? Most side-by-side filters are recommended to be change approximately every 6-9 months depending on your water usage and frequency. A clogged water filter or a blocked supply water valve may also lead to low ice production.
The ice maker fill tube may be blocked with ice. If so, melt the blockage using a hair dryer-but be careful to not melt any plastic parts!
Also replace the water shut-off valve or water-inlet valve, or both, if necessary. The ice maker head assembly may have broken parts. Look to see if the gears are broken. Check to see if the small plastic arms that rest against the ice rake are broken. If the ice maker head assembly is modular and you've found broken parts, you can just replace it.
Should these suggestions prove to be ineffective, contact a professional to diagnose the unit.
Jan 03, 2013 | Refrigerators
Frigidaire plhs3teesbe model won't make ice
Hello - If your ice maker has stopped producing ice completely, you can try to check the following:
1. It may be turned off. Look for the wire along the right side of the ice maker that looks a bit like a coat hanger. If the wire is in the raised position, the ice maker is turned off. If so, try one of these: If your ice maker has a small red plastic lever, lower it to lower the wire. If there's no plastic lever, simply lower the wire. In either case, the ice maker should begin producing ice again.
2. Also make sure that the temperature is 8 degrees Fahrenheit or lower. If the freezer is too warm, the ice maker won't cycle properly.
3. The ice maker fill tube may be blocked with ice. If so, melt the blockage using a hair dryer-but be careful to not melt any plastic parts!
4. Also replace the water shut-off valve or water-inlet valve, or both, if necessary. The ice maker head assembly may have broken parts. Look to see if the gears are broken. Check to see if the small plastic arms that rest against the ice rake are broken. If the ice maker head assembly is modular and you've found broken parts, you can just replace it.
Oct 03, 2012 | Frigidaire FRS3R5EMB Side by Side...
The model for Scotsman ice maker is AFE400A-1B and it stop making ice. Can you help me diagnosis?
If your ice maker has stopped producing ice completely first unplug the ice maker and then check it in this order.
It may be turned off. Look for the wire along the right side of the ice maker that looks a bit like a coat hanger. If the wire is in the raised position, the ice maker is turned off. If so, try one of these:If your ice maker has a small red plastic lever, lower it to lower the wire.If there's no plastic lever, simply lower the wire.In either case, the ice maker should begin producing ice again. Also make sure that the temperature is 8 degrees Fahrenheit or lower. If the freezer is too warm, the ice maker won't cycle properly.The ice maker fill tube may be blocked with ice. If so, melt the blockage using a hair dryer-but be careful to not melt any plastic parts! Also replace the water shut-off valve or water-inlet valve, or both, if necessary.The ice maker head assembly may have broken parts. Look to see if the gears are broken. Check to see if the small plastic arms that rest against the ice rake are broken. If the ice maker head assembly is modular and you've found broken parts, you can just replace it.
Mar 15, 2011 | Scotsman Ice Maker WBin Flake Style water...
Ice maker stopworking
If your ice maker has stopped producing ice completely, check these, in this order:
Take care.
Mar 08, 2011 | Frigidaire Refrigerators
Ice maker will not make ice
hELLO THERE:
There's no ice If your ice maker has stopped producing ice completely, check these, in this order: It may be turned off. Look for the wire along the right side of the ice maker that looks a bit like a coat hanger. If the wire is in the raised position, the ice maker is turned off. If so, try one of these: If your ice maker has a small red plastic lever, lower it to lower the wire. If there's no plastic lever, simply lower the wire. In either case, the ice maker should begin producing ice again. Also make sure that the temperature is 8 degrees Fahrenheit or lower. If the freezer is too warm, the ice maker won't cycle properly. The ice maker fill tube may be blocked with ice. If so, melt the blockage using a hair dryer-but be careful to not melt any plastic parts! Also replace the water shut-off valve or water-inlet valve, or both, if necessary. The ice maker head assembly may have broken parts. Look to see if the gears are broken. Check to see if the small plastic arms that rest against the ice rake are broken. If the ice maker head assembly is modular and you've found broken parts, you can just replace it.
Dec 29, 2010 | GE Microwave Ovens
Hi, ice maker stopped working.
Hello there:
There's no ice If your ice maker has stopped producing ice completely, check these, in this order: It may be turned off. Look for the wire along the right side of the ice maker that looks a bit like a coat hanger. If the wire is in the raised position, the ice maker is turned off. If so, try one of these: bullet.jpg If your ice maker has a small red plastic lever, lower it to lower the wire. bullet.jpg If there's no plastic lever, simply lower the wire. bullet.jpg In either case, the ice maker should begin producing ice again. Also make sure that the temperature is 8 degrees Fahrenheit or lower. If the freezer is too warm, the ice maker won't cycle properly. The ice maker fill tube may be blocked with ice. If so, melt the blockage using a hair dryer-but be careful to not melt any plastic parts! Also replace the water shut-off valve or water-inlet valve, or both, if necessary. The ice maker head assembly may have broken parts. Look to see if the gears are broken. Check to see if the small plastic arms that rest against the ice rake are broken. If the ice maker head assembly is modular and you've found broken parts, you can just replace it.
Sep 27, 2010 | KitchenAid Refrigerators
Ice maker not making ice
Hello there:
Aug 07, 2010 | Maytag Freezers
The ice maker didin't work
hELLO THERE:
Jul 27, 2010 | Kenmore 57029 Side by Side Refrigerator
Ice maker stopped
Hi!
Please check these:
Please do rate this solution as FixYa and revert for further assistance.
Thanks
Rylee
May 23, 2009 | Whirlpool Gold Series GI15NDXT 15"...
My sears refrigerator has an ice maker that will not shut off
Jan 30, 2009 | Kenmore 55693 Side by Side Refrigerator
Refrigerators Logo
21 people viewed this question
Top Bosch Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Are you a Bosch Refrigerator Expert? Answer questions, earn points and help others
